Re: Broke the ring gear what should I do?
[Re: mopartuner]
#1073788
09/12/11 09:01 PM
09/12/11 09:01 PM
Posts: 16,930 NC
440Jim
NC
What gear were you in when this happened ?
1st gear......right on the starting line
IMO, 50/50 chance the sprag is damaged. It might not be completely scattered, but if it has started to lay over it is just a few passes at high power before it lets go.
Is the valve body low band (1st) apply? If so, it is even harder to determine if the sprag is damaged without pulling it apart. But either way an inspection is good insurance.
[Re: Cab_Burge]
#1073789
09/12/11 09:11 PM
09/12/11 09:11 PM
Challenger 1
Cincinnati, Ohio
The bad part about the 489 case is it uses a crush sleeve and the caps on the carrier are some what weak... if you change the cap/caps and go to a solid sleeve they work fine
I forgot about the steel cap (Mark Willaims offers ) needed on the left side, If your going to stress any of the 8 3/4 center sections you should get one also
Why spend the money on a 8 3/4 getting caps, when you could put that money towards a stronger rear end? It already most likely caused tranny damage, think fixing the 8 3/4 is wise? Different rear end is the best value and it drops out just like a 8 3/4. He's already got 35 spline axles I believe.
[Re: WheelsUp73]
#1073792
09/12/11 11:18 PM
09/12/11 11:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you broke in 1st gear then the sprag is garbage.I build trannys 8 3/4, the caps won't help because what breaks gears is case deflection
Sure didnt hurt my sprag... and its still in there... but we all get lucky now and then
