LCA Bushings Removal #1071901
09/09/11 11:37 AM
09/09/11 11:37 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Anyone have any tricks for pressing out the LCA bushings? I don't have a press, so maybe someone has a good tip.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: LCA Bushings Removal [Re: Erik] #1071902
09/09/11 12:00 PM
09/09/11 12:00 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
take them to a auto machine shop. they have the proper tools to do the job.
I am truckless..
Re: LCA Bushings Removal [Re: 340SHORTY] #1071903
09/09/11 12:22 PM
09/09/11 12:22 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I did, and they had them for almost two months and did nothing other than let them sit on the floor. Hence why I have them at home and will do them myself.
Re: LCA Bushings Removal [Re: Erik] #1071904
09/09/11 12:34 PM
09/09/11 12:34 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Thanks!
Yep, read this tech article.
http://www.moparmusclemagazine.com/tipstricks/155_0306_control_arms/index.html
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: LCA Bushings Removal [Re: hemi71x] #1071905
09/09/11 12:41 PM
09/09/11 12:41 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
without a good press I don't know how you would get them back together
my advice, find a different machine shop
I'd do them for $100 but the postage would kill ya
Re: LCA Bushings Removal [Re: hemi71x] #1071906
09/09/11 12:44 PM
09/09/11 12:44 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks. I already pressed out the pivots, but don't remember the inner sleeve of the bushing coming out with them. I'll check this weekend.
I already removed/installed the UCA bushings using hand tools made for that purpose (you can get them at Mancini). I will use them to install the LCA bushings, too. Getting the old ones out is the problem.
Re: LCA Bushings Removal [Re: Erik] #1071907
09/09/11 01:10 PM
09/09/11 01:10 PM
It's a dry heat
It's a dry heat
Uppers are a piece of cake and can be R+R'd in a bench vice with sockets to press into and out of.
But on the lowers -
99% of the time the outer sleeve stays in .
I use an air chisel to cut a slit in the side of the sleeve and pull it out.
Press the new bushing in the arm, then support the bushing fron the backside when pressing the pin back in or you will push the rubber/inner sleeve out of the bushing out the backside.
trust me, been there done that
Re: LCA Bushings Removal [Re: Erik] #1071908
09/09/11 06:01 PM
09/09/11 06:01 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks!
No mention of replacements?...if your going with Poly (which I recommend) you need to leave the other bushing shells in the LCA, I just usually torch the rubber out, leaving the shell, then glassbead the assy, then paint, or cosmoline, or both,...the poly bushings just slide in with lube, depending on the poly bushing of choice some require the inner sleeve stay on the pivot shaft as well, that installs by hand with lube as well,...so basically with poly you just need to burn out the rubber, and clean up the assys/install bushings by hand...
if your doing factory style, I still like to torch out the rubber, collaspe the outer shell in the LCA to remove, and carefully grind a slot on the inner sleeve to remove the inner shell from the pivot shaft,....a press is the only correct way to install a new bushing,....do the poly, you'll never look at a factory bushing again
Re: LCA Bushings Removal [Re: gtx6970] #1071909
09/09/11 06:09 PM
09/09/11 06:09 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
I paid a guy to do that for me once ... then I bought my own press and tools and never looked back.
These things are money when it comes time to change an LCA bushing http://www.americanmuscle.biz/23501_Lower_Control_Arm_Bushing_Sleeve_Remover_ABE_p/23501.htm
Everybody makes fun of a hillbilly until they need something fixed
Re: LCA Bushings Removal [Re: B_Body_Bob] #1071910
09/09/11 08:55 PM
09/09/11 08:55 PM
hemi71x Offline
hemi71x  Offline
The American Muscle, lower control arm bushing tool works well, but your still going to need a hydraulic press to put everything back together.
Re: LCA Bushings Removal [Re: DAYCLONA] #1071911
09/12/11 04:13 PM
09/12/11 04:13 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks!
