Re: did some air bleed tests,?
[Re: Clanton]
#1077776
09/23/11 02:53 PM
09/23/11 02:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thank you 3404 and i agree i dont want to endup with junk carbs! ![](/ubbthreads/images/graemlins/thumbs.gif) the jets in the plate are 110. ![](/ubbthreads/images/graemlins/eeek.gif) the high speed does ok at 12.8 a/f but needs more with those jets.
I cant believe you need 110 jets on a PAIR of carbs unless your running E-85 and then it still doesnt sound right ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1077777
09/23/11 02:58 PM
09/23/11 02:58 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
i know mr p.some info on the carbs,it came with 100 jet and power valves so i blocked them and jettup.it is a 1250cfm carb. ![](/ubbthreads/images/graemlins/shruggy.gif) like i said the high speed is close at 12.8 a/f and i have not touched those bleeds.just the intermediat is lean.
[Re: Clanton]
#1077778
09/23/11 03:01 PM
09/23/11 03:01 PM
MR_P_BODY
i know mr p.some info on the car,it came with 100 jet and power valves so i blocked them and jettup.it is a 1250cfm carb.
I thought you had dual 4 barrels... so you only have a single ![](/ubbthreads/images/graemlins/wave.gif)
