79 newport disc brake questions #1083224
09/26/11 08:54 PM
09/26/11 08:54 PM
mopar country
O
omnicrazy Offline OP
O
mopar country
Will the spindles, rotors and calipers from a 79 Newport fit an a-body?
Re: 79 newport disc brake questions [Re: omnicrazy] #1083225
09/26/11 09:33 PM
09/26/11 09:33 PM
the upper ball joint taper dia is larger on the C body so the spindle top tapered hole would be too big as is. Way back a C body UBJ has been grafted onto an A body UCA. Dont remember how they solved the spindle lower mounting bolts/lower ball joint difference on the lower end but it was not difficult. If you solved the upper prob I think mocking up the lower end would make the solution to that part probably pretty easy to figure out
Re: 79 newport disc brake questions [Re: RapidRobert] #1083226
09/26/11 09:39 PM
09/26/11 09:39 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
a 79 Newport is an R body, which is the same as the late B's so yes the brakes will work on an A body. Provided you use the late A body upper control arm with the larger ball joint.
Re: 79 newport disc brake questions [Re: omnicrazy] #1083227
09/26/11 10:14 PM
09/26/11 10:14 PM
AndyF Offline
AndyF  Offline
Spindles and rotors fit, calipers aren't a good idea because the hose routing will be wrong. Get the correct caliper for the application and you should be fine.
Re: 79 newport disc brake questions [Re: AndyF] #1083228
09/26/11 11:19 PM
09/26/11 11:19 PM
oops my mistake I thought that stuff was C body
Re: 79 newport disc brake questions [Re: RapidRobert] #1083229
09/27/11 12:39 AM
09/27/11 12:39 AM
AndyF Offline
AndyF  Offline
The marketing guys at Chrysler went brain dead in the late 70's and badged a bunch of cars in silly ways. It is confusing trying to keep the names straight.
