Re: Hoping to run the Aspen tonight. Any guesses??
[Re: MR_P_BODY]
#1072040
09/10/11 01:40 AM
09/10/11 01:40 AM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
I'm thinking in the 10.77 area at about 133... because you wont be coming out of the hole strong... JMO BUT dont break it... and .............have fun
I think your on to something there. The car left like a dump truck last year, so this time out will probably similar. I hope the 3.23's are a diff saver.
Tonight we didn't get to run yet, but the header is all back together. We took the exhaust off now so it will be ran un corked tomorrow. Stupid thing doesn't sound like a street car anymore though. ![](/ubbthreads/images/graemlins/tongue.gif)
[Re: StrokerAspen]
#1072041
09/10/11 12:19 PM
09/10/11 12:19 PM
Posts: 9,897 MI, usa
dvw
MI, usa
Heading out after work if all goes well! Here is the combo.. h dumps
Not too sure what the car weighs yet, I would guess around 3450lbs. with me in it.
If I missed anything let me know.
-Kenny
I'd like to see how you got it that light. Mine weighs 3875 with me (175lbs). Doug
[Re: MIKES_DUSTER]
#1072044
09/10/11 03:18 PM
09/10/11 03:18 PM
StrokerAspen
Alberta Canada
Well, time trials should start soon here.
Some new updates, the air is around 5000ft. I finally got to weigh the car, and it's lighter than I thought. 3130lbs with out me, 3330 with me. The car is all steel, engine is cast iron, and the bumpers are fiberglass now. The heater is gone, as well as power steering, power brakes and sway bar. also, the exhaust is sitting on the trailer.
Sorry for the wrong weight originally, but that was my best guess since the last time I weighed it.
-Kenny
[Re: StrokerAspen]
#1072045
09/10/11 03:32 PM
09/10/11 03:32 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
5000 ft is going to make difference, revised guess, 10.34 at around 132.
[Re: dragram440]
#1072048
09/10/11 05:42 PM
09/10/11 05:42 PM
StrokerAspen
Alberta Canada
Run number 2. 1.59 60' 6.88 @ 102 10.77@126.4Blew number 8 header tube off in high gear. 5200ft air now. Everyone else slowed down from their first pass a little
[Re: StrokerAspen]
#1072053
09/10/11 09:48 PM
09/10/11 09:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Run number 2.
1.59 60' 6.88 @ 102 [Email]10.77@126.4[/Email]
Well SO FAR I guessed the ET BUT I'm suprized it doesnt MPH higher with that gear..... good ET ![](/ubbthreads/images/graemlins/thumbs.gif) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MIKES_DUSTER]
#1072055
09/10/11 11:11 PM
09/10/11 11:11 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[Email]10.77@126[/Email] is pretty dead on...right??
Nope!, The MPH is high A 126 MPH is good for around a 10.5 ET
A 10.77 ride will MPH around 123 to 124.
[Re: Sport440]
#1072056
09/10/11 11:42 PM
09/10/11 11:42 PM
MR_P_BODY
Its got a 3.23 in it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1072057
09/11/11 12:28 AM
09/11/11 12:28 AM
StrokerAspen
Alberta Canada
I have a theory on the MPH. This converter is super loose. It is at 6000 right out of the hole. I am clicking into high gear at about 900ft. It's slipping way too much up to because I can't get any rpm up top.
I Had a close call today... The air started getting better. I lost first round, so I was running the buy back round. The car ran a 10.76 on a 10.75 dial. Then a 10.75 on a 10.75. Then a 10.70 on a 10.70. That got me to the final. I pulled into the burn out box, and pressed really hard on the brake pedal. I heard a ping, and the pedal hit the floor. Lost the codder pin and the brake pin popped out.
So, I lost the round, which was a shame because the other guy broke out, but I am glad it happened in the burn out box and not the top end of the track.
So, best time was a 10.70 @ 127mph.AND, it ran a 1.55 60 foot haha. I think that last run would have been a 10.6x but what do you do eh?
I will make more runs tomorrow as long as high gear holds up
[Re: StrokerAspen]
#1072059
09/11/11 01:07 AM
09/11/11 01:07 AM
MR_P_BODY
You are probably right on the slippage in the conv... just doesnt get much time locked up... nice job... yeah, lucky that pedal quit in the box(but then again you probably wouldnt have been pressing that hard on top end) ![](/ubbthreads/images/graemlins/wave.gif)
