Page 2 of 3 1 2 3
Re: 64 pushbutton trans need help! [Re: calrobb2000] #1094092
10/17/11 09:18 PM
10/17/11 09:18 PM
N.Y.
sixpacksteve Offline OP
N.Y.
Will Do!
Hell Hath No Fury Like Mine
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094093
10/18/11 05:03 PM
10/18/11 05:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
i can push all of the buttons and they seem to work but won't go into neutral or any other gear.
If it's not in Neutral it must be in some "other gear".
Re: 64 pushbutton trans need help! [Re: John_Kunkel] #1094094
10/18/11 06:43 PM
10/18/11 06:43 PM
N.Y.
N.Y.
ok, this morning, dropped pan readjusted the cable. put everything back together . hit all the gears,GREAT! then later tested it again NOTHING
it won't go into gear, stuck in neutral. i guess back to the drawing board.
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094095
10/18/11 06:49 PM
10/18/11 06:49 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Try pulling the park-lever up-and-down a couple of times...
Re: 64 pushbutton trans need help! [Re: dOc …] #1094096
10/18/11 07:03 PM
10/18/11 07:03 PM
N.Y.
N.Y.
tryed it! NOTHING
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094097
10/18/11 07:05 PM
10/18/11 07:05 PM
N.Y.
N.Y.
when i push the buttons it seems to shift, just nothing happens doesn't go into gear.
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094098
10/18/11 07:09 PM
10/18/11 07:09 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Do the buttons CLICK IN ? ... and stay-in ? ... Did you observe the cable action in the valve-body underneath the car?
Re: 64 pushbutton trans need help! [Re: dOc …] #1094099
10/18/11 09:36 PM
10/18/11 09:36 PM
N.Y.
N.Y.
the buttons do click in and stay in but i doesn't go into gear
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094100
10/18/11 10:52 PM
10/18/11 10:52 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
....but did you or someoen else observe from underneath with the pan off ? .... something is jamming the cable up.
Re: 64 pushbutton trans need help! [Re: dOc …] #1094101
10/18/11 11:08 PM
10/18/11 11:08 PM
N.Y.
N.Y.
yes,i had friend shift while i adjusted it. it was perfect. test drove it was fine.. then test drive again squat. i'm going to drop the pan again. something is not right with the cable. where would i get a new cable?
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094102
10/19/11 01:22 AM
10/19/11 01:22 AM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
I think it is something ON or IN the VB ... a bad cable would not act this way.
Re: 64 pushbutton trans need help! [Re: dOc …] #1094103
10/19/11 12:18 PM
10/19/11 12:18 PM
Minnesota
peabodyracing Offline
Minnesota
If you've already done so my apologies for doubling up on this, but did you change the filter? I've had these plug up after sitting a long time. I'm in the middle of the same thing with a Coronet that sat for a long time. Got it running, tranny worked for a few tries and then nothing. Filter was plugged.
Lead, follow or get the hell out of the way
Re: 64 pushbutton trans need help! [Re: peabodyracing] #1094104
10/19/11 04:24 PM
10/19/11 04:24 PM
N.Y.
N.Y.
no, i didn't try that. its raining but i'll change filter as i check cable position.
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094105
10/19/11 04:55 PM
10/19/11 04:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If in doubt about whether the cable is moving the roostercomb, just pull the NSS and you can observe the movement of the roostercomb.
Re: 64 pushbutton trans need help! [Re: John_Kunkel] #1094106
10/19/11 06:05 PM
10/19/11 06:05 PM
N.Y.
N.Y.
ok john, forgive me but whats roostercable, and nss? thanks
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094107
10/19/11 07:38 PM
10/19/11 07:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The roostercomb is the internal shift lever that the spring-loaded ball sits in to make shift detents, NSS is Neutral Safety Switch.
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094108
10/20/11 02:50 AM
10/20/11 02:50 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you MUST use the filter for 62-65 with 2 feed holes NOT 66 and later
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094109
10/20/11 10:47 AM
10/20/11 10:47 AM
Central New York
bfury Offline
bfury  Offline
Central New York
I also had the same problem with the filter, you can cut the second hole in the filter and it will work. As far as the shift cable adjustment, I pushed the neutral pb in and then adjusted the cable so that the neutral safety switch was depressed and all worked fine.
Now where do you buy that tee shirt?
No Stock
Re: 64 pushbutton trans need help! [Re: bfury] #1094110
10/22/11 12:54 PM
10/22/11 12:54 PM
N.Y.
N.Y.
Ok update! dropped pan,changed filter, watched as cable was shifted everything moved fine,worked fine etc.. put everything back together and nothing! buttons push in,they stay in,they change nice when you switch gears. zero zip! WHAT gives? How does it go from working one minute then nothing?
Re: 64 pushbutton trans need help! [Re: sixpacksteve] #1094111
10/22/11 02:46 PM
10/22/11 02:46 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
TIME ...for a line-pressure check.
Page 2 of 3 1 2 3
