Re: what sway bar in an E-body with narrower rearend?
[Re: autoxcuda]
#1079129
09/23/11 02:50 PM
09/23/11 02:50 PM
Posts: 203 Sante Fe Springs, CA
Hotchkis
The addco, helwig, and hotckis rear sway bars will work. The helwig and hotckis dogbone connector links may need attention.
I know Hotchkis has a special bolt for clearence on the rear sway bar connector for moved springs. But I don't remember what the exact moved over amount was.
Steve – The special sway bar bolts we sell allow for additional bolt clearance when moving the rear leaf springs inboard 1 to 1.5” for wider tires. PN: 17366
![](http://i997.photobucket.com/albums/af92/kahnmedia1/Cuda-offsetsprings-1point5.jpg)
