Re: Which is the right water pump for my 383 Roadrunner
[Re: Imrare]
#1072733
09/12/11 03:59 PM
09/12/11 03:59 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
The engine is definetly overheating. The engine has been so hot in the past (from idling) that it has melted the foam steering column gasket that goes between the firewall and the base mount of the steering column, plus, like I've mentioned previously the engine begins to spark-knock and the amount of heat coming off of the engine is dramatic. It gets so hot that even with leather "Mechanix" gloves on the carb throttle is too hot to touch for very long. I haven't put a laser temp gage on the block to see what the degrees are, but belive me, it is very hot.
I have seen these off and on , do you have an ACTUAL TEMP READING ??? till then you could be chasing the wrong problem.
also how long are you leaving it sitting "idling" ??? The steering column foam is being melted by the heat off the EXHAUST MANIFOLDS , not the engine itself ...
[Re: JohnRR]
#1072734
09/12/11 07:20 PM
09/12/11 07:20 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
are you actually over-heating or is the 'reflected' heat of the engine your concern?
[Re: Imrare]
#1072737
09/14/11 12:24 AM
09/14/11 12:24 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
It only makes sense that the engine would overheat slowly at idle with the lower volume 6 blade pump.
as far I can tell is not about low or high volume, is related about the size of the pulley. A/C cars got smaller pulleys on Water pump, so at same RPMs will spin faster being 6 vanes
I bought two pumps, one from NAPA and one from Year One. The year one looks to have the impeller set up for counter clock-wise rotation while the NAPA pump is set up for clock-wise rotation (they also sell the same pump for counter clock-wise rotation with an impeller that looks like the Year-One pump. For my application, I need clock-wise rotation. However, Year-One only lists this pump for the "383 - 440" application? I'm going with the NAPA pump.
This is very interesting... CW against CCW talking about same 8 vanes pump... aren't all engines with regular belts the same rotation no matter the belt setup with or without A/C ?
now there is something said by 6bblgt what is true... blades are 90 degrees, and if you install an "anti-cavitation" plate it will make work the impellers the same no matter how are cut the vanes if faced CW or CCW
[Re: NachoRT74]
#1072738
09/14/11 09:51 AM
09/14/11 09:51 AM
JohnRR
There is no factory serpentine setup for a big block mopar so I can't see the aftermarket making a CW and CCW pump , those pumps will push water no matter what direction they spin .
[Re: A12]
#1072741
09/14/11 11:02 AM
09/14/11 11:02 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Are there flow ratings available for the two water pumps? Why does it appear that the A/C pump would flow less than a non-A/C pump, I would think it would be the exact opposite need. I can see that the A/C pump would have less drag or resistance than the non-A/C pump and can understand that would be important because of the increased drag of the A/C system but why such a big difference? What is the flow rate difference between the two??
I read up on this a long time ago. If you move the coolant through the motor too fast, it does not allow the water/coolant adequate time to transfer the heat. Hemi's put out more heat and only have a 6 blade impeller just for that reason...to slow the flow down a little. I think Chrysler engineers also increased the diameter of the Hemi crank pulley and reduced the diameter of the water pump pulley from 68- 69 to try to get the optimum rpm's for the water pump? I believe 383/440 HP's and A/C equipped cars had 8 blade impellers. It's a little hard to understand. On the otherhand, I would be concerned about the backwards configuration of the impeller too? It just does not look right.
[Re: RoadRunnerJD]
#1072742
09/14/11 12:00 PM
09/14/11 12:00 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
I ran a 6 blade AC water pump on the 440 that used to be in my GTX for about 14 years. The first one had 93,000 miles on it when I installed it, it started leaking about 10 years later. I replaced it with another 6 blade from the parts store.
I always used non/ac pulleys.
In 14 years, many of which were daily driven (for a few years the GTX was my only transportation) the only heating problems I ever had were due to either me not using the fan shroud, or the radiator being clogged. Even when the first water pump leaked, it did not overheat.
So I guess I don't agree with the whole diagnosis, but good luck with it nonetheless.
Rich H.
Esse Quam Videri
[Re: Imrare]
#1072744
09/15/11 06:57 PM
09/15/11 06:57 PM
RapidRobert
Holler (in this thread) how it turns out. Yes Ma had their recommendations on that & I'm certainly not an engineer (or even close 2 it) but I haven't seen a prob w cavitation & I gotta go w an 8 blader/smallest WP pulley I can find/fit but I always use an added anticav plate esp on a SB
[Re: Imrare]
#1072748
08/17/12 12:02 PM
08/17/12 12:02 PM
Posts: 17,862 albany ny
05dakota
albany ny
[Re: Imrare]
#1072749
08/17/12 12:04 PM
08/17/12 12:04 PM
Posts: 5,447 So Cal
Sinitro
So Cal
What about the distributor and timing curve... A close friend and his 383 was overheating badly up to 225, he changed water pumps, added a shroud... Still a problem... I checked his Mopar performance distributor, he had 14 degrees mechanical advance... I reset it to 10 degrees mechanical advance, set initial @ 15 degrees and fired it up.. It ran @ 190 degrees and is doing very well in our 105 degree SoCal heat wave.. Check the basics... Mopar built a pretty robust engine and cooling system.. Just my $0.02...
[Re: 05dakota]
#1072750
08/17/12 12:12 PM
08/17/12 12:12 PM
Posts: 291 St. Louis
Imrare
St. Louis
do you have fan shroud?
Yes
[Re: Sinitro]
#1072751
08/17/12 12:15 PM
08/17/12 12:15 PM
Imrare
St. Louis
Just my $0.02...
Good point and easy to check, I will definitely check that out, thank you.
[Re: Sinitro]
#1072752
08/17/12 01:10 PM
08/17/12 01:10 PM
JohnRR
Just my $0.02...
Is this correct ? That would only be 25 TOTAL, I can see it running even hotter ?????
