Re: A matter of opinion: resto cost [Re: sixpackbee] #1089411
10/06/11 08:21 PM
10/06/11 08:21 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
all depends on what kind of car it is if its a 1970 duster you will have $$ left over, if its a 1969 charger r/t you will be in the hole, unless its nice car to start with
MOPAR OR NO CAR
Re: A matter of opinion: resto cost [Re: ademon] #1089412
10/06/11 08:53 PM
10/06/11 08:53 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Finding the carb and having it replated and rebuilt will cost $500 if your going to do it right, and thats just a run of the mill AVS
$325
Re: A matter of opinion: resto cost [Re: JohnRR] #1089413
10/06/11 09:28 PM
10/06/11 09:28 PM
Warrenton, VA
Warrenton, VA
$500 labor on the engine ??? 3275 for parts ??? What about machining costs ?
$35k may not be too far off but it should be understood that it is just an estimate. I would not guarantee the total cost of a job like that. I would charge him your hourly rates and bill your hours and costs on parts and material weekly and let him pay as you go. He would have to trust you to keep accurate track of your hours and can't argue too much about costs of materials and parts. Let him make the decisions as to what parts to restore or replace. It's bound to add up to more than you can estimate and your customer could not get more fair of a deal.
Re: A matter of opinion: resto cost [Re: RoadRunnerJD] #1089414
10/06/11 09:37 PM
10/06/11 09:37 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
$325
is that with the carb? or just the replate/rebuild? he's missing the carb.
Re: A matter of opinion: resto cost [Re: ademon] #1089415
10/06/11 10:08 PM
10/06/11 10:08 PM
Warrenton, VA
Warrenton, VA
$325
You're right! My mistake! That's just the carb resto. A decent complete carb will be from $100-$200. $500 is a good estimate. I have $470 in my AVS.
Re: A matter of opinion: resto cost [Re: sixpackbee] #1089416
10/06/11 10:16 PM
10/06/11 10:16 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
this the one you emailed me about?
Yes it is. Keep it quiet though. Needs both quarters, wheelhouses, trunk floor, main floor, trunk extensions, and some inner fender work by the battery. Will be using AMD stuff for ease of availability.
Keep in mind that even though you are planning to use the AMD products, which are probably the best out there, they will probably not fit perfectly. My AMD quarters required quite a bit of massaging around the rear window area and at the tail light extensions. Mine was a '69 RR.
Re: A matter of opinion: resto cost [Re: Mopar Grandpa] #1089417
10/07/11 02:09 AM
10/07/11 02:09 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've have built cars for myself for under 10k. I did a 70 roadrunner for 4k. That was using a lot of parts I have from parts cars, some trading, and not being concerned if for exapmle the bumpers and other chrome parts were perfect. Also reusing door panels, like if the vinyl was good, gluing on to boards I cut myself and so on. I did the 4k roadrunner in less than 4 months at maybe 20 hours a week for 3 of the 4 months. I didn't do the underside on that one.
For someone elses car, if a lower end resto, I mean, not everything redone or to factory original. Done to be a nice driver, needing panels, I still think your looking at 10k for parts alone on the low end. That would be using the low line of paints like nason or omni. So if your charging 25 an hours, that gets you to your estimate. However I'd be prepared to work some hours for free cause chances are 1000 hours won't cut it on a rusty car.
Now I'm assuming when you say resto, your talking a complete resto, underside and all. Now if your just doing a topside, suspension, brakes, etc... then 35k is actually pretty decent in my eyes to make. I got about a 3rd of that for a car I did last year that was a rotiserrie done car, but didn't need any interior work, engine/trans and the owner did the front suspension himself. Also pretty rust free and straight.
Re: A matter of opinion: resto cost [Re: Silver70] #1089418
10/07/11 09:14 AM
10/07/11 09:14 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Sounds like a bargain. If I ever have to buy a car, I will go to a major auction and buy the right finished car.
