Hoping to run the Aspen ***PICS ADDED***
#1072020
09/09/11 01:20 PM
09/09/11 01:20 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Heading out after work if all goes well! Here is the combo.. 1976 Dodge Aspen 468ci. W2 Small block 1050 dominator 2" 4500-4150 adaptor Victor W2 intake Econo W2's off of Brian's 360 (ou812) 52cc chambers (milled down to a closed chamber) 2.02 intake 1.6 exhaust T&D 1.7's .040" cometic gasket zero deck 13.3:1 compression 16cc reverse dome Ross piston 1.125" CD .748"/.714" lift Comp custom solid roller 276/284 @ .050" 110LSA with 2 degree advance built in. R3 tall deck 48 degree (673AD) 4.185" bore 4.250" stroke 6.300" rod 1-7/8"primaries 3.5" collector. Heddman Husler Headers 3" crush bent exhaust no X or H pipe Dynomax Ultra Flows with dumps 727 transmission reverse manual valve body Island Converters 8" (5500ish on this engine) BONE STOCK 9-3/4 Diff 3.23 cone style posi M/T ET Street 10.5 X 27" Not too sure what the car weighs yet, I would guess around 3450lbs. with me in it. I will run it with exhaust and open header'd as long as the stock diff last long enough to get the passes in feel free to guess both. If I missed anything let me know. -Kenny
Re: Hoping to run the Aspen tonight. Any guesses??
[Re: MIKES_DUSTER]
#1072024
09/09/11 02:01 PM
09/09/11 02:01 PM
StrokerAspen
Alberta Canada
3.23's????? Should MPH pretty good!!!
Yup, I am hoping it will help hold the stock diff together. It will likely leave like a dump truck.
[Re: thedriver]
#1072026
09/09/11 02:03 PM
09/09/11 02:03 PM
StrokerAspen
Alberta Canada
Medicine hat or swift current? I'll guess 10.5@ 132
Med Hat buddy! Are you coming out this weekend??
[Re: HardcoreB]
#1072030
09/09/11 03:44 PM
09/09/11 03:44 PM
StrokerAspen
Alberta Canada
Other than the rear-end that is a nice combo. Best of luck and I'll guess it'll run 132mph the first time out 'uncorked'.
Haha, yeah, there is definetly improvements that could be made, rear end, shocks, valve size, heads, intake, car. LOL
[Re: StrokerAspen]
#1072031
09/09/11 04:04 PM
09/09/11 04:04 PM
Posts: 20,697 in a cattle trailer down by th...
Guitar Jones
No time, that stock cone diff will be obliterated. OK, if it stays together I'm going to guess 10.23/130ish
[Re: MIKES_DUSTER]
#1072033
09/09/11 07:13 PM
09/09/11 07:13 PM
StrokerAspen
Alberta Canada
Kenny, What track you going too???
Medicine Hat, Alberta Canada.
http://www.mhdra.com/
Looking at their schedule, this weekend is Jet cars.... So, if I run after one of those, good chance the car will go into the wall. I hate racing on Jet car days...
-Kenny
[Re: Guitar Jones]
#1072034
09/09/11 10:17 PM
09/09/11 10:17 PM
StrokerAspen
Alberta Canada
Oh, thanks a lot eh. If it breaks, I'm blamin' you. Haha.
We are on the road now after a few snags. About an hour from the track. Had a nail in the front tire and every tire shop in town was busy of course. Before I loaded the car I took it out for a boot, and well, we have a severe traction problem, not a bad thing though, should hook fine at the track!
Then when I was loading the car, the header collector on the new headers caught the trailer and pulled a slip tube out. Murphy's law eh? So, once we get to the track we will have to pop it back in the collector. So, I'm not sure I will get a run in tonight or not, but if not, that's fine, we are planning on racing all weekend, or until the diff goes now that Guitar Jones ginks'd it. Haha
-Kenny
[Re: MIKES_DUSTER]
#1072036
09/09/11 10:40 PM
09/09/11 10:40 PM
StrokerAspen
Alberta Canada
Keep us posted!!!!!
Will do buddy! I have my phone on me all the time, so as the night goes on I will do my best to post any updates.
Hey Mike! You didn't guess yet.
-Kenny
[Re: StrokerAspen]
#1072039
09/09/11 11:31 PM
09/09/11 11:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm thinking in the 10.77 area at about 133... because you wont be coming out of the hole strong... JMO BUT dont break it... and .............have fun
