C body motor mount torque straps
#1080500
09/22/11 05:08 PM
09/22/11 05:08 PM
Posts: 5,799 minnarusta
TX9H6E4CUDA
minnarusta
A buddy of mine was telling me about how big C body cars had some torque straps that held the motor mount together and kept the motor from shifting. Does anyone have a picture of this set up or of the straps themselves? Im going to a yard next weekend and I am going try and find a set to put into my car. Also what models and years of c bodies have you seen them in?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: C body motor mount torque straps
[Re: 440newport]
#1080502
09/22/11 05:44 PM
09/22/11 05:44 PM
Posts: 75,369 A gulag near you.
JohnRR
A gulag near you.
I have something that may or may not be one , it was in my 69 Superbee when I bought it back from a freind that had put a 383 from a 69 Polara in it , it was neither a police car or a taxi though but I did also get a set of 15x6 H wheels off it also . It's just a short piece of steel cable with 2 crimped on ends with some sort of spacer , it grabbed one engine ear bolt and the bolt thru the K frame ... You are lucky that you can still go yarding and find 60's - 70's mopars , around here they crushed pretty much everything when steel was going overseas for big bucks
[Re: JohnRR]
#1080503
09/22/11 05:59 PM
09/22/11 05:59 PM
TX9H6E4CUDA
minnarusta
Yeah I am lucky, the yard I am going to has not crushed a car since the late 50's. It is a amazing place and they have cars stacked on top of other cars. Its starting to become a little overgrown and I am actually bringing my chain saw with to clear a path and to get to some cars. Ill have pics next weekend of this place.
[Re: JohnRR]
#1080504
09/22/11 07:37 PM
09/22/11 07:37 PM
Posts: 1,069 Washington State
70Duster440
Washington State
I found them on my '69 Newport vert when I pulled the engine. Runs from an upper mount boss to bottom. Oddly, my passenger side mount was broken.
[Re: TX9H6E4CUDA]
#1080505
09/22/11 08:37 PM
09/22/11 08:37 PM
Posts: 21,138 Niles , Ohio
therocks
Niles , Ohio
I have a few somewhere also.Mine came out of some Imps I pulled motors from.Looks like a cable with 2 eyes.Rocky
Chrysler Firepower
[Re: therocks]
#1080506
09/22/11 08:57 PM
09/22/11 08:57 PM
TX9H6E4CUDA
minnarusta
Ok so was there only one for the drivers side or two for both sides?
[Re: Gavin]
#1080510
09/23/11 07:52 AM
09/23/11 07:52 AM
Posts: 654 Westfield, MA
rbrogle
super street
super street
Westfield, MA
Must have been a '69 thing because I parted a rough '69 300 convertible several years ago and it had that strap on the driver's side mount only. I saved it and plan on using it on either my current convertible or my '68 300 someday. I have another friend in central Mass. that took one from a parted '69 C body and is currently using it on his '70 6 BBL. 'Cuda. Works like a charm and protects the fan shroud and shaker hood stuff. THey should have used it on all BB cars of that era.
Rob
'70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic
'68 300 2 Door HT vinyl/cloth bench
'68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED!
'68 New Yorker 4 Door HT, 440/Auto, loaded!
2004 Chrysler 300M Special daily driver
[Re: TX9H6E4CUDA]
#1080511
09/23/11 08:06 AM
09/23/11 08:06 AM
JohnRR
A gulag near you.
Would only be on the drivers side , the passenger mount is in compression when the engine is trying to spin itself .
They should have definitely installed that on all 4 speed cars at a minimum.
[Re: 383man]
#1080513
09/23/11 06:35 PM
09/23/11 06:35 PM
Posts: 3,470 Back in NJ....
EWJ
Back in NJ....
Might not be just a 1969 thing : The one I have came out of a 68 Newport 383/2bl/ 3-on-the-tree manual trans car I cut up.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: 11secondC]
#1080516
11/27/11 12:17 PM
11/27/11 12:17 PM
Posts: 4,402 Madison Wi
NTOLERANCE
Madison Wi
Does anyone have a length on these cables? Wondering how much slack if any they had.
[Re: NTOLERANCE]
#1080518
11/27/11 04:19 PM
11/27/11 04:19 PM
70Duster440
Washington State
Approximately 7.5" OC.
[Re: TX9H6E4CUDA]
#1080519
11/27/11 04:41 PM
11/27/11 04:41 PM
Posts: 16,489 Canada
CrAzYMoPaRGuY
Canada
I bought a 1969 Chrysler station wagon years ago with a 383, it had the driver's side strap. 4bbl, high flow exhausts, 3.23 sure grip, and the gas cap said "premium fuel only".
CrAzYMoPaRGuY
