Re: 1970 GTX
[Re: PasiR]
#1087485
10/14/12 02:52 PM
10/14/12 02:52 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Transmission back home. Paint & detailing needed. Detailing tips & pics needed.
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W2-8bbl
Re: 1970 GTX
[Re: ArcticCuda]
#1087486
10/20/12 12:07 PM
10/20/12 12:07 PM
Posts: 597 Lost in the 70's
440gtx6
Lost in the 70's
Very nice GTX. All numbers matching including engine? Noticed the blue valve covers on earlier post so was wondering if the car had the original engine block? Keep the pictures coming!
69 EF8 GTX 440 auto 72 EB5 RR/GTX 440 auto 70 EW1 GTX 440-6 4 spd 70 EF8 Satellite 318 auto (452 coming soon) 70 FK5 Satellite 318 auto 71 FC7 Cuda 340 4 spd
Re: 1970 GTX
[Re: 440gtx6]
#1087487
10/21/12 05:44 PM
10/21/12 05:44 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Unfortunately original engine was shot already 1971. Blue one is 383. I have got 1969 440 warranty block and I'm gonna use it.
Re: 1970 GTX
[Re: ArcticCuda]
#1087488
10/21/12 05:48 PM
10/21/12 05:48 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Started front suspension rebuilding. Lots of work needed.
Re: 1970 GTX
[Re: ArcticCuda]
#1087489
10/29/12 09:31 AM
10/29/12 09:31 AM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
After 17 hours of sand blasting & wire brushing. Next...time for new bushings, paint & plating.
Re: 1970 GTX
[Re: ArcticCuda]
#1087490
11/09/12 11:56 AM
11/09/12 11:56 AM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Right door after sodablasting, wash and sanding. Clean and nice. Zero rust and only few minor dings.
My bodyshop needs this. That's why I did this in the middle of front end rebuilding.
Re: 1970 GTX
[Re: ArcticCuda]
#1087491
11/09/12 12:18 PM
11/09/12 12:18 PM
Posts: 1,106 Northeast
VincentVega
Northeast
hey, Arctic... I've done similar work, in fact I blasted the entire front suspension on my Fury, including KFrame.
I was just curious - what is your post-blasting cleanup technique? I always have a ton of sand dust on the parts, and I've never felt like I've been able to get all that dust off before primer. I'd love to hear what you do.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 1970 GTX
[Re: VincentVega]
#1087492
11/09/12 06:47 PM
11/09/12 06:47 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Hi. I'm using both sodablasting and sandblasting. Sodablasting for sheetmetal, sand blasting for "heavier" parts like K-frame. Check out for example my bolts and nuts; They are sandblasted (veryveryvery light sand) and after that wirebrushed using brass wire. After that lots of air and for some parts solvent.
Re: 1970 GTX
[Re: mopar383]
#1087494
12/06/12 12:37 PM
12/06/12 12:37 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Citric acid. Great stuff for rust removing. Calipers are like new both inside and outside.
Re: 1970 GTX
[Re: ArcticCuda]
#1087495
12/06/12 12:47 PM
12/06/12 12:47 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Calipers. Just new hardware kit and paint needed.
Re: 1970 GTX
[Re: ArcticCuda]
#1087496
12/06/12 12:50 PM
12/06/12 12:50 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
K-frame. Sandblasted, re-welded, sandblasted and finished. Tomorrow some semi gloss black paint and it's ready for assembly.
Re: 1970 GTX
[Re: ArcticCuda]
#1087500
12/09/12 05:18 PM
12/09/12 05:18 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Couple of pictures after long weekend. Thank you my FRIEND Kalle!!
