Re: Crane rocker carnage pic. Need rocker recommendations
[Re: Charger453]
#1101179
10/24/11 11:15 PM
10/24/11 11:15 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I dont charge $125 more for Harlands....too bad...you just missed my sale a short time ago....drop me a PM...I can help you out... https://board.moparts.org/ubbthreads/show...e=0#Post6776844
RIP Monte Smith
[Re: Charger453]
#1101182
10/24/11 11:26 PM
10/24/11 11:26 PM
Posts: 2,056 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Brian, that looks real familiar! I had a spare rocker around, slapped her on and went racing yesterday. I'm just worried it will keep happening. My car is driven on the street a decent amount.
I'm not 100% sure on the cause of my broken rocker (I don't run a lot of spring pressure and a .590 solid lift cam), but I did find the valve cover gasket had sliped up and gotten "pinched" by the valve spring on that cylinder. Possibly coil bind??? Could have just been the rocker failed. ![](/ubbthreads/images/graemlins/shruggy.gif)
Brian Dunnigan
[Re: rickraw]
#1101186
10/25/11 01:03 AM
10/25/11 01:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
t&d.$$$, but worth it. stay safe, seeya.
thats all I run now... would be the last set of rockers you would buy ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1101187
10/25/11 01:44 AM
10/25/11 01:44 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
T&D's are awesome, but cost a few pennies. Honestly I bought my Harland Sharp's from Performanceonly and have never looked back. I don't run anywhere near the lift you guys do, but still they work well for me.
Mike
1969 Dodge Dart Swinger
[Re: Charger453]
#1101190
10/25/11 12:22 PM
10/25/11 12:22 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
You broke one, I'd expect more to follow , plus ditch those springs between them for solid spacers .
[Re: MR_P_BODY]
#1101191
10/25/11 12:25 PM
10/25/11 12:25 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
the best money i have spent ,t&d all the way ![](/ubbthreads/images/graemlins/drive.gif)
[Re: Ian]
#1101192
10/25/11 04:41 PM
10/25/11 04:41 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
Hello, t&d's will also break, .650 lift roller 600 lbs spring, have broken 3-4 in 250 runs, they do have a life cycle as t&d says. just broke 1 intake at lvd this past weekend. car has been sitting since may without backing off rockers??
gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Thumperdart]
#1101194
10/25/11 09:45 PM
10/25/11 09:45 PM
Posts: 16,934 NC
440Jim
NC
ThumperDart Exactly, I don`t think the Cranes or Comps were designed for those pressures and that`s why I went to Harlands.............
440lebaron: Hello, t&d's will also break, .650 lift roller 600 lbs spring, have broken 3-4 in 250 runs, they do have a life cycle as t&d says. just broke 1 intake at lvd this past weekend. car has been sitting since may without backing off rockers??
gary
This is disappointing. The original poster is only running 550 lbs open pressure (his estimate) and the rockers are breaking. There has to be more to it! -number of runs -valve float or surge -etc. or something
Now I agree Harland Sharp or T&D are better, but at 550 lbs open that is disappointing. And the T&D post is disappointing at 600 lbs open. These are not high pressures, IMO. But I do agree that aluminum doesn't last forever. But I know a bunch of bracket racers that put 300 passes on their cars every season; and they don't buy rockers every year.
Maybe I should just stick to the flat tappet cams and 400ish open pressure... Even the Indy rockers hold up to that ! LOL
What's Up with this????
[Re: dragram440]
#1101195
10/25/11 09:51 PM
10/25/11 09:51 PM
Posts: 20,697 in a cattle trailer down by th...
Guitar Jones
I have the blue Mopar Performance ones that are made by Crane. I broke one this season at just under 7000 RPM's in the lights on 1/4 mile. Mine broke at the same spot, looks identical to yours. I replaced mine with a spare on, and replaced the mangled up push rod, so far so good.
Brian Dunnigan
I am running these same blue mopar performance rockers with a solid roller cam. I hope mine dont do that. Or should I be expecting it?
I have both the Crane Golds and the Mopar blues and they are not the same.
[Re: Dodgem]
#1101198
10/30/11 11:55 AM
10/30/11 11:55 AM
CompWedgeEngines
Syracuse,NY
I'd be willing to bet you know already why this happened. ![](/ubbthreads/images/graemlins/eeek.gif) Rocker breaking, causing a rod to break? Or rod breaking, casuing a rocker to break...hmmmm..decisions...decisions....I know where I would put my money.... ![](/ubbthreads/images/graemlins/laugh2.gif) How bad is the rest of the damage?
RIP Monte Smith
[Re: Mopar-Al]
#1101200
10/30/11 12:31 PM
10/30/11 12:31 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
This thread is making me nervous now. I have 230 closed 685 open on my springs. crane golds at 1.5 ratio. low .700 lift on eddy rpm heads. I planned on changing the complete top end by summer, but may end up doing it sooner.
I planned on waiting until next spring since the season is almost over, but Todd (Competitionwedge) gave me a sweet price so I'm getting them now. I may do a little street driving if the weather stays nice. My local track is done after today, but KCIR runs thru November according to their site, so I might try to run down there sometime. I was nervous about the Cranes and had one break. I'm not waiting any longer. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Scott58]
#1101204
11/04/11 01:08 AM
11/04/11 01:08 AM
Posts: 808 mckinney texas
shoebox
mckinney texas
RAS makes a very strong rocker in stainless, good if you do a lot of street use. Very expensive, though.
That would be fine if you could call these people and someone Would answer the phone! They don't return calls or emails. I don't think Anyone can get these rockers anymore! Lol. I'm sore with these folks.. Does it show? Maybe I'll get my rockers back someday.
[Re: Guitar Jones]
#1101205
11/04/11 02:24 PM
11/04/11 02:24 PM
Posts: 3,695 nc
emarine01
nc
Brian Dunnigan
Alrighty then... which one is better.... ![](/ubbthreads/images/graemlins/scope.gif)
[Re: rickraw]
#1101207
11/04/11 05:07 PM
11/04/11 05:07 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
I feel that a 620 lift or less flat tappet is the limit for Cranes and hughes. 700 is the limit for harland sharps. Anything bigger needs paired jessel or T&D... Flimsey cheap pushrods will also cause problems. Overkill is the safe way to go when you are building a valve train. poppaj
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#1101208
11/04/11 11:10 PM
11/04/11 11:10 PM
Posts: 4,085 Mo.
racerx
Mo.
Harland sharps r rated up to 900" lift ive just upgraded to a set of Smith Brothers 120 wall/3/8 push rods at the end of the season hoping to eliminate some of the flex in the drive train ![](/ubbthreads/images/graemlins/thumbs.gif)
