Re: what do you think i might gain ? [Re: Mr.Yuck] #1101549
10/26/11 06:07 PM
10/26/11 06:07 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Wow I would have thought that combo would have run 11.20's out of the box. I'm at 11.38 @ 118.2 w/ less motor and less work. I'll be shooting for 11.20's this weekend after getting my axles in. What jetting are you running? I have 70's and 35 squirters (stock six pack) using purple springs I get zero bog and this thing jumps right up to 6k. They only thing different is I'm running a small solid roller cam (580/588), but I'm also running tiny 1 3/4 headers, 3800 stall and 3.91's. I would have thought those extra cubes would get it done w/o much more cam?????
You have stage VI heads. lol! Not Eddy's Gotta love the stage VI's
67' charger 499 RB 10.57 at 127
Re: what do you think i might gain ? [Re: tex013] #1101550
10/26/11 06:11 PM
10/26/11 06:11 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
That's testament to how well tuned your satellite is, your motor would run 10.60's in an A body.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: what do you think i might gain ? [Re: dragram440] #1101551
10/26/11 06:14 PM
10/26/11 06:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes but doesn't he had D.Porter ported e-heads? I'd think they'd flow pretty good. I think there is more in the car. What is he shifting at? what's the 60foot. Seems like his MPH should be higher. I mean the car runs good but I'd think it should be an easy 11.20 ride.
Tex try some more jet in the center and bump the squirters. Car looks great and has a bunch of air under it.
Re: what do you think i might gain ? [Re: Mr.Yuck] #1101552
10/26/11 06:17 PM
10/26/11 06:17 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
The stage VI coment was more of a joke then anything. Most people on here seem to really dis the stage VI heads.
I think it has alot more in it also.
Re: what do you think i might gain ? [Re: Mr.Yuck] #1101553
10/27/11 06:02 AM
10/27/11 06:02 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Stage 6s have a lot more flow potential than eddys.....no?
Re: what do you think i might gain ? [Re: RemCharger] #1101554
10/27/11 06:18 AM
10/27/11 06:18 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I believe, Stage 6 heads have a better exhaust port than eddy's.
Mick
best 60ft 1.36
Re: what do you think i might gain ? [Re: deaks] #1101555
10/27/11 08:22 AM
10/27/11 08:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no idea there, I do know that I'm giving up a 1/4" inch on the headers and 65 cubic inches.
That car will run 10's once they figure it out...keep tweaking it.
Re: what do you think i might gain ? [Re: Mr.Yuck] #1101556
11/01/11 06:07 PM
11/01/11 06:07 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
time for an update,sorry for the delay the alternator dumped its guts on Thursday night.
ran the car yesterday afternoon but was a little suprised with how much jetting it wanted.
prior to running i had #79 outer,#62 centre
at cruise and even with a full pull only on the centre carb the #62 was good AFR
with outer's it was lean still,went to #85 and it picked up but needed more.ran out of time and will go to #89.played with timing,liked its 25 initial to give about 38 total.
it has a K&N filter but made 4-5 extra HP with the cleaner off.
is there a taller,4" K&N,or do you just stack 2 of them ?
we did check vacuum from under the centre carb,did not go positive with the 3 carbs operating.
it does seem a little softer on secondary opening with the extra jetting.
i have not had much to do with tri carbs before,do you see anything wrong with my direction.
Cab,fuel system has a Carter 90 electric pump at rear and Carter hi perf mechanical pump.8psi at idle,6 1/2 psi under full load.not my choice but will have to see how it goes on the strip.
car certainly gets up and boogies when you open it up on the street.
HP gain is in line with what i aimed for,another 5hp would be nice
Ron,Greg says thanks for the comment
pics are TOO big so here is some links
http://i1018.photobucket.com/albums/af301/texsautomotive/SANY00923.jpg
http://i1018.photobucket.com/albums/af301/texsautomotive/SANY00912.jpg
dyno sheet -
http://i1018.photobucket.com/albums/af301/texsautomotive/IMG-1.jpg
Tex
Re: what do you think i might gain ? [Re: tex013] #1101557
11/01/11 08:03 PM
11/01/11 08:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Tex run it w/o the filters just the baseplate
