Re: Front Disk Brake Conversion not working as expected
[Re: 1970440RT]
#1084412
09/29/11 07:45 AM
09/29/11 07:45 AM
Posts: 18,165 Mass
DAYCLONA
Mass
Typical disc brake conversion thread ...with the usual "problems" and misconceptions, a few of the responses are spot on, ..... I've done countless swaps over the decades using the 73 B body/ FMJ spindles, along with using the pin type caliper, on 66-70 B bodies, 70-4 E bodies, and the 71-2 B bodies, this family of cars are pretty much the same, with regards to sharing the same design/componets,....I've NEVER had an issue using the 73/FMJ "tall" spindle, no bumpsteer issues, or alignment problems, as some have proposed/theorize.... 1st problem, sounds like you have the calipers mounted rearward, if so you can relocate them to the front upward position, by swapping the spindles left to right/drivers to pass/pass to drivers, the spindle design is symetrical in regards to the spindle angle/position, all that changes is the calipers location from rear to upper front/forward, use the 70-72 calipers/hoses (pin type)....get rid of the DISTRIBUTION DRUM block and use the correct PROPRTIONING VALVE,...get rid of the adjustable PROPORTIONING VALVE, not needed in your application....use a 1" maximum bore DISC/DRUM master cylinder 70-72 B/E application, regarding the booster, the single diaphrams, drum or disc, are all 10 3/4 diaphrams, pretty much all the same....the pushrod to bore gap for the master cylinder/booster pushrod clearance should be no less than .060 (ideal) to a max of .100 ...simple guidelines, posting some pics of your current set-up, could help ID some prbplems/help Mike
[Re: DAYCLONA]
#1084413
09/29/11 08:20 AM
09/29/11 08:20 AM
Posts: 135 Pittsburgh, PA
1970440RT
Pittsburgh, PA
Mike
Thanks for the info Mike. I will get some parts in here for this weekend and report back the results.
[Re: hemi71x]
#1084415
09/29/11 10:24 AM
09/29/11 10:24 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Also the lower control arms on a 73 B body are the same as your 70 B body .
That's not true. The 73 B body lower control arm is different than a 1972 - 1962 B body LCA.
Didn't know that , what changed .
[Re: 69sixpackbee]
#1084416
09/29/11 10:29 AM
09/29/11 10:29 AM
JohnRR
A gulag near you.
Been there and done that....I had the exact same issue with another build. The PO had put on the 73-up spindles. I swapped in the A body ones and it was solved.
Can you explain what your problem was and how it was solved? The caliper mounts in the same place on the spindle, the spindle is just 3/8" taller at the top.
[Re: JohnRR]
#1084417
09/29/11 10:38 AM
09/29/11 10:38 AM
moparpollack
Lil Herman
Lil Herman
85086
73 was the first year of the bubber isolated K member.
[Re: moparpollack]
#1084419
09/29/11 02:59 PM
09/29/11 02:59 PM
JohnRR
A gulag near you.
That I know , what does the LCA look like though ?
[Re: JohnRR]
#1084420
09/29/11 03:16 PM
09/29/11 03:16 PM
Posts: 12,521 Western Colorado High Desert
moparmarks
Everything.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1084421
09/29/11 03:17 PM
09/29/11 03:17 PM
JohnRR
A gulag near you.
Everything.
WOW not even close
[Re: 1970440RT]
#1084422
09/29/11 03:24 PM
09/29/11 03:24 PM
Challenger 1
Cincinnati, Ohio
Well from the posts in this thread and some helpful pm's, I plan to buy a new disc brake proportioning block, lines, 70 Challenger calipers and hoses. I will retain the B spindles and switch sides so the caliper is front mounted. That should cure the interference issue and then I can tackle the lack of braking performance. Who knows, maybe by replacing all those parts, that problem may go away as well. We'll see...
Look for a used one(proportioning valve), imo. I've read on here about too many problems with new one's.
[Re: 1970440RT]
#1084424
09/29/11 11:14 PM
09/29/11 11:14 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Lots to wade thru here....so I'll just make a few points.
It sounds like he has the drum Tee with an adjustable valve in the rear line. That's all you need...ever. BUT, its possible he has the valve plumbed in BACKWARDS, that'd give the symptoms he describes.
I'm not much on power boosters, but the comments on drum booster runout on disc swaps (pedal pressure skyrocketing) are well taken.
Reversing the caliper mountings from OEM prevents the flex line from crossing the steering axis (unless you move the hardline and frame bracket) and can be real dangerous (hose goes taut, abrades, etc.)
Gotta run...
Rick
[Re: 05dakota]
#1084425
09/30/11 08:22 AM
09/30/11 08:22 AM
Posts: 4,882 Florida
BDW
ON MY 70 challenger, originally drums, i have the 73a body set up using the stock distribution block and an adjustable valve in the rear line. works exactly the same as my 74 cuda that has all stock disk brakes
Same here, I'd look into the plumbing or booster before spending money on a new proportioning valve. I actually didn't even add the adjustable valve on the rears, just changed over to the smaller 7/8" wheel cylinders.
[Re: 1970440RT]
#1084426
10/01/11 02:01 AM
10/01/11 02:01 AM
Posts: 27,558 So Cal
autoxcuda
So Cal
No. 70 Challenger calipers are pin mounted. So to run them you need pin type caliper adapters (used only) and pin hardware kit.
Sounds like you need 73-76 A-body slider calipers because of hose orientation?? Rick?
[Re: autoxcuda]
#1084429
10/01/11 07:52 AM
10/01/11 07:52 AM
Rick_Ehrenberg
Marlboro, NY, USA
Here's rear mounted pin calipers with braided banjo line. The line is just routed in U shaped down from the banjo fitting and upward to the body fitting.
The arrangement shown doesn't have the hose crossing the steering axis. This causes lots more twisting in the hose and mandates a very, very careful and thorough check for abrasion and "going taut" lock-to-lock, full jounce to full rebound, all combinations thereof. If the calipers must be rear hung for some reason, you are way better off moving the hardline and frame brackets to the front.
His original post led me to believe that he had pin-type calipers and they were front hung (he said LCA interference). Now he says he will move them to the front...so who knows?
Using the taller late-B knuckles may improve the camber pattern a small amount but definitely TRIPLES the bumpsteer!
Rick
[Re: Rick_Ehrenberg]
#1084430
10/01/11 09:25 AM
10/01/11 09:25 AM
Posts: 9,982 MI, usa
dvw
MI, usa
Rick [/quote
My knowledge of bump steer is this. You need to form a parallelogram with these 4 points. The lower control arm pivot. The inner tie rod pivot. The lower ball joint pivot. And the outer tie rod pivot. Can you explain how raising the upper ball joint pivot affects this? I don't see it. Doug
