IF you on doing-it on-the-ground ... trans-jacks make it more of a PITA ...PLUS you have to get the car WAY UP higher.
First ....make sure you have good jacks stands and they are stable. Then uNless you are a small guy ... just hump-it up-and-down on your back putting it on your chest.
really? i would not trust jacks in the dirt.plus you would have to have the car up so high .anyway be safe.
"GROUND" ... I should have said(and I meant) CONCRETE ... garage ....driveway ..
