Page 2 of 4 1 2 3 4
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: topside] #1081848
09/25/11 02:03 PM
09/25/11 02:03 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Yeah, that's kind of a good news/bad news deal. Now you have me thinking about a Dana for my wagon...as in "do it once and do it bulletproof".
Only way to go is a Dana.Install it and forget about it.
Nautilus Racing-
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: Chris2581] #1081849
09/25/11 02:18 PM
09/25/11 02:18 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
My engine must be a POS... I never broke my 8 3/4 yet....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: DemonDust] #1081850
09/25/11 02:32 PM
09/25/11 02:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had over 600 passes on a stock 489 till it spit the
caps off, thats when I changed over to the alum center
but again its a light car
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: MR_P_BODY] #1081851
09/25/11 02:42 PM
09/25/11 02:42 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
What do you gain with the alum center?
I'm running a 742 case with 5.13, billet caps, spool and Cass's race axles. I've recently back braced it since the tubes were starting to twist.
SDG Motorsports
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: DemonDust] #1081852
09/25/11 02:48 PM
09/25/11 02:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The alum center is based on the 742 but its just
beefier and stronger... it has threw bolts(on 3 of
them) to hold the caps which are big... when I bought
mine they were reasonable on price and I got 35% off,
now days they're pretty pricey
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: MR_P_BODY] #1081853
09/25/11 02:51 PM
09/25/11 02:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup, if I remember right. A lot of strength is gained with the through bolts, even though it's aluminum.
Sorry to hear about rear, jcastle1, don't have any leads for ya for on dana 60 rear ends.
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: Challenger 1] #1081854
09/25/11 02:53 PM
09/25/11 02:53 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Whats the P/N?
SDG Motorsports
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081855
09/25/11 04:32 PM
09/25/11 04:32 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Mike,
The pig was just freshened with new bearings & pinion seal last fall.
I re-installed the yolk and torqued it to 190 lbs.
I was told by the person who re-built my pig that he torqued it to 225 ft. lbs.
The yolk definately felt different(tighter)after I torqued to 190
I was gonna step it to 225lbs after I reached 190 but stopped because it felt tighter.
The next day after driving it to the track,it broke on the starting line after 1 easy pass to break in the new slicks.
Do you think I probably crushed the sleeve further,and changed the pre-load?
John
if it felt tighter then yes you over torqued it and that is why it broke ...
But I have to ask why ANYONE still uses a crush sleeve ??? It's an accident waiting to happen, solid spacers have been available for the 489 for close to 20 years ...
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: DemonDust] #1081856
09/25/11 04:34 PM
09/25/11 04:34 PM
Guitar Jones Offline
Whats the P/N?
http://www.summitracing.com/parts/DCC-4876445/?rtype=10
I've been using one for well over 10 years now and since I went to the pro gear I've not broken anything. Even my 30 spline Moser axles splines are still nice and straight.
Mancini is the cheapest I've found though.
http://chucker54.stores.yahoo.net/moal8ca742ca.html
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: DemonDust] #1081857
09/25/11 04:34 PM
09/25/11 04:34 PM
JohnRR Offline
JohnRR  Offline
Have you ran it other than on the ice ?
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: JohnRR] #1081858
09/25/11 05:01 PM
09/25/11 05:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Yeah I ran it on the asphalt, got a 1.36 60 ft... But the belleville unwound and the high clutches had a nuclear meltdown.... Currently under reconstruction
SDG Motorsports
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: fourgearsavoy] #1081859
09/25/11 05:16 PM
09/25/11 05:16 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Yep split the sleeve,lost all the preload then mayhem was introduced
They all fail eventually
Gus
Gus.... You Got a pretty way of sayn things....
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081860
09/25/11 09:51 PM
09/25/11 09:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What do you mean by "split the sleeve"?
I don't understand.
Well I have seen more than one 489 case split the crush sleeve right down the side when you shock them with weight,horsepower,and traction.
I have also rebuilt 9" rears that also split that little tiny sleeve
I went to a Dana before that happened to my 8 3/4(alot easier to sell before the look like yours)
If you stay with an 8 3/4 do yourself a favor and get a 742 unit
Gus
64 Plymouth Savoy
Dana 60
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: 10secGTX] #1081861
09/25/11 09:54 PM
09/25/11 09:54 PM
Rittman Ohio
Rittman Ohio
Gus
Fran I just picture that "mayhem guy" from the insurance ads on the TV hanging under our cars looking for the weak link
Gus
64 Plymouth Savoy
Dana 60
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: fourgearsavoy] #1081862
09/25/11 10:13 PM
09/25/11 10:13 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Call Cass Eslick aka Dr. Diff out in Montana. He can set you up with a Strange 60. We went the S60 route with a Detroit Tru-Trac. Has worked great. The 8-3/4 brakes bolted right up, which saved some coin.
Tried to find a Dana in a junkyard, but decided the time spent to find one, change gears, put in limited slip of some type, weld on axle ends was better spent doing what I do well, which is designing boats, and paying Cass for brand new parts that showed up in a nice crate.
Oh yeah, on our 8-3/4 the spider gears broke, the left axle shaft twisted off and the right one was twisted like you show. There were also signs of the ring gear hitting the housing. Same deal, stout 383, heavy car (70 RR) 4 speed, slicks. Now that we have a Performance Only 452 I am really good that we have the S60.
The problem was, no matter what axles I put in, the spider gears would be the same. I would have to back brace the housing (welding, distortion, straightening), buy new shafts etc so went right to overkill.
Bummer about the breakage regardless.
I will also mention might want to think about a different clutch too since we are all spending your money with our suggestions. I have been very pleased with our Tim Hyatt built Mcleod based Soft-Lock. Loosen it up for the track, tighten it up for the street.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: David_in_St_Croi] #1081863
09/25/11 10:19 PM
09/25/11 10:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I broke ONE 8 3/4, my car had a Strange S-60 now.
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: justinp61] #1081864
09/25/11 10:57 PM
09/25/11 10:57 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Hey guys,thanks for all the love,I appreciate it.
Anyone got a phone# for Dr. Diff ?
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081865
09/25/11 11:02 PM
09/25/11 11:02 PM
406) 883-4772
Website:
http://www.doctordiff.com/
Cass is very nice and gives great service.
Noticed you are from Cincinnati, my wife is from there but she is an island girl now.
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: David_in_St_Croi] #1081866
09/25/11 11:45 PM
09/25/11 11:45 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Thanks for the quick reply.
Yes,born & raised here in Cincinnati.Glad to hear someone made it out!
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081867
09/27/11 12:45 AM
09/27/11 12:45 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
If I'm gonna go Dana 60,should I go with 30, or 35 spline axle?
Just a street car that I do have slicks for and go to the track a 1/2 dozen times a year for tnt.
Page 2 of 4 1 2 3 4
