Re: Piston Wall Clearance
[Re: RapidRobert]
#110385
08/26/08 01:32 AM
08/26/08 01:32 AM
Posts: 309 Maracaibo,Venezuela
GTMaracucho
super street
super street
Maracaibo,Venezuela
on their(KB) site they want .004 piston to wall clearance on the top ring for each inch of bore with forged(not hypereutectic) pistons(If I am reading their site correctly,it was a little confusing) which would put you at .016" for a street normally aspirated application(the top ring). At .012 you are tighter than they recommend but I dont know if your rings are butting & causing the problem or not but the more I think about it I would be inclined to think the rear mounted battery & long cables are the culprit. When its warmed up it cranks too slow & this is the issue right? At that point in time could you pull the plugs & see how it cranks & also with the plugs out put a socket & breaker bar(or torque wrench) on the front harmonic dampener bolt & see how hard it is to turn ? or easier yet at that point in time get a jump directly to your starter & dont use your trunk battery & see what it does. It is midnight here & I am going to have to sign off. I will get back to you tomorrow. Post what you find out.
Thanks for your help..... Now I have in my hands somethink to do tomorrow
[Re: GTMaracucho]
#110387
08/26/08 02:48 AM
08/26/08 02:48 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
ptw on kbs is 2-4 thou there designed to be tighter than forged i set up at 4-6 thou ptw, its where the top ringland in piston is machined that it comands twice the end gap for expansion if you dont follow that piston top will break off when under load and up to temp
MOPAR OR NO CAR
[Re: hemigod426]
#110388
08/26/08 08:54 AM
08/26/08 08:54 AM
dogdays
You didn't read the original post. He says the pistons are KB FORGED. He says he has 0.007" piston-to-wall clearance, I think that's too much, but it's the maximum in the KB chart for drag racing, 4" piston. He says he has ring gap of 0.012". The chart says 0.004" per inch of bore diameter, that would be 0.016" so the ring gaps are too tight.
R.
[Re: dogdays]
#110389
08/26/08 10:18 AM
08/26/08 10:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
he also said hard turning when hot...could it be a timing issue instead of a clearance issue?
**Photobucket sucks**
[Re: RapidRobert]
#110391
08/26/08 11:13 AM
08/26/08 11:13 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
.007 on the pistons is ok, loose and mabye noisey when started cold, but ok. .012 on the top ring is bad, and technically, leaving the 2nd ring a little bigger than the top will help ring seal. So with a 360 (4.03 when bored .030 over) I'd be setting the top ring at .017 and the 2nd ring at .020. Also, always round up when you get a "point something" (4.03x.004= .01612, or .017). You want to err to the large side on any performance engine.
[Re: RapidRobert]
#110392
08/26/08 01:03 PM
08/26/08 01:03 PM
GTMaracucho
super street
super street
Maracaibo,Venezuela
excellent idea! Could it actually be something thatsimple as overadvanced timing On our stock car we had to engage the starter THEN switch on the ign to get it to crank when things were hot. If he grounds the coil wire & then cranks we'll have the ans to that.
I have 34° and MSD 6 Digital Plus with retard option
[Re: RapidRobert]
#110399
08/26/08 09:55 PM
08/26/08 09:55 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
When its hot and cranking slow unhook the MSD box and then crank it to verify if it is an over advanced ign. You have forged pistons and not hypertech pistons so then I agree the top ring gap should be .016 to .017 and the .007 Piston to wall clearence is a bit on the loose side at .007 but it will work. Will most likely be a bit noisey when cold like was said but it will be ok as it's not to tight. If you find the eng is tight and its not the ign then I would think about that .012 top ring gap you have in it. Good luck , Ron
[Re: 383man]
#110400
08/27/08 07:18 PM
08/27/08 07:18 PM
GTMaracucho
super street
super street
Maracaibo,Venezuela
OK Gents.... Today I talked with my mechanic and he said that the first ring is .017" & second is .022". I started and warm up the engine, then I pull out all spark plugs and turn manually and the engine is very..very hard to turn. Maybe on this week end we pull out the engine and check everything again. I'm thinking go to more clearance on Piston to wall, what about .010"?? ![](/ubbthreads/images/graemlins/frown.gif)
