Page 1 of 3 1 2 3
Carb Tuneing #1092732
10/11/11 03:20 PM
10/11/11 03:20 PM
Finally a HUSKER again
Moparnut426 Offline OP
Well I did some tuneing on the Demon this noon. First off, my secondary float was high, Like almost a full turn to get it back down to where is should be. 2nd, I had the idle adjustments off, and 3rd Ill have to set the timing down a smidge, it did a very slight diesel 1 time when I shut it down. I think Im at 34* now, Ill take it down to 32 or so and see how it acts.
I did notice the 408 never really reacted when I turned the idle screwes inn. Shouldnt it almost die whe the screwes are turned inn?
Could this mean my idle it soo high?
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092733
10/11/11 03:35 PM
10/11/11 03:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd probably turn the screws all the way in then back out 1.25 turns, then fire it up to 2400rpm set your timing, then back it down to 8-900 and set your mixtures and go from there. 34* seems like it would be low enough
Coming soon!!!!
Re: Carb Tuneing [Re: Mr.Yuck] #1092734
10/11/11 03:36 PM
10/11/11 03:36 PM
Ill try that. Couldnt hurt.
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092735
10/11/11 03:39 PM
10/11/11 03:39 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yes it should die when 1 is turned in, sounds like the transfer slots are too exsposed & its entering the main metering, in any case its getting too much fuel at "idle".
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Carb Tuneing [Re: joedust451] #1092736
10/11/11 03:53 PM
10/11/11 03:53 PM
So how do I adjust it out of that if its past the idle cuircut
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092737
10/11/11 05:15 PM
10/11/11 05:15 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
set the transfer slots for both pri and secondary then start the engine. to adjust idle rpm, use your timing and not the screw on the side to raise and lower your idle rpm. adjust AF screws. readjust timing. recurve dist. done
if you have a msd dist, i dont think you can recurve easy like a mopar one because they suck
Re: Carb Tuneing [Re: sixpackgut] #1092738
10/11/11 06:28 PM
10/11/11 06:28 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
MSD dist. suck , Don't know which one you say is hard to dial in . I loved mine on my SB, i'll NEVER use a MP dizzy again, there a big PITA IMO with sloppy shafts too boot.
This is the one i use & its simple/simple/simple, just need an aftermarket box, but who cares everyone gets them anyways, The MP boxes suck, at least the orange units.
http://www.jegs.com/i/MSD+Ignition/121/8534/10002/-1
Re: Carb Tuneing [Re: Moparnut426] #1092739
10/11/11 06:38 PM
10/11/11 06:38 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Kasey
Square up the transfer slots on the primaries, even if its 4 corner idle the rear ones sit higher on the base, so you may never exspose them unless you open the butterflies more then the primaries, so start off with squareing up the front slots, then find out how far you needed to turn on the throttle screw to reach it, then open up the secondaries as much as the front, so if your primary throttle screw is 1.1/2 turns from fully seated, then set the back at 1.1/2 turns, then set all mix screws at 1.1/4 open, fire it up, make sure float level is good, set timing for highest manifold vacuum, then tailer in the mix screws & throttle shafts to obtain the best idle & the RPM where you want it. Hope this makes sence.
Re: Carb Tuneing [Re: joedust451] #1092740
10/11/11 10:26 PM
10/11/11 10:26 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
make sure the secondary idle is closed or it will pull fuel from there and the mixture screws will not kill the engine.
Re: Carb Tuneing [Re: 440charger500] #1092741
10/11/11 11:01 PM
10/11/11 11:01 PM
Well I did all that and the idle screws are only about 1/4 to 1/2 out, and it dosnt die with them screwed inn. Do i need different idle air bleeds?
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092742
10/11/11 11:09 PM
10/11/11 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
Did you have the transfer slots squared before you
tried to turn in the mixture screws... if they were
open to much you werent on the idle circuit
Re: Carb Tuneing [Re: MR_P_BODY] #1092743
10/11/11 11:12 PM
10/11/11 11:12 PM
Kasey
yes, I turned the carb over, squared up the slots, was pretty close to closed, wasnt opened very far at all, and I tuned it from there. still didnt die out after screwing them inn.
