Re: tranzact valve body
[Re: AAR-B4]
#1086175
10/01/11 01:08 PM
10/01/11 01:08 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I have run several of there Trans Brake VB's. Both there Pro Brake(Hold button to activate R) and there Pro street brakes. They are top notch, this question gets asked on here every so often, and never read a single bad report on there stuff. Joe is good people too.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1086178
10/01/11 09:23 PM
10/01/11 09:23 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Yeah I'm buying a clean neutral VB from him as soon as I have the funds. Times is tough right now.
[Re: Guitar Jones]
#1086179
10/01/11 10:07 PM
10/01/11 10:07 PM
Posts: 327 wisconsin
mod381
wisconsin
It is everywhere and his valve body is 100 cheaper than all the other ones,that is why I am asking. It seems every time I use the cheaper stuff I get burned from it.
[Re: mod381]
#1086180
10/01/11 10:17 PM
10/01/11 10:17 PM
Posts: 99 Louisville, KY
Allan_G
Louisville, KY
I run that MVB w/ low band apply. Works great. The only problem I had, and I relayed this to Joe after purchase, was that most of the screws were loose. Just make sure they're tight. This was roughly 8 years ago. -Allan
(FKA Racer Al back in 2000...)
[Re: Allan_G]
#1086181
10/01/11 10:19 PM
10/01/11 10:19 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I got two of his pro transbrakes..never had a problem with them...
just ordered another brake a couple of weeks ago...
Joe is a very nice to chat with too...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: mod381]
#1086182
10/01/11 10:40 PM
10/01/11 10:40 PM
Guitar Jones
I totally understand where you're coming from. I've been burned by cheaper stuff too but like you, if I do my research I find I can save a few bucks and still get a quality product that's up to the job.
[Re: 70AARcuda]
#1086183
10/01/11 10:42 PM
10/01/11 10:42 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I bought one that would hang up the 2-3 shift REAL bad. Turns out it was cracked --they did send a new one though..... but only after 3 MONTHS of "try this...try that " , when I told joe my trans was not the problem--it was fresh . He is a Nice guy -- but it was nearly impossible to get anyone in that place to answer the phone over 3 months. Extremely frustrating ! I would buy stuff from them again ONLY IF THEY HIRE SOMEONE TO SIT THERE AND ANSWER THE PHONE DAILY.
[Re: steeldust]
#1086187
10/02/11 01:50 PM
10/02/11 01:50 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I have run Turbo Action, slow releasing transbrake in comparison and required a stock filter to not have trouble with the small soleniod.
I have ran a couple Tranzact VB's. Better lights picked up a considerable ET improvement with the 2-3 shift.
Was pissed at Joe over something totally irrellevant and bought a A&A. Won a race toasting high gear clutches. Changed several things that Rick suggested. After several rebuilds including replacing a good case. I borrowed a Tranzact and had no problems. Rick suggested I still had tranny troubles. Never once offered to just send me a replacement VB with a return shipping on the bad one clause. I caved sense all my expensive drums were burned up and switched to a glide.
Seems things are common with the torqueflite performance parts manufacturers. Like hard to reach, hard to get warranty service. I have had trouble with Tranzact not having the neutral safety plastic on the VB and had to find my own a couple times. THIS SAID IF AND WHEN I NEED ANOTHER TORQUEFLITE VB I WILL CALL 317-846-4933 AND TALK TO JOE AT TRANZACT. His valve bodies win rounds at the track and will repeat the following weekend.
Leon
