Re: Methanol car over the winter (cold winter) [Re: Mopar-Al] #1099310
10/24/11 04:31 PM
10/24/11 04:31 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
I would take carb off WD it. Drain cell put diesel in it turn on pump so lines got full. Wd motor crank it few times. Back valve train off. Little extra work but kept problems away!!!!
Re: Methanol car over the winter (cold winter) [Re: 440Jim] #1099311
10/24/11 08:30 PM
10/24/11 08:30 PM
NC
440Jim Offline
440Jim  Offline
NC
NAPA sells a heater you can put in the lower rad hose, just cut the hose in half and clamp it in place. They have different sizes and cost about $35.
Good Luck
I searched the NAPA web site and here is an example, 1-3/4" hose, 600 Watt
NAPA KAT 14700 link
I also looked at the Autozone web site, and this looks like the same thing for $24.99
Auto Zone web link
Re: Methanol car over the winter (cold winter) [Re: Mopar-Al] #1099312
10/24/11 08:35 PM
10/24/11 08:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Don't start it at all.
If you install a heater, keep it off until the day before you need to drive the car - heat speeds up all chemical reactions - like rust and corrosion.
Boffin Emeritus
