Re: Front Suspension Rebuild Kit....Again... [Re: roe] #1089259
10/09/11 05:59 PM
10/09/11 05:59 PM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
http://www.performancesuspension.com/pro...roducts_id=5918
Why don't you try this set? Its a polygraphite rebuild kit and is pretty complete. Its $290.00 plus you get a 10% discount (roughly makes it $260.00) plus free shipping. Im going this way for my superbee and previously when I posted about this company nobody gave me any static about them.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Front Suspension Rebuild Kit....Again... [Re: TX9H6E4CUDA] #1089260
10/09/11 06:14 PM
10/09/11 06:14 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I hadn't heard of these guys, but they look like a really good deal. Much more affordable, and leaves me money left over for other mods.
Thanks for the link
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Front Suspension Rebuild Kit....Again... [Re: roe] #1089261
10/09/11 08:24 PM
10/09/11 08:24 PM
MN
astrobuf Offline
astrobuf  Offline
MN
I'd advise skipping it.
I just completed a front end rebuild. All Moog bought from Rock Auto. You can't beat the quality and I've heard too many unflattering comments on most all of the non Moog stuff people have tried.
This is an immense amount of work. Don't skimp, you're going to have way too many hours in this job to do it half way.
Don't forget the tools you are going to need to pull stuff apart. Get em at Mancini's.
Astrobuf
So, are you really a Rocket Scientist?
Re: Front Suspension Rebuild Kit....Again... [Re: astrobuf] #1089262
10/09/11 08:29 PM
10/09/11 08:29 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I did 2 B body cars with kits from ESPO. All stuff was U.S. made with a good price. I would run rubber in the lower control arm torsion pivit area unless you like squeaks.
Re: Front Suspension Rebuild Kit....Again... [Re: rapom] #1089263
10/09/11 10:03 PM
10/09/11 10:03 PM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
When I posted about about this place they used energy suspension bushings.
I would never run rubber bushing again, especially after the issues with modern day rubber. The whole "squeak" issue is from improper installation (need to be lubricanted with silicon type of lubricant). I know tons of old cars (gm, ford, mopar) that run poly bushings and they don't have the squeak issue because they were properly installed and lubricated.
Re: Front Suspension Rebuild Kit....Again... [Re: TX9H6E4CUDA] #1089264
10/10/11 07:10 AM
10/10/11 07:10 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Second that. Used the kit you mentioned and it works great. Energy suspension bushings, McQuay idler arm, tie rods were BAW. BAW? a taiwanese company...well, before some guys cry out: main customer of BAW is Federal Mogul...
reference: http://www.alibaba.com/member/baw1057.html
Anyways, I'm happy with the kit and I don't have any squeaks (lubed the bushings with the supplied teflon grease).
Re: Front Suspension Rebuild Kit....Again... [Re: JohnRR] #1089265
10/10/11 07:26 AM
10/10/11 07:26 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I just bought the 4 ball joints, 4 rod ends and the idler arm from NAPA for 236.00 This for a 70E. Had it all in stock. I'm told that Moog makes the NAPA stuff.?
Was all made in US.
What was made in USA the parts or the BOX , that is something NAPA has done , Made in USA on the box , whatever inside said made elsewhere ...
Obviously not all is made outside the US but I've always boughtthe good name brand parts whenever I can , lately it's been made in china , the sad part is it is still priced like it was made here , Wagner rotors ...
Exactly! A a pair of moog tie rod ends for The POS Dakota cost me 130 bucks!
Re: Front Suspension Rebuild Kit....Again... [Re: TX9H6E4CUDA] #1089266
10/10/11 07:28 AM
10/10/11 07:28 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
They come with the grease to install them. I dont know why people dont use it.
Re: Front Suspension Rebuild Kit....Again... [Re: TX9H6E4CUDA] #1089267
10/17/11 06:11 PM
10/17/11 06:11 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Well I went ahead and picked up this kit. I liked everthing that I saw and heard about it. Cant wait to get back and get to knock out this front end rebuild. $261 shipped!!! Now all I need is a new pitman arm and all replaceable parts will be accounted for.
