Broke the ring gear what should I do?
#1073768
09/12/11 01:07 PM
09/12/11 01:07 PM
Posts: 614 ont,canada
mopartuner
ont,canada
I broke the ring gear in the 8-3/4 rear end(489 case)this was a 410 gear and had many street miles and some 10 second passes on it as well as the 12 second passes this last weekend.The car has a spool and is a small block(360,904 combo)and is 3000lbs.My question is should I just get a set of gears and go or should I change to a 742 case?The car has 35 sline axels in it as well.
410 pump gas solis flat tappet cam 10.95 so far
Re: Broke the ring gear what should I do?
[Re: mopartuner]
#1073770
09/12/11 01:11 PM
09/12/11 01:11 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Clean it and install new gears. The 742 is not stronger than the 489.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: mopartuner]
#1073774
09/12/11 01:20 PM
09/12/11 01:20 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
I would think your case,spool & axles should be fine unless it was injured. You may have broke the sprag in your transmission,You may want to pull the trans & check.
I called my tranny guy and he said if the overrunning clutch was gone that I would have no first gear and I did manage to back it up and put it up on the trailer in forword in low gear.
Is the guy going to stand behind that statement if and when your front drum comes thru the floor of your car ?
What gear were you in when this happened ?
[Re: mopartuner]
#1073777
09/12/11 01:30 PM
09/12/11 01:30 PM
JohnRR
1st gear......right on the starting line
Pull the trans ...
[Re: mopartuner]
#1073778
09/12/11 01:34 PM
09/12/11 01:34 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
Take the tranny out and inspect the rear spraque Sometimes you get lucky and sometimes you don't ![](/ubbthreads/images/graemlins/shruggy.gif) Way better to be safe than not I have a high dollar 727 SS trans that drives fine at low throttle but if I foot stall it it up and hit it, it acts like it is in nuetral, backs up good, goes into all the gaers, drives fine at low throttle. I broke the rear end it the car with that trans before that happened. I have several trans and need to take that one apart to fix it Be safe ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DavidDean]
#1073780
09/12/11 02:37 PM
09/12/11 02:37 PM
mopartuner
ont,canada
My transmission guy offered to check it for free so I think I will pull it.
[Re: Blucuda413]
#1073782
09/12/11 02:56 PM
09/12/11 02:56 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Pull the trans, inspect the over running clutch, no doubt about it. No way, no how I would chance it.
As for the 42 vs the 89, the 42 is stronger in that it has a larger rear pinion bearing which in turn reduces some pinion gear deflection. Other than that, no they are the same. Inspect the caps carefully as well as the carrier.
[Re: mopartuner]
#1073785
09/12/11 03:30 PM
09/12/11 03:30 PM
Guitar Jones
Are you still using the pinion crush sleeve to set the pinion bearing preload or a spacer and shims? If crush sleeve, lose it and buy a spacer from Ratech Better yet,if you have access to a 742 case get it and use it
If I go to a 742 case then I need to buy another spool don't I?
No, but the ring and pinion is different as are the bearings for the pinion gear. You'll also need setup shims and the gear selection for the 742 case isn't as great as for the 489.
[Re: mopartuner]
#1073786
09/12/11 05:11 PM
09/12/11 05:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The bad part about the 489 case is it uses a crush sleeve and the caps on the carrier are some what weak... if you change the cap/caps and go to a solid sleeve they work fine ![](/ubbthreads/images/graemlins/wave.gif)
[Re: mopartuner]
#1073788
09/12/11 09:01 PM
09/12/11 09:01 PM
Posts: 16,932 NC
440Jim
NC
IMO, 50/50 chance the sprag is damaged. It might not be completely scattered, but if it has started to lay over it is just a few passes at high power before it lets go.
Is the valve body low band (1st) apply? If so, it is even harder to determine if the sprag is damaged without pulling it apart. But either way an inspection is good insurance. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Cab_Burge]
#1073789
09/12/11 09:11 PM
09/12/11 09:11 PM
Challenger 1
Cincinnati, Ohio
I forgot about the steel cap (Mark Willaims offers ) needed on the left side, If your going to stress any of the 8 3/4 center sections you should get one also
Why spend the money on a 8 3/4 getting caps, when you could put that money towards a stronger rear end? It already most likely caused tranny damage, think fixing the 8 3/4 is wise? Different rear end is the best value and it drops out just like a 8 3/4. He's already got 35 spline axles I believe. ![](/ubbthreads/images/graemlins/stirthepot.gif)
[Re: WheelsUp73]
#1073792
09/12/11 11:18 PM
09/12/11 11:18 PM
MR_P_BODY
If you broke in 1st gear then the sprag is garbage.I build trannys 8 3/4, the caps won't help because what breaks gears is case deflection
Sure didnt hurt my sprag... and its still in there... but we all get lucky now and then ![](/ubbthreads/images/graemlins/wave.gif)
