Re: Blower Setups for Street? Who has Used What? [Re: MR_P_BODY] #1097275
11/10/11 07:03 PM
11/10/11 07:03 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I have a Dyers on a 440 intake.. I plan on sending
it in for a freshening and a polish job then its going
up for sale... its a good unit but I'm changing over
to other stuff
Or you could just sell me that scrap like it is . My new powerplant is going to be blown and I could save you the trouble.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Blower Setups for Street? Who has Used What? [Re: jim sciortino] #1097276
11/11/11 08:50 PM
11/11/11 08:50 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
PSI 206B....
So how do you like that set-up? Is it streetable with the carbs?
Some more details about that combo would be great..
Re: Blower Setups for Street? Who has Used What? [Re: Dragula] #1097277
11/11/11 09:35 PM
11/11/11 09:35 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
PSI 206B....
It's a 526 4.310 x 4.500 w/KB block and Stage V big valve heads, TD/Barton rockers. The mistake I made was not having PSI cut the bottom of the blower bigger to hold less boost in the case. If I keep the car, I'm going to send the blower back for a bigger cut so I can drive the blower slower and use pumpgas for street driving.
It made 1629hp @8000rpm, just touching 20lbs and even in this configuration, it's pretty easy to putt around. It's just expensive to burn C-16. With the small cut, the discharge temp in the manifold climbs when going slow, or stopped at a light. It drops as you drive and the harder you hit it, the cooler it gets. Just opposite of a roots.
After talking with PSI, we'll probably redo a couple things and knock it down to the 1200hp range for street driving on 93, then swap pulleys, retune the carbs and drive it to 30lbs with C-16 and see how much we can make.
Unless I sell the car and turn my Dart (superstock style chassis) into a grudge deal.
Re: Blower Setups for Street? Who has Used What? [Re: jim sciortino] #1097278
11/12/11 10:02 AM
11/12/11 10:02 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Like you need that much HP for the street I underdrive run 4 lbs of boost on pump gas for the street with over 750 HP available.UD it enough to use just pump gas
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Blower Setups for Street? Who has Used What? [Re: hemi-itis] #1097279
11/12/11 07:55 PM
11/12/11 07:55 PM
Trumbull,CT.
Trumbull,CT.
You couldn't be more right. To much steam isn't really fun on the street cuz you can't jack around with it and burning C-16 to get a burger is ridiculous.
If I don't sell the car, I'm going to back the engine down plenty by opening up the blower cut and a pulley change. The chassis is killer so it can take good power, but the most fun I ever had in a street car was in the mid 90s with a 69' Barracuda w/SS springs.....it had a 499ci 440-1 that ran in the 9.20-9.40 range. About 800hp and was a blast on an empty Rt. 25 connector and ATCO rent days.
Re: Blower Setups for Street? Who has Used What? [Re: MR_P_BODY] #1097280
11/21/11 02:43 AM
11/21/11 02:43 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
to other stuff
Mike ,You have a PM !
RT