Re: A matter of opinion: resto cost [Re: sixpackbee] #1089419
10/07/11 09:40 AM
10/07/11 09:40 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
Resto work is time and materials. thats what it is. This is not a cheap hobby.some jobs cost more some less you ll find out when your done if you priced it right and only experance will help you for the future
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: A matter of opinion: resto cost [Re: yella71] #1089420
10/07/11 09:58 AM
10/07/11 09:58 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I would think $20k plus parts and subs would put you in a better position. That way if he decides the bumpers don't look quite good enough he coughs up the extra, not you. I know I had $17.5 in parts for a driver cuda, because the used stuff wouldn't look as good. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: A matter of opinion: resto cost [Re: DPelletier] #1089421
10/07/11 02:42 PM
10/07/11 02:42 PM
O
OLD318 Offline
OLD318  Offline
O
The body shop that did my '69 car had over 670 hours in it but the thing is dead straight. Paint materials, depending on the color, will probably cost you over $2,000 which includes primers, bondo, sandpaper, tape, etc., etc. I think you'll be surprised at the final cost.
I would be happy to send you the 11 page breakdown of my parts and labor charges. Just PM me with your e-mail address.
All that changes is the labor rate; we've all been saying that a proper resto will take 1000 hrs give or take and the part cost is the same no matter where you are.
Even if you charge yourself out at $20/hr and don't have to pay rent, insurance, taxes, upkeep, tool replacement, etc. etc. it is still going to break down something like this;
- parts & materials: $20,000
- farmed out component resto and specialty labor: $ 10,000
- 1000 hrs at $20/hr: 20,000
Total: $50,000
All I know is that I could have done ALL the labor by myself for free and I still would have spent more than your $35k budget. I would take the offer given above and take a look at a spreadsheet for a complete nut and bolt resto to make sure you haven't missed or underestimated significant items.
Do what you like, but I think you're making a big mistake and will be working for free. If we could all get quality resto work done where you live for 1/3rd the going rate, we'd all be doing that.
OTOH, if you don't have any bills to pay, maybe it's a good idea to do this one and then you'll know for sure one way or the other.
Dave is absolutely right about the costs..And I'll bet his prices are circa 2005-2010...
The parts and materials alone to take even a complete 40+ year old
mopar B or E body from rags to really sweet driver will cost you
upwards of 40K... Thats just parts and materials only...
If there is stuff you are not gonna do...
then yes, you can subtract from that.
Perhaps the biggest pitfall in restoration is this:
Once you have one part of the car looking all shiny new..
the old stuff really sticks out...
So you get stuck very quickly trying to make everything look new..
That is a very time-consuming and expensive proposition...
For example, what about all the chrome?
You think you can get that done for $500? Not a chance...
Nuts and bolts?
You gonna use those old bolts on your new freshly painted engine?
or are you buy shiny new ones? Easily $500 - $1000 just for nuts /bolts and hardware...
Wanna blast and refinish them yourself? You can try that..good luck!
What about shipping costs for new parts?
For the 100's of parts you absolutely have to replace
the shipping costs alone will add up to 100's of dollars if not
a thousand or more...
FWIW, let me implore you, Dave is not lying to you!
Having been there and done it myself I can honestly look in the
mirror and say this:
For the time, effort, and cost in most cases, if you want a restored car, the average person is way better off buying one already done as close as you can get to what you want, then going through the cost, hassle and aggrevation of doing one yourself or paying someone to do
one from scratch..
Obviously, for some people and some cars (R/T, superbee, gtx etc)
this doesn't apply... but for most people and situations I think it does.
Most are for sale for half of what it would cost to do one yourself.
For example: Once in a while, I see some really nice Chargers/Coronets/ etc. on ebay for 25-35K...
Having been there and done it, there is no way I could take a projct car and get it to that condition for that price..
Plus all the time and aggrevation...
In the end, anybody can work for free...
Heck, you can do easy desk work for $10.00 hour...
Why would you kill yourself on an old car for that?
Your lungs (from all the dust and overspray alone)
are worth alot more than that..
Re: A matter of opinion: resto cost [Re: sixpackbee] #1089422
10/07/11 03:04 PM
10/07/11 03:04 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO you way under bid this one.
I rebuilt my 71 challenger completely. It needed no sheet metal, it was rust free. I kept detailed records and all reciepts. I have 40K into it with me doing 99.9% of the work myself. I busted my azz to get it done. I wouldn't do the labor for anything less than 20K.
I think your 20 under where you need to be, plus you have rust!!!
Re: A matter of opinion: resto cost [Re: Challenger 1] #1089423
10/07/11 03:51 PM
10/07/11 03:51 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I agree with you guys above, I do think he priced it too low. But like I mentioned, depending on the extent of it, there still could be room for a nice profit, although it could be a lot more.
