Re: Operating a RMVB on the street
[Re: BradH]
#1079700
09/23/11 11:04 AM
09/23/11 11:04 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
So do you guys really think there is a difference from kicking down a stock valve body into first gear from speed or putting a non band apply MVB into first at the same speed?
Well there isn't.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1079702
09/23/11 05:58 PM
09/23/11 05:58 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Well there isn't.
You know I never looked at it that way. I mean since I use a TA non apply low band in first I really thought about slamming it back in first and worrying about the overrunning clutch locking back up from freewheeling and figure I dont want to worry about doing any damage to it. But you are correct as in a stock trans the low band is not on when in first from the drive posistion and we all have slammed it to the floor at 20 mph to have it drop back to first and go ! Hmmmmmmm........now you have me thinking about that. Ron
[Re: John_Kunkel]
#1079705
09/24/11 05:23 PM
09/24/11 05:23 PM
Guitar Jones
Well there isn't.
I believe the discussion was about shifting to low while coming to a stop. Kicking down is done at WOT and stopping is at idle.
Besides the point first of all. If you take off in 2nd or 3rd and you're only going say 20 MPH you can still shift into 1st under throttle. If you can do that why can't you shift to first while rolling at say 5-10 mph before stopping? A stock valve body will go into first before a complete stop, you just don't feel it because it's free wheeling. Granted it's probably under 5 MPH but it's the same thing. They just don't want you slamming a RMVB down into first at 30 and then hammering it or using 1st as a kind of neutral to coast down.
