Page 2 of 3 1 2 3
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Cab_Burge] #1080469
09/25/11 01:41 AM
09/25/11 01:41 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
So I pulled the distributer and tried to prime the pump with the drill. No oil pressure.
Note what the bronze gear looked like.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080470
09/25/11 01:42 AM
09/25/11 01:42 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
pic 2
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080471
09/25/11 01:45 AM
09/25/11 01:45 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
so I drained the new oil and pulled the oil pump
It is a new muscle motors unit. Not a milidon (I forgot that I got this one recently, It was internal before)
The valve slides in and out for the first half easily but gets jammed going all the way in. It needs to be forced to open and close completely.
It got be a bit of casting that the valve is getting stuck on
Not the wear on the housing and the pump I am not sure if the pump could not turn of if it wa sthe valve of what series on events transpired.
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080472
09/25/11 02:06 AM
09/25/11 02:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well you can try reaming the by pass hole to free it
up... also get a new intermediate shaft(which you already
know)... how long was that shaft in there... I cant see
the wear on the pump and housing very well but how deep
is it in the housing... I would believe your issue
is the by pass not seating
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080473
09/25/11 03:26 AM
09/25/11 03:26 AM
Arizona
Chris'sBarracuda Offline
Arizona
It is a new muscle motors unit. Not a milodon (I forgot that I got this one recently, It was internal before)
You know those oil pump cover bolts only torque to 25-30#..
They could be over torqued and binding the shaft..
You should be able to turn the pump when torqued, with your fingers using a priming shaft.
Also, put a tiny bit of white grease in the pump when re-assembling.
It will help prime the system.
Chris..
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Chris'sBarracuda] #1080474
09/25/11 09:29 AM
09/25/11 09:29 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
After seeing that now is the time to pull the engine, fix all your issues, clean all the parts, mic and measure, do all the needed machine work, clean all the parts again, and install new rings, bearings, pump, oil pump drive and all other new parts that will be needed.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: pittsburghracer] #1080475
09/25/11 12:28 PM
09/25/11 12:28 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Mike. I bought the engine used. I don't know how many miles are on it. I bought it to build for the procharger
There isn't very much where on the housing. Any suggestions on it,
I agree that the housing seemed torqued down to far. It was tight taking it off
Not sure what to do on the rebuilt. I need to decide to pull apart and clean it up, put together or built with lower compression for the procharger
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080476
09/25/11 02:22 PM
09/25/11 02:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You could mill that flat again or if you dont have
a mill use sand paper on a flat surface like a surface
plate of a piece of glass
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: MR_P_BODY] #1080477
09/25/11 02:57 PM
09/25/11 02:57 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I would try another pump then try to prime with a drill, The ware pattern showes that air could be transfering from the intake to exhaust port of the pump
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: emarine01] #1080478
09/25/11 10:52 PM
09/25/11 10:52 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Sorry to hear about your woes Rob! If I can help let me know.
Steve
Photobucket sucks
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: 72chrgrally] #1080479
09/27/11 11:05 AM
09/27/11 11:05 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
It appears that the distributer was not adjusted properly and also put pressure on the oil pump.
There are brass metal fragments in the oil pump rotor so...
It looks like the engine is coming out.
4 years to get it together and 2 short drives LOL. (I will consider it as a total car mockup)
I guess I will be building the procharger engine earlier than expected.
Time to call Dwayne for some cylinder head work too.
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080480
09/27/11 02:34 PM
09/27/11 02:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I know this is small comfort, but it's better to find it now, rather than by driving over the crank.
Boffin Emeritus
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080481
09/27/11 03:25 PM
09/27/11 03:25 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The distributor shouldnot be able to push on the oil pump. thats what the dist shaft bushing is for.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: RemCharger] #1080482
09/28/11 11:28 PM
09/28/11 11:28 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thats what the builder said, but the prior owner used an MSD with an adjustable collar and it may not have been set right. Too deep
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: mac56] #1080483
09/28/11 11:43 PM
09/28/11 11:43 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I know it sounds too simple but I have had the screw that hold the relief spring in the pump back out.
That happend to me , relief plug unscrewed dropped oil pressure. Pulled the pan, bearings, couldn't find anything. Then the boy's on Moparts told me where to look. Simple fix, used some lock tight to make sure it didn't happen again.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080484
09/28/11 11:46 PM
09/28/11 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I doubt it... the dist shaft with a collar still
would be pushing on the intermediate shaft and the
bushing below it
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080485
09/29/11 02:23 AM
09/29/11 02:23 AM
CALIFORNIA, USA
KB RACING ENG Offline
CALIFORNIA, USA
Kam, Just a thought. If you haven't already done this,you might check the OAL of the intermediate shaft as some of the Milodon set-ups use a longer than stock shaft. You said your older set-up was a Milodon. I don't know what length the Muscle Motors unit uses. Our KB cast and billet pumps all use the stock length shafts. If you use the longer shaft with our pumps it bottoms out and will not seat on the distributor bushing. From the photos it looks like there was a lot of pressure forcing the rotors into the cover and the bronze gear....not fully engaged on the cam because the shaft was not seated on the bushing? Then again I could be totally off the mark but thought I would throw it in as something to look at.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: KB RACING ENG] #1080486
09/30/11 01:14 PM
09/30/11 01:14 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Could this issue for the gear be caused by a inproperly sized cam button?
https://board.moparts.org/ubbthreads/uplo...ronze-gear1.jpg
1654.5 Mustang
1955 Land Rover
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: Kam*Kuda] #1080487
09/30/11 03:01 PM
09/30/11 03:01 PM
CALIFORNIA, USA
CALIFORNIA, USA
As long as you had the proper end play on the camshaft when the engine was built I don't see how this could come into play. The block and cam gear/thrust washer keep the cam from being pushed too far to the rear and the thrust button would keep the cam from walking towards the front unless you have a different set-up.
Re: Low Oil Pressure %^@#!&* What to check first??? [Re: KB RACING ENG] #1080488
09/30/11 03:26 PM
09/30/11 03:26 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Switched the timing cover and the guy had to make a new button.
He indicated that something may be wrong as he had to take a lot out to fit. This could be an issue
1654.5 Mustang
1955 Land Rover
Page 2 of 3 1 2 3