Yes, the new bushings are poly. The ones I have are complete with shells, so I need to get the old shells out. All that is left in the control arm at this point is the outer shell. The old rubber pulled right out with no problems.
Re: LCA Bushings Removal [Re: hemi71x] #1071912
09/12/11 04:15 PM
09/12/11 04:15 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I just received that last week. I was looking at it over the weekend to figure out exaclty how it fits in there to pull out the shell. I think I understand how it works, but didn't try it yet.
Re: LCA Bushings Removal [Re: Erik] #1071913
09/14/11 10:45 PM
09/14/11 10:45 PM
Middleboro,MA
Jopar Offline
Jopar  Offline
Middleboro,MA
Erik,
Piece of cake! I purchased the American muscle car tools from the car shop online and removed mine last week. Years ago on another vehicle I tried to use a chisel per the Mopar service manual and it was ugly.
If you do not have a press bring your lower control arms to a good parts store to press out the pivot first and it will take you about 10 minutes with the right tools. I attached a picture to show you what they look like.
Joe
Re: LCA Bushings Removal [Re: Erik] #1071914
09/16/11 12:06 PM
09/16/11 12:06 PM
southern illinois
O
ozz383 Offline
ozz383  Offline
O
southern illinois
I've done a few once your down to the shell I take the mig and run a few beads down the inside and let it cool. after cooling they will usually just fall out.they will shrink that much. You can also weld pressed in bearing races and they will do the same thing.I have tried the chisel and made more work than it was worth also have used a die grinder with deburring ball to slit and then pull out but the welder is by far the easiest way I have found. a machinest friend showed me how back when I had to turn wrenches for a living. MUCH EASIER. ozz
Re: LCA Bushings Removal [Re: Erik] #1071915
09/16/11 01:07 PM
09/16/11 01:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
OT a little, to get the inner sleeve off the pivot pin, use the round part of a ballpen hammer and hit em a few times, It will expand the sleeve and it will come right off.
For the outter sleeve I weld some washers in there and between the heat and having something to push against, the sleeve comes out much easier.
Good luck with it.
Re: LCA Bushings Removal [Re: Erik] #1071916
09/16/11 01:11 PM
09/16/11 01:11 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
You can notch/cut the inside of the LCA sleeve with a sawzall. Then a hammer and chisel or air chisel to fold the outer lip into the center of the sleeve and it will fall out.
If you have a press, remove the inner sleeve and bushing, then put a washer almost the size of the ID of the outer sleeve into the sleeve. Take an air chisel and fold over the lip of the outer sleeve to hold the washer in place. Then press it out. The washer should come out once the sleeve is off the LCA.
Re: LCA Bushings Removal [Re: Erik] #1071917
09/23/11 12:06 AM
09/23/11 12:06 AM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
If you don't mind driving to Easton, I always used these guys for machine work when I lived there.
Sigafoos Machine Shop
1031 Spruce Street, Easton, PA 18042-4253
(610) 252-6250 ‎
Re: LCA Bushings Removal [Re: Erik] #1071918
09/23/11 01:56 AM
09/23/11 01:56 AM
N
newem Offline
newem  Offline
N
Put it in a vice, take the blade off a hack saw, put it through the sleeve, reattach blade to hacksaw... then cut the sleeve out. I remember seeing a guy do it that way in a YouTube video awhile back.
Re: LCA Bushings Removal [Re: newem] #1071919
09/23/11 02:03 AM
09/23/11 02:03 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Try that & you'll be cutting the control arm... There is a step between the back of the pocket that receives the bushing & the pocket that receives the torsion bar...
Re: LCA Bushings Removal [Re: 1_WILD_RT] #1071920
09/23/11 02:18 AM
09/23/11 02:18 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
<> diamond shape tip chisle, split it inward then down the inside, use a punch or drift to "collapse" it and then it will drive out no problem