I've done nice driver cars for people and then when done they thought this or that should have been done or expected show worthy for driver resto cost. So I think your communication will be key.
Say there 15-20k to be made in labor over 4-6 months. To me thats decent money. I had jobs I worked a year made that kind of money. Not everyone is out to get rich. I could charge double of what I do or more, but that scares away a lot of business and I look at it this way: I get to do something I love and work when I want. To some that means way more than the money made.
Re: A matter of opinion: resto cost [Re: RoadRunnerJD] #1089424
10/07/11 04:22 PM
10/07/11 04:22 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
I say you're foot is bleeding.
I don't have time to give you a complete breakdown, but $35k wouldn't cover the cost of parts and the drivetrain in my case.
I have over $100k in my resto, but my car was missing lots of stuff which significantly added to the cost. If it was together and complete, I probably could have saved $20 - $30k. Also, I spent good money on many repop parts that weren't good enough to use and also I bought quite a few spares.
Bottom line is that I spent $50k on metal work, body work, paint, panel alignment and body reassembly. Shop had over 600 hours charged to the car which I have every reason to believe is accurate. At a pretty cheap charge out rate of $50/hr that's $30,000 in labor alone. (If you want more detail on exactly what metal work was done and how many hours were spent, let me know and I'll dig it out.)
....then you can add in the engine, tranny, driveshaft, rear end, dash and gauges, interior, exhaust, suspension, etc. etc. Even the sub assy's that Jules did for me (steering column, wiper motor and linkage, e-brake assy, heater box) added up to a fair chunk of change.
I just don't see how a quality rotisserie restoration by skilled workers can cost any less than $50 - $60k.....heck, lots of people have indicated that they have 1000 - 2000 hours in thier resto and even at the cheapest rates possible for a real and viable business, it simply adds up.
Hits nail squarly on head!
I'll add to that, it really doesn't matter which car you start with, average to restore ANYTHING to an equal level isn't all that different
Re: A matter of opinion: resto cost [Re: sixpackbee] #1089425
10/07/11 05:20 PM
10/07/11 05:20 PM
Sebring, Florida
Sebring, Florida
I hope you sincerely understand that those that have posted are trying to help you and not discourage you. Having said that if you have as much rust in this car as you indicated above I guarantee you you are going to find a lot more rust in areas that you can't see until you start removing the panels, floors, etc. Just make sure the owner understands you don't have x-ray vision. And if you don't address all of the rusty areas they will eventually raise their ugly little heads and the owner will be back to your shop for an unpleasant discussion. Dot your I's and cross you T's.
Re: A matter of opinion: resto cost [Re: Mopar Grandpa] #1089426
10/07/11 05:31 PM
10/07/11 05:31 PM
Western New York
sixpackbee Offline OP
Western New York
I appreciate the concerns. I have been restoring North East rusted junk for over 30 years now. I have seen it all rust wise. I think I am OK on this. I do not need to make a ton to come out alright. The car has an interesting family tie that makes doing it a moral imparative. Or at least a fun story to tell.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: A matter of opinion: resto cost [Re: sixpackbee] #1089427
10/07/11 11:58 PM
10/07/11 11:58 PM
Caledon, Ontario
smac77 Offline
smac77  Offline
Caledon, Ontario
I rarely get a complete job to do. Mostly do total body/paint and customers assemble. Get quite a few engines/trans too. I have one coming in. Total job. The car is very complete and original. Needs only a carb to be found. Needs complete rear body panels and floor. No frame work needed. Underside will be done in primer type deatil. Total interior redo, seat covers ect. Engine will be done all new and slightly internally warmed over. Rebuild trans. Rear gear swap and rebuild. Suspension redo and powder coated.
In short the car comes to me as it is. Not running and rusty. It gets delivered back in very, very nice driver quality, no paint daubs, overpray type details, turn key style. I came up with just north of 35,000 parts and labor. Opinions: is he going to take a swing at me or is my foot bleeding from a self inflicted injury?
you'll be ok north of $35k as long as you aren't on the hook for all the parts... I'd quote him less on labour based on a set amount of work plus parts and materials... any surprises are extra. You have no way of knowing what will and will not work, break or just plain be unusable after 40 years of neglect until you get it removed and in your hands. The worst thing any restorer can do is get themselves in a position where they are trying to cut corners to make a flat rate. The work you've been doing to date (body and paint for customer to assemble) is the easy part to quote. It's the little bits and peices that kill you...
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
