Re: C body motor mount torque straps
[Re: TX9H6E4CUDA]
#1080520
11/27/11 06:25 PM
11/27/11 06:25 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
These could be made easily. I have the crimping tool and a bunch of the clamps, just not the style mopar put on. These eyelets arent steel, but its what I had lying around.
Clearly Mopar used some special bolt ends to keep the piece from getting crushed/tisted.
I would loop them around and forget the eyelets and just use two clamps. Slightly longer upper bolt and a spacer on the lower bolt and youd be good. I used 3/16" air craft type cable.
[Re: NTOLERANCE]
#1080521
11/27/11 06:26 PM
11/27/11 06:26 PM
NTOLERANCE
Madison Wi
7.5" seems abit long, even though thats what I measured as well.
[Re: wasacuda]
#1080523
11/27/11 11:36 PM
11/27/11 11:36 PM
Posts: 1,294 Under the big sky
stateline
Under the big sky
Garret I have a complete one I will sell you for $50.00 Its cold outside and you will spend that in gas money hunting for one.
Kind of steep if you ask me
[Re: wasacuda]
#1080525
11/28/11 02:37 PM
11/28/11 02:37 PM
stateline
Under the big sky
Someone always has to be a wise guy. 50 bucks is for a complete mount with the strap.
I wasnt being a wise guy , I sold him mine for $15 including shipping, think I have several more somewhere.
[Re: CrAzYMoPaRGuY]
#1080531
11/29/11 08:08 AM
11/29/11 08:08 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I bought a 1969 Chrysler station wagon years ago with a 383, it had the driver's side strap. 4bbl, high flow exhausts, 3.23 sure grip, and the gas cap said "premium fuel only".
Wow, a talking gas-cap..! Who would've guessed that kind of technology already found it's way into cars in '69...
