Page 2 of 3 1 2 3
Re: 8 3/4 vs Dana 60 weight difference? [Re: S/ST 3040] #1074999
09/14/11 06:43 PM
09/14/11 06:43 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: 8 3/4 vs Dana 60 weight difference? [Re: S/ST 3040] #1075000
09/14/11 06:44 PM
09/14/11 06:44 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Same set up I have in my Barracuda, But I still can't change gears at the track. 9 inch all the way
Re: 8 3/4 vs Dana 60 weight difference? [Re: mokid] #1075001
09/14/11 06:56 PM
09/14/11 06:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When was the last time you changed gears at the track...
I've got a 8 3/4 in the P-Body and a 9" in the Rampage
and I've NEVER changed gears at the track
Re: 8 3/4 vs Dana 60 weight difference? [Re: MR_P_BODY] #1075002
09/14/11 07:49 PM
09/14/11 07:49 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sure would be nice to be able to, if you hurt a rearend on a Fri at a 3 day race.
I know I have more than once in my dragsters.
I have ran 2 different gear sets during TNT.
Re: 8 3/4 vs Dana 60 weight difference? [Re: Challenger 1] #1075003
09/14/11 09:59 PM
09/14/11 09:59 PM
MI
68shifter Offline
68shifter  Offline
MI
This is a Dana I finished tonight. Everything new except the housing - A body width. Posi, green bearings, 35 spline dr. diff axles, 11" brake setup etc. As pictured with perches and lines but no fluid was - 240lbs
Sorry, but no 8-3/4 to compare to. Last year I put Wilwoods on my Dana and lost 45 lbs, so getting under 200 no problem.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: 8 3/4 vs Dana 60 weight difference? [Re: S/ST 3040] #1075004
09/14/11 10:06 PM
09/14/11 10:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
My Dana 60 ended up 15 lbs. lighter than the 8 3/4".
Mark Williams 40 spline gun-drilled axles, aluminum spool, and Aerospace discs in place
of the 11" x 3" drums. The brakes was the big savings.(45 lbs. lighter)
My dana was lighter also! drums to strange discs! housing smaller / smaller axels... spool
Mopar Performance
Re: 8 3/4 vs Dana 60 weight difference? [Re: Challenger 1] #1075005
09/14/11 10:06 PM
09/14/11 10:06 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
"Why would you want to run a heavy dana 60 that have few aftermarket parts made for them with limited gear ratios?"
Heavy??
Few aftermarket parts??
Limited gear ratios??
A NEW Dana 60 weighs about the same, costs less, and is MORE EFFICIENT than a COMPARABLE 9".
Commonly available Dana 60 gear ratios:
3.54, 3.55, 3.73, 3.90, 4.09, 4.10, 4.30, 4.56, 4.88, 5.13, 5.38, 5.86, 6.17, 6.50, 7.17
Commonly available Dana 60 spools:
35 spline
40 spline
Commonly available Dana 60 traction differentials:
30 spline
35 spline
40 spline
As far as I know, there are only 3 35 spline traction differentials available for a 9" and NO 40 spline units.
Unless you are talking about light duty 28 spline street/cirle track gears, few ratios are available for "big pinion" 9" and 9.5" rears.
Dana 60s are very strong street/strip rears. Once again, application is everything.
Re: 8 3/4 vs Dana 60 weight difference? [Re: 68shifter] #1075006
09/14/11 10:09 PM
09/14/11 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you have a P/N for the Y block/vent... I still
need to put one on my diff
Re: 8 3/4 vs Dana 60 weight difference? [Re: MR_P_BODY] #1075007
09/14/11 10:11 PM
09/14/11 10:11 PM
MI
68shifter Offline
68shifter  Offline
MI
Mr. P
I dont on me. But its for a 76 Powerwagon front axle 4wd. Any advance etc for $18, usually a day to get.
PN - 77171Z from autozones website. They list it as an inner. Should be a Dorman number
Re: 8 3/4 vs Dana 60 weight difference? [Re: 68shifter] #1075008
09/14/11 10:16 PM
09/14/11 10:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mr. P
Thanks... I'll hit the parts store tomorrow
Re: 8 3/4 vs Dana 60 weight difference? [Re: MR_P_BODY] #1075009
09/14/11 10:23 PM
09/14/11 10:23 PM
Guitar Jones Offline
As I weighed my aluminum center A body 8.75 with a steel spool to a Ford truck Dana housing, bare, unshortened there was a 50 pound difference. No brakes on either one but the Dana housing did still have the full floating ends on it. If I had it to do over again I'd have a Dana in my car. With a pro gear I'd probably never break it and if I have to do major work at a track, I'm taking it home. Breaking something at the track is one thing but I've driven a lot of miles just to red light in the first round so what's the big deal, I can't fix the red light. If it's something simple I'll fix it, if it's major it's not going to be a permanent repair at the track anyway so it's just going home. Might just as well drink a few beers and watch the rest of you for awhile.
