Re: 64 pushbutton trans need help!
[Re: John_Kunkel]
#1094094
10/18/11 06:43 PM
10/18/11 06:43 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ok, this morning, dropped pan readjusted the cable. put everything back together . hit all the gears,GREAT! then later tested it again NOTHING it won't go into gear, stuck in neutral. i guess back to the drawing board.
Hell Hath No Fury Like Mine
[Re: sixpacksteve]
#1094097
10/18/11 07:05 PM
10/18/11 07:05 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
when i push the buttons it seems to shift, just nothing happens doesn't go into gear.
[Re: dOrk !]
#1094101
10/18/11 11:08 PM
10/18/11 11:08 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
yes,i had friend shift while i adjusted it. it was perfect. test drove it was fine.. then test drive again squat. i'm going to drop the pan again. something is not right with the cable. where would i get a new cable?
[Re: dOrk !]
#1094103
10/19/11 12:18 PM
10/19/11 12:18 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
If you've already done so my apologies for doubling up on this, but did you change the filter? I've had these plug up after sitting a long time. I'm in the middle of the same thing with a Coronet that sat for a long time. Got it running, tranny worked for a few tries and then nothing. Filter was plugged.
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#1094104
10/19/11 04:24 PM
10/19/11 04:24 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
no, i didn't try that. its raining but i'll change filter as i check cable position.
[Re: sixpacksteve]
#1094105
10/19/11 04:55 PM
10/19/11 04:55 PM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If in doubt about whether the cable is moving the roostercomb, just pull the NSS and you can observe the movement of the roostercomb.
[Re: John_Kunkel]
#1094106
10/19/11 06:05 PM
10/19/11 06:05 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ok john, forgive me but whats roostercable, and nss? thanks
[Re: sixpacksteve]
#1094107
10/19/11 07:38 PM
10/19/11 07:38 PM
John_Kunkel
Rio Linda, CA
The roostercomb is the internal shift lever that the spring-loaded ball sits in to make shift detents, NSS is Neutral Safety Switch.
[Re: sixpacksteve]
#1094109
10/20/11 10:47 AM
10/20/11 10:47 AM
Posts: 404 Central New York
bfury
Central New York
I also had the same problem with the filter, you can cut the second hole in the filter and it will work. As far as the shift cable adjustment, I pushed the neutral pb in and then adjusted the cable so that the neutral safety switch was depressed and all worked fine.
Now where do you buy that tee shirt?
No Stock
[Re: bfury]
#1094110
10/22/11 12:54 PM
10/22/11 12:54 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
Ok update! dropped pan,changed filter, watched as cable was shifted everything moved fine,worked fine etc.. put everything back together and nothing! buttons push in,they stay in,they change nice when you switch gears. zero zip! WHAT gives? How does it go from working one minute then nothing?