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092744
10/11/11 11:45 PM
10/11/11 11:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the mixture screws and blow out the ports with
a air nozzle/blow gun then try it again
Re: Carb Tuneing [Re: Moparnut426] #1092745
10/11/11 11:53 PM
10/11/11 11:53 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Kasey
Kasey
fuel is getting in the motor from somewhere. if it was me, i would take the carb off, completely drain it and blow air into the little hole under the throttle blades and see if you feel air comming out the airbleeds with the mixture screw all the way in or its getting alot of fuel out of the transfer slot.
check to make sure you dont have a blown PV also
Re: Carb Tuneing [Re: Moparnut426] #1092746
10/12/11 12:01 AM
10/12/11 12:01 AM
Az
Crizila Offline
Crizila  Offline
Az
I had similar issues with my 750 mighty demon with "idle-Eze". 1. Try dropping the float levels a little more. 2. Make sure the idle air bleeds ( outers ) are the correct size. Mine were supposed to be .070" per the spec. Actually mic'ed .067". When I corrected that, I could kill the motor ( barely ) when I turned the mixture screws all the way in. Idled best with the mixture screws 1/2 turn out. BTW, you only want to "square" the transfer slots on the primary side. Secondary butterflies should be set to the bottom of the transfer slots ( not visible from the underside at idle. If you have "idle-eze", base line it at 1 1/2 turns out.
Fastest 300
Re: Carb Tuneing [Re: sixpackgut] #1092747
10/12/11 12:01 AM
10/12/11 12:01 AM
Kasey
Kasey
Ill do that again. I have a new PV inn it. Ill check to make sure they are clear.
Kasey
Re: Carb Tuneing [Re: Crizila] #1092748
10/12/11 12:04 AM
10/12/11 12:04 AM
Ive done this, and also have 70s on the idle air bleeds.
The screws are about 1/2 out now but wont kill it off. Heres a thought just popped inn my head. Is it suposed to die individually, or when all of them are screwed all the way inn.
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092749
10/12/11 01:09 AM
10/12/11 01:09 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hey Casey
Does it have a idle speed screw on the back throttle shaft, most 4150's dont but some HP series do. Some you can adjust with the carb off on the bottom side of the base with a small set screw. You can turn it in a 1/2 turn or so. This will help give the engine some extra air without being so much in the front transfer slots. Thats why you see lots of old holley out there at the swap meets that have holes drilled in the butter flies. If you dont care to do this, this still might be a option, you can get replacement butter flies cheap if you want to go back so..
Make sure the floats are close, back the idle speed screw all the way out, then turn the idle mixture screws out about 1 1/2 to 1 3/4 turns from a light seat. This is probably hair fat but should provide a base line to adjust from. Turn the idle speed screw in to it just touches the cam, then turn in 1/2 turn see if it will idle, if it wont turn it in another 1/4 turn and try again.
Re: Carb Tuneing [Re: Bob_Coomer] #1092750
10/12/11 09:57 AM
10/12/11 09:57 AM
There isnt a screw on the back throttle blades, but there id a stop. I was thinking I may tweek that stop and get the rears to open a bit more.
Kasey
Re: Carb Tuneing [Re: Moparnut426] #1092751
10/12/11 10:15 AM
10/12/11 10:15 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Kasey, what carb do you have? I have a Quick Fuel Q-750 that I had to drill the primaries to clean up the idle. I tried larger idle air bleeds, adjusting the idle screw on the secondaries and timing, but the thing that helped the most was drilling holes in the primaries. I'd only do this as a last resort.
BTW, in my experience if the secondary idle is opened to far the engine will surge at cruise speed.
You should be able to kill it with one air mixture screw.
Page 1 of 3 1 2 3
