Re: 440 dead miss 2 cylinders?? [Re: buildanother] #1072996
09/11/11 09:01 PM
09/11/11 09:01 PM
Lenox Iowa
MMiller Offline OP
MMiller  Offline OP
Lenox Iowa
Ok, well after it set all night, I cannot spin the pushrods like you mention. I noticed that some I could, and some I couldn't. Of the ones on the base of the cam.
The lifters from #1 when I removed them, the plunger was pushed clear up to the snap ring. Plus they were holding the valves slightly open. I'm learing about hydraulic lifters, but I don't think they should be like that should they?
Thanks again for all the comments and info.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: 440 dead miss 2 cylinders?? [Re: Challenger 1] #1072997
09/11/11 09:07 PM
09/11/11 09:07 PM
Lenox Iowa
MMiller Offline OP
MMiller  Offline OP
Lenox Iowa
Go ahead and order lifters...
I don't know how to read this. Do you feel like I'm wasting money buying lifters, or do you think I messed with it too much and really need lifters? I'm tired of chasing my tail.
Michael
Re: 440 dead miss 2 cylinders?? [Re: MMiller] #1072998
09/11/11 10:09 PM
09/11/11 10:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Michael
You need shorter pushrods on some valves, plain and simple. If you don't have adjustable rockers to compensate for variances valve to valve.
There ain't anything wrong with your lifters.
Hopefully you didn't hurt a lifter or cam lobe by running it with not enough lash. They all should be checked. Easiest way is with the intake off. Set em once and forget about them for life of the motor with a hydralic cam with adjustable rockers.
You need to take a adjustable pushrod and see what length you need and compare that with the pushrods you're running now. I bet there too long.
Re: 440 dead miss 2 cylinders?? [Re: Challenger 1] #1072999
09/11/11 10:32 PM
09/11/11 10:32 PM
Lenox Iowa
MMiller Offline OP
MMiller  Offline OP
Lenox Iowa
Alright, I see what you are saying. If the plunger in the lifter is up at the top pushing on the snap ring, would that still indicate too long of push rod? Thats what is confusing me, I can see if they were way down in the stroke of the plunger. But these are up against the snap ring. I thought that they lifter was supposed to run partially down in the plunger stroke. That way they could compensate for wear. Is this wrong?
I'm sorry I'm being difficult. I've worked on diesels my whole adult life, and they sure a heck don't have hydraulic lifters or carburators.
Re: 440 dead miss 2 cylinders?? [Re: MMiller] #1073000
09/11/11 10:57 PM
09/11/11 10:57 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If the lifter is at the top of the travel against the snap ring the push rod is too short. You have to preload the hydraulic lifters somewhat. Some times the push rods are too long they push the plunger so far down in the bore that they bottom out the plunger then the person adds the 1 to 2 turns of preload and they are holding the valve open. This would be like preloading a solid lifter.
Re: 440 dead miss 2 cylinders?? [Re: MoparforLife] #1073001
09/11/11 11:07 PM
09/11/11 11:07 PM
Lenox Iowa
MMiller Offline OP
MMiller  Offline OP
Lenox Iowa
Ok, so if the lifter plunger is against the snap ring, the push rod is tight, and the valve is slightly open, and the lifter is on the base of the cam, what do I look at next?
Re: 440 dead miss 2 cylinders?? [Re: MMiller] #1073002
09/12/11 12:32 AM
09/12/11 12:32 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
new lifters(s)
Steve
