Re: wind sheild wiper problems
[Re: fatdaddyadam12]
#1071201
09/08/11 02:02 AM
09/08/11 02:02 AM
RapidRobert
Welcome aboard. Back click to the main index & click on "all other mopars/amc" & then click on parts wanted & might put an ad in 4 what you r after w a descrip
#1071203
09/08/11 08:19 AM
09/08/11 08:19 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Hi new guy here I may be posting in the wrong forum if so please forgive me. I need part number 3799292 its the hub that goes on my 78 Aspen wiper motor. Its on the end of the arm that goes from the motor to the wiper assembly. Any help is greatly appreciated ADAM
welcome aboard! you might want to send a pm to a member here - julesdawiperman - he is very knowledgable when it comes to wiper stuff and parts. he might be able to hook you up!
#1071205
09/08/11 11:08 AM
09/08/11 11:08 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Is it the white (probably cream-ish to yellow by now) nylon bushing which joins the wiper motor arm and wiper transmission linkage you need? If it's the small bushing you need, you can get those in a package from your local parts store for under $8.00.
If the bushing is the circular, 1" diameter piece that late B-bodies also used, that's not going to be easy to find.
