Re: Six Pack Rocker Arms [Re: JohnRR] #1094777
10/16/11 12:12 AM
10/16/11 12:12 AM
IN
ahy Offline
ahy  Offline
IN
A set of Comp Pro Magnum rockers would work well in your application.
Re: Six Pack Rocker Arms [Re: JohnRR] #1094778
10/16/11 12:22 AM
10/16/11 12:22 AM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
A set of crane ductiles would work with only minimal clearancing for the rockers needed .
What heads are you going to run ?
Probably some 452's. Where did you have to clearance those
rockers?
Re: Six Pack Rocker Arms [Re: 440child] #1094779
10/16/11 10:11 AM
10/16/11 10:11 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
rockers?
This works well and you don't have to move the baffels.
Re: Six Pack Rocker Arms [Re: 62maxwgn] #1094780
10/16/11 10:24 AM
10/16/11 10:24 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
rockers?
That's all the needs to be done, nothing needs to be done to the rockers just drill he baffles to clear the adjusters.
Re: Six Pack Rocker Arms [Re: ahy] #1094781
10/16/11 10:37 AM
10/16/11 10:37 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
The spring load required for .55 lift will likely push a pushrod through the stamped rocker. Over about .5 lift, the OE stamped get real risky. You need a better rocker.
saw it happen with a 292/509, replaced with Crane irons and never a problem after that.
Re: Six Pack Rocker Arms [Re: 62maxwgn] #1094782
10/16/11 08:47 PM
10/16/11 08:47 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
rockers?
That's the ticket! I always wondered what was the interference point between the rocker & the v/c.
Re: Six Pack Rocker Arms [Re: 440child] #1094783
10/17/11 10:40 AM
10/17/11 10:40 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Anyone have a picture of the inside of an original max wedge valve cover considering they run a rocker that is very similar to the crane/isky ductiles ?
Re: Six Pack Rocker Arms [Re: JohnRR] #1094784
10/17/11 02:04 PM
10/17/11 02:04 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
That's a great idea concerning the Max Wedge valve covers. I googled it and found that Mancini Racing sells the reproductions and the sales rep. said they would fit a 440. They don't have pictures on the website so that would really help.
Re: Six Pack Rocker Arms [Re: JohnRR] #1094785
10/17/11 05:14 PM
10/17/11 05:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Don't really want to take one back off,two weeks ago I could have helped.If I remember correctly there is about 1/4" difference in the height of the baffles.Also,the original Max Wedge rockers were not a true 1.5 ratio,more like 1.4,don't know if that would have any bearing on clearance.
Re: Six Pack Rocker Arms [Re: 62maxwgn] #1094786
10/18/11 10:44 AM
10/18/11 10:44 AM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
Thank you guys for all the help!!
Re: Six Pack Rocker Arms [Re: 440child] #1094787
10/18/11 12:30 PM
10/18/11 12:30 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
just one more note on the MP stamped rockers, I bought a set this year, MP#P4529743 for my 440 stroker, power on the dyno was low so we measured true valve lift, The rockers were actually closer to a 1.3:1 ratio, making what should have been a warm street cam act like a grain truck/RV cam, just something to be aware of and check!
Re: Six Pack Rocker Arms [Re: 70Sbird] #1094788
10/18/11 01:15 PM
10/18/11 01:15 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
YIKES ... but then again yet another QUALITY part from MP ...
Re: Six Pack Rocker Arms [Re: 440child] #1094789
10/18/11 01:19 PM
10/18/11 01:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no such thing as a six-pack rocker arm. You speaking of the heavy duty units? I'd think any speed shop or online store can get you what you want.
Coming soon!!!!
Re: Six Pack Rocker Arms [Re: Mr.Yuck] #1094790
10/18/11 01:31 PM
10/18/11 01:31 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I have crane adjustable roller rockers under my stock '70 stamped valve covers....
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Six Pack Rocker Arms [Re: Mr.Yuck] #1094791
10/18/11 02:04 PM
10/18/11 02:04 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The rocker arms used on the 69 440 six pack were HD units and referred to ... I think ... as 6 pak rocker arms ...
Re: Six Pack Rocker Arms [Re: JohnRR] #1094792
10/18/11 02:47 PM
10/18/11 02:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You don't have to think John!
Re: Six Pack Rocker Arms [Re: DPelletier] #1094793
10/18/11 03:00 PM
10/18/11 03:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Dave,I have Isky rockers and I had to modify the baffles for clearance as shown above,not for the adjuster but the other end.Guess it depends on the rocker design.
Re: Six Pack Rocker Arms [Re: 62maxwgn] #1094794
10/18/11 05:48 PM
10/18/11 05:48 PM
DPelletier Offline
DPelletier  Offline
Hmmm; yeah, must be. I think mine are Crage 64750's, but my invoice is in my shop at home
Re: Six Pack Rocker Arms [Re: 62maxwgn] #1094795
10/18/11 08:41 PM
10/18/11 08:41 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I would have thought that clearance was for the adjuster , I learn something new from you Bill all the time ...
