Re: Six Pack Rocker Arms
[Re: JohnRR]
#1094778
10/16/11 12:22 AM
10/16/11 12:22 AM
Posts: 205 Martinsville, VA
440child
Martinsville, VA
A set of crane ductiles would work with only minimal clearancing for the rockers needed .
What heads are you going to run ?
Probably some 452's. Where did you have to clearance those rockers?
[Re: 440child]
#1094779
10/16/11 10:11 AM
10/16/11 10:11 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This works well and you don't have to move the baffels.
[Re: 62maxwgn]
#1094780
10/16/11 10:24 AM
10/16/11 10:24 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
That's all the needs to be done, nothing needs to be done to the rockers just drill he baffles to clear the adjusters.
[Re: ahy]
#1094781
10/16/11 10:37 AM
10/16/11 10:37 AM
Posts: 176 Rome, GA
GTXX
Rome, GA
The spring load required for .55 lift will likely push a pushrod through the stamped rocker. Over about .5 lift, the OE stamped get real risky. You need a better rocker.
saw it happen with a 292/509, replaced with Crane irons and never a problem after that.
[Re: 62maxwgn]
#1094782
10/16/11 08:47 PM
10/16/11 08:47 PM
440child
Martinsville, VA
That's the ticket! I always wondered what was the interference point between the rocker & the v/c.
[Re: JohnRR]
#1094784
10/17/11 02:04 PM
10/17/11 02:04 PM
440child
Martinsville, VA
Anyone have a picture of the inside of an original max wedge valve cover considering they run a rocker that is very similar to the crane/isky ductiles ?
That's a great idea concerning the Max Wedge valve covers. I googled it and found that Mancini Racing sells the reproductions and the sales rep. said they would fit a 440. They don't have pictures on the website so that would really help.
[Re: JohnRR]
#1094785
10/17/11 05:14 PM
10/17/11 05:14 PM
62maxwgn
Blair County,PA
Don't really want to take one back off,two weeks ago I could have helped.If I remember correctly there is about 1/4" difference in the height of the baffles.Also,the original Max Wedge rockers were not a true 1.5 ratio,more like 1.4,don't know if that would have any bearing on clearance. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 70Sbird]
#1094788
10/18/11 01:15 PM
10/18/11 01:15 PM
JohnRR
just one more note on the MP stamped rockers, I bought a set this year, MP#P4529743 for my 440 stroker, power on the dyno was low so we measured true valve lift, The rockers were actually closer to a 1.3:1 ratio, making what should have been a warm street cam act like a grain truck/RV cam, just something to be aware of and check!
YIKES ... but then again yet another QUALITY part from MP ... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Mr.Yuck]
#1094790
10/18/11 01:31 PM
10/18/11 01:31 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I have crane adjustable roller rockers under my stock '70 stamped valve covers.... ![](/ubbthreads/images/graemlins/shruggy.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: JohnRR]
#1094792
10/18/11 02:47 PM
10/18/11 02:47 PM
62maxwgn
Blair County,PA
no such thing as a six-pack rocker arm.
The rocker arms used on the 69 440 six pack were HD units and referred to ... I think ... as 6 pak rocker arms ...
You don't have to think John! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: DPelletier]
#1094793
10/18/11 03:00 PM
10/18/11 03:00 PM
62maxwgn
Blair County,PA
Dave,I have Isky rockers and I had to modify the baffles for clearance as shown above,not for the adjuster but the other end.Guess it depends on the rocker design.
[Re: 62maxwgn]
#1094795
10/18/11 08:41 PM
10/18/11 08:41 PM
JohnRR
I would have thought that clearance was for the adjuster , I learn something new from you Bill all the time ...
