Re: Will a /6 904 bolt up to a 318?
[Re: MoparJoe]
#110174
08/26/08 10:08 PM
08/26/08 10:08 PM
Huh?
Even if you do all that stuff you're still missing about 80hp/100 lb/tq compared to a stock 2barrel 318.
??? Comparing factory net hp ratings, there's only 50 hp difference, stock to stock.
On a 67-72 A body a /6/904 to 318/904 swap shouldn't take more than 1 day, if it does you're doing something wrong.
Guess I'm slow then . . .
[Re: slantzilla]
#110177
08/27/08 08:56 AM
08/27/08 08:56 AM
Posts: 411 Texas
vynn3
Texas
Why would you trash the bulkhead connector? The engine leans the other way.
Just more slant hateration, I assume.
If you want a V8, fine. No need to keep ragging on slants, though. Slants have been good, solid, reliable engines for 40+ years. And my mildly-modded is anything but slow.
But hey, if you break the bulkhead when you pull your engine, it's the engine's fault, right?
[Re: MoparJoe]
#110178
08/27/08 09:21 AM
08/27/08 09:21 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
" lopsided lump" ?
Oh, you didn't just say that?
Let's race!!!
[Re: 340727dart]
#110181
08/28/08 01:09 PM
08/28/08 01:09 PM
Posts: 17,884 S.E. Michigan
ZIPPY
S.E. Michigan
What you should do is find a rusted or wrecked car (or truck) with a good running 318 and good trans in it, take everything, and put it in your car.
I just now located a '77 Aspen wagon the guy is using for a daily driver with a 318/904 and will sell to me for $500. And, another buddy has volunteered to haul the body to the scrap yard for me.
That's the way it's done
[Re: ZIPPY]
#110182
08/28/08 02:29 PM
08/28/08 02:29 PM
Posts: 4,443 Michigan
MarkZ
Worthy
Worthy
Find an 85' or later M body. The 318s in them had the roller cams and swirl port heads (302 castings). They were only light on power due to the smog equipment, which I don't think would be following over with it anyways.
[Re: MarkZ]
#110183
08/28/08 03:03 PM
08/28/08 03:03 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
or keep the slant and get an A833OD manual. my duster is a stock 1bbl slanty with the OD tranny (3.09 first, 1.74 2nd, 1:1 3rd, .73 OD). with 25" tall tires and a 3.21 rear it keeps up with modern traffic just fine, and knocks down 24-26 combined mpg
[Re: patrick]
#110184
08/30/08 04:24 PM
08/30/08 04:24 PM
Posts: 8,144 Arkansas
340727dart
Arkansas
I rebuilt the one barrel Holley a couple of days ago and that really helped with the idle and smoothness of the engine. However, it is still gutless. So, I had my wife floor the gas pedal (engine off, of course) while I looked down the carb throat. It doesn't even go to half throttle. After inspecting it some more, I discovered it has an incorrect throttle cable on it. In fact, it looks more like an aftermarket transmission kickdown cable adapted to fit. Anyway, I placed a parts wanted ad on Moparts last night and have already gotten several responses. Thanks Moparts.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: scratchnfotraction]
#110186
08/30/08 11:27 PM
08/30/08 11:27 PM
Posts: 1,630 Burma Shave
plymouthfan
Burma Shave
I have the correct throttle cable on my slant 6 and it's still slower than molasses dripping uphill.
One red car, one yellow car.
