Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: Labratt] #1081259
09/24/11 10:12 PM
09/24/11 10:12 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Remi..are the deals from Indy directly? I've heard of WAY TOO MANY horror stories dealing with them! I believe Dwayne's a distributor for them,though. I'll see what he says!....Chad,I'm sure opening up the ports will take some velocity away..i.e TORQUE! But..maybe the milling will help to offset some of the torque loss. I'll have to discuss this with Dwayne,as well! All I know is if getting the heads ported,and raising the compression to what HE thinks will handle pump premium...results in CONSISTENT 10.9-11.0's....I'll be VERY HAPPY!
Hey I didn't say it wouldn't be a trade off that wouldn't be worth it. The gains up top will more than make up for the small torque loss at the bottom. And depending on the converter it may not be noticed at all.
Do the stage 2 porting and I promise you will notice a huge power gain. Once that not just the timeslip will notice but the seat of your pants is gonna feel a HUGE gain too.
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: viperblue72] #1081260
09/25/11 09:41 AM
09/25/11 09:41 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Chad! I'm curious as to how high I can go with the compression..and still run pump gas. My 262/266 @ .050 duration might let me get away with a little more than 11:1. I'm sure I'll get the answer when I talk to Dwayne..and Jeff!
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: Labratt] #1081261
09/25/11 01:19 PM
09/25/11 01:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What is your current cranking cylinder pressure?
What is the advertised duration, and what ICL?
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: BSB67] #1081262
09/25/11 04:54 PM
09/25/11 04:54 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Russ..cyl. pressures averaged 182,when I checked them last(April)The only duration specs I see on the Comp card are the 262/266 @ .050 numbers. When we degreed the cam,it was 105 ICL...where we left it! The intake opens at 26* BTDC and closes at 54* ABDC,if that helps! Hope everything is going good with you! Randy
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: Labratt] #1081263
09/25/11 06:28 PM
09/25/11 06:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Hmmmm. Cylinder pressure is higher than I would have thought for a 10:1 CR and a cam that large. Do you know your deck height, valve notch volume, gassket thickness and head volume? Is it a zero deck 6-pack piston...I don't remember.
We're doing good. I'll be back up in Mich. pulling the dock next weekend. Seems like I just put it in.
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: BSB67] #1081264
09/26/11 12:07 AM
09/26/11 12:07 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Russ..my deck heights avg. 10.715"..gasket thickness compressed is .039..the pistons are Diamond flat tops,and the chamber volume is 84cc. Have an idea on the MAX comp. ratio?
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: Labratt] #1081265
09/26/11 12:48 AM
09/26/11 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy the cam has a BIG play with what the real(dynamic)
compression is... when the intake closes
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: MR_P_BODY] #1081266
09/26/11 01:17 AM
09/26/11 01:17 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Mike..the intake opens at 26* BTDC..and closes at 54* ABDC. What does this tell you? What's your guess on the max ratio for my combo..on pump premium? THANKS!
Re: PORTER RACING HEADS STAGE II PORT ON BB EDD [Re: Labratt] #1081267
09/26/11 11:00 PM
09/26/11 11:00 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
After punching in the numbers on the Wallace calculator..the DYNAMIC compression comes out to 8.74. I was told the max was right around 9.2! Anybody know how much would have to be milled to achieve this on Eddy Performers?
