tranzact valve body #1086173
10/01/11 01:38 AM
10/01/11 01:38 AM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Can you tell me any good or bad about tranzact valve bodies? I am looking at a manual valve body with low band apply. The price on it is good but i have not heard much about them,any experience with them would be helpfull. Thanks
Re: tranzact valve body [Re: mod381] #1086174
10/01/11 07:30 AM
10/01/11 07:30 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
I can't speak for the manual valve body but I bracket race with a 20 year old Trazact bracket trans brake vb. This is the external solenoid type and it has been very consistent and reliable.
Re: tranzact valve body [Re: AAR-B4] #1086175
10/01/11 01:08 PM
10/01/11 01:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I have run several of there Trans Brake VB's. Both there Pro Brake(Hold button to activate R) and there Pro street brakes.
They are top notch, this question gets asked on here every so often, and never read a single bad report on there stuff.
Joe is good people too.
Re: tranzact valve body [Re: Bob_Coomer] #1086176
10/01/11 03:46 PM
10/01/11 03:46 PM
mo
ALKYW5DART Offline
ALKYW5DART  Offline
mo
BOUGHT HIS 727 TRANS WITH BRAKE FOR 1500.00 BEST THING I EVER DID
Re: tranzact valve body [Re: ALKYW5DART] #1086177
10/01/11 06:36 PM
10/01/11 06:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have his protree trans with alum drum. But no hits on it yet
Re: tranzact valve body [Re: Bob_Coomer] #1086178
10/01/11 09:23 PM
10/01/11 09:23 PM
Guitar Jones Offline
Yeah I'm buying a clean neutral VB from him as soon as I have the funds. Times is tough right now.
Re: tranzact valve body [Re: Guitar Jones] #1086179
10/01/11 10:07 PM
10/01/11 10:07 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
It is everywhere and his valve body is 100 cheaper than all the other ones,that is why I am asking. It seems every time I use the cheaper stuff I get burned from it.
Re: tranzact valve body [Re: mod381] #1086180
10/01/11 10:17 PM
10/01/11 10:17 PM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
I run that MVB w/ low band apply. Works great. The only problem I had, and I relayed this to Joe after purchase, was that most of the screws were loose. Just make sure they're tight. This was roughly 8 years ago.
-Allan
(FKA Racer Al back in 2000...)
Re: tranzact valve body [Re: Allan_G] #1086181
10/01/11 10:19 PM
10/01/11 10:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I got two of his pro transbrakes..never had a problem with them...
just ordered another brake a couple of weeks ago...
Joe is a very nice to chat with too...
Tony
70 AARCuda Vitamin C
Re: tranzact valve body [Re: mod381] #1086182
10/01/11 10:40 PM
10/01/11 10:40 PM
I totally understand where you're coming from. I've been burned by cheaper stuff too but like you, if I do my research I find I can save a few bucks and still get a quality product that's up to the job.
Re: tranzact valve body [Re: 70AARcuda] #1086183
10/01/11 10:42 PM
10/01/11 10:42 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I bought one that would hang up the 2-3 shift REAL bad. Turns out it was cracked --they did send a new one though..... but only after 3 MONTHS of "try this...try that " , when I told joe my trans was not the problem--it was fresh .
He is a Nice guy -- but it was nearly impossible to get anyone in that place to answer the phone over 3 months. Extremely frustrating !
I would buy stuff from them again ONLY IF THEY HIRE SOMEONE TO SIT THERE AND ANSWER THE PHONE DAILY.
Re: tranzact valve body [Re: 493_DART] #1086184
10/01/11 11:29 PM
10/01/11 11:29 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
My Transact Brake trans works well...well enough that I'm moving it from my SB Aspen to my BB Dakota project with a little help from JW ultrabell!
Re: tranzact valve body [Re: mod381] #1086185
10/02/11 12:32 PM
10/02/11 12:32 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
Tranzact pro-brake here.
Re: tranzact valve body [Re: MoparPitBull] #1086186
10/02/11 01:32 PM
10/02/11 01:32 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I run a brake in my roadrunner i raced for 15 years no trouble and now i have run a pro brake in my duster for 4 years tranzact is the only way to go . GOOD LUCK.
Re: tranzact valve body [Re: steeldust] #1086187
10/02/11 01:50 PM
10/02/11 01:50 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have run Turbo Action, slow releasing transbrake in comparison and required a stock filter to not have trouble with the small soleniod.
I have ran a couple Tranzact VB's. Better lights picked up a considerable ET improvement with the 2-3 shift.
Was pissed at Joe over something totally irrellevant and bought a A&A. Won a race toasting high gear clutches. Changed several things that Rick suggested. After several rebuilds including replacing a good case. I borrowed a Tranzact and had no problems. Rick suggested I still had tranny troubles. Never once offered to just send me a replacement VB with a return shipping on the bad one clause. I caved sense all my expensive drums were burned up and switched to a glide.
Seems things are common with the torqueflite performance parts manufacturers. Like hard to reach, hard to get warranty service. I have had trouble with Tranzact not having the neutral safety plastic on the VB and had to find my own a couple times. THIS SAID IF AND WHEN I NEED ANOTHER TORQUEFLITE VB I WILL CALL 317-846-4933 AND TALK TO JOE AT TRANZACT. His valve bodies win rounds at the track and will repeat the following weekend.
Leon