Re: 8 3/4 vs Dana 60 weight difference? [Re: Guitar Jones] #1075010
09/14/11 10:37 PM
09/14/11 10:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a alum center 8 3/4 with back brace, steel
spool,narrowed and disc brakes.... I never did weigh
it but its alot light than the dana I narrowed for
a buddies car... basically the same set up
Re: 8 3/4 vs Dana 60 weight difference? [Re: Challenger 1] #1075011
09/14/11 10:55 PM
09/14/11 10:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have seen many Mopar racers that had Dana 60 in thier race cars change gear ratio at the track in 20 minutes They had set the spool up with the ring and pinion set up for that housing and had it done in as quick as I could change the third member in my 8 3/4 Planning and prepartion is everything when it comes to racing and changing parts at the track When it comes to costs of spare rear end parts I much rather have a Dana 60 ring and pinion mounted on a spool all set up than have a Nine inch Ford type third member set up and ready to go, $350 to $500.00 for the Dana parts versus $1300.00 + for the nine inch race third member
Re: 8 3/4 vs Dana 60 weight difference? [Re: DoctorDiff] #1075012
09/15/11 09:29 AM
09/15/11 09:29 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Heavy??
35 spline
40 spline
30 spline
35 spline
40 spline
The Dr is 'in'.
Re: 8 3/4 vs Dana 60 weight difference? [Re: WheelsUp73] #1075013
09/15/11 10:59 AM
09/15/11 10:59 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
30 lbs-60 lbs right over the wheels where ya need it.
Not when its "unsprung" weight !!!
Agree 100%.
That's what adjustable shocks are for.
Yeah, it's got a smallblock.
Re: 8 3/4 vs Dana 60 weight difference? [Re: 340B5] #1075014
09/15/11 03:27 PM
09/15/11 03:27 PM
organ
maximum entropy Offline
organ
i've broken an 8 3/4. i've broken a 9". i put a dana in, and it runs EXACTLY the same et. exactly. mr dana laughs at my attempts to hurt him. i recommend the dana. get close on your gear ratio, and fine tune using tire diameter (how you should be doing it anyway).
Re: 8 3/4 vs Dana 60 weight difference? [Re: WheelsUp73] #1075015
09/15/11 05:30 PM
09/15/11 05:30 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Agree 100%.
You lost me. It's primarily a street car that sees track 3 or 4 times a year. Also, I understand why some of you recommend a 9", but the Dana is bought and paid for. 35 spline with power lock and a 4.10. No desire to gear swap...just bought it so I would get more sleep the night before raceday. Thanks for all of the responses. We will weigh both and post numbers when it comes time to do the swap.
Re: 8 3/4 vs Dana 60 weight difference? [Re: OA5599] #1075016
09/15/11 06:22 PM
09/15/11 06:22 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
For a A body why not just run the 8 3/4? I have a 8 3/4 in my B body seems to work good! 35 spline axles, spool, m/w cap and back braced. Iknow the thread says whats the weight difference!
67' charger 499 RB 10.57 at 127
Re: 8 3/4 vs Dana 60 weight difference? [Re: dragram440] #1075017
09/15/11 07:40 PM
09/15/11 07:40 PM
ill
dennismopar73 Offline
ill
and the debate goes on,
8 3/4 is a very strong carrier, if set up right.
a dana does weigh more thats a fact , but the hp it gains far outwieghs that issue,
i have run both, and have realy picked up et by going with a dana, gear for gear change.
i cant say nothin for 9" i figure they belong to ford, so i leave them there
Re: 8 3/4 vs Dana 60 weight difference? [Re: dennismopar73] #1075018
09/15/11 08:37 PM
09/15/11 08:37 PM
Locomotion Offline
Locomotion  Offline
I've heard of Mopar Stock racers do the comparison, compensated for the weight so the car maintained the same total weight, and the car ran the same! The ring & pinion relationship in the housing is more efficient in a Dana 60.
Personally, I think the "unsprung weight" issue has been overblown in drag racing involving most cars. While I'm sure it's a factor, the "action" of that weight is minimal during a drag strip run when compared to a circle track or road course car where suspension movement is constant as well as constantly variable. But the faster you go on a drag strip, the more important it does become as small surface imperfections have to be compensated for quickly - i.e.: Pro Stock, Funny Car, Top Fuel, etc.
The unsprung weight of wheels and tires is a different situation and more important. That weight is not only unsprung, but it is rotating weight with a lot of it a good distance from the center of rotation, similar to the rotation of a crankshaft and its counterweights.
Page 2 of 3 1 2 3
