Re: Build me 850 HP in most economical package
[Re: fishy340]
#1070001
09/07/11 09:50 AM
09/07/11 09:50 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
i remember muscle motors had a BIG ci 600+ inches made well over 900hp and tq was crazy for like 18g's PUMP GASSER...dont know if anyone bought one,but from reading about it,it sounded nasty.
We have one coming together during the winter. It's not exactly their crate, the camshaft and CR are slightly bigger because of our 93 octane pump gas, and the heads are ported. It will be dynoed locally onve ready, I would be highly surprised to see it make 900 hp despite of the advertising. But if it does, I sure will be happy!
Plynouth VIP '67 TT IC EFI
[Re: Chad Bittle]
#1070002
09/07/11 04:32 PM
09/07/11 04:32 PM
Posts: 3,456 Out West
408strokerdart
Out West
I think a Koleno low deck block at about 540" would fit the bill nicely at your race weight. To much torque might be a bad thing. All you would need is enough cyl head to support about 1.6 hp/ci. Easily done with a B1 original or even an Indy 440-1 head. Do yourself a favor and go to a terminator on alky and your car will be deadly with the glide. With your command of the tree, I will follow you around with the wheelbarrow to help haul the cash.
I don't think alcohol would be good for lonnie....car will never be warm in time since he's usually running back from either sportsman, pro, no box, big wheel class, foot race event or tryin to remember where he put his dads tools.
Oh and Lonnie, we knew this day was coming, haha. Good luck with your new build.
Just add their "primer plus" system and warm up is no problem and he can save some nickles on gas while idling thru the pits.
[Re: AndyF]
#1070003
09/07/11 08:02 PM
09/07/11 08:02 PM
Posts: 621 Iowa
coronetville
Iowa
[Re: wheelsup68dart]
#1070004
09/08/11 12:15 AM
09/08/11 12:15 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Looking to step up to the 8.50's in 1/4 next season, not gonna do it with the small block. I believe 850 flywheel HP will get me there at 2650 lbs. Starting from scratch, how would you get there? Car will be BB, RB, with power glide and Dana 60 4.88 gear.
Does it weigh 2650# with the small block? If it does, you will be @ 2800# with the BB..
Wallace says 900 hp in perfect conditions, and drag coefficient..
IMO.. You are going to need close to 1000hp to do this. B1 MC's all the way and the biggest you can build....
If 8.50's were that easy in a Mopar.. A lot more guys would be doing it. Plus.... In bad conditions you'll need the extra hp.
Al Alguire's Barracuda just gets that 8.50 mark in 3500'- 4000' DA 2800 lbs. and his B1 MC (really actually) makes over 1000 hp.
Doesn't Fred's 588" barely run 8.50's with 2 Dominators..
You could always put a Rat Motor in it and go plenty fast...
I'm just saying.. It's not that simple..
You wanted something to think about..
Chris..
[Re: HEMIFRED]
#1070006
09/08/11 03:11 AM
09/08/11 03:11 AM
Chris'sBarracuda
Arizona
It's an example of a build done for a variety of reasons besides power. The long list starts with longevity,reliability and low maintainance. We can gain close to 40 HP with a better intake than the present5 cast.We need more plenum. It's running the same exact cam transplanted from one to another in my last three motors. A Crane R-396 ground in 1971 much smaller than it can take with only .730 lift. Probably could make 80 HP overall with a few changes.
Not disrespecting your combo Fred..
I'm merely pointing out that you can't just throw parts together and go 8.50's in a full bodied door car NA..
Like I said.. 8.50's is fast NA, and if it was easy, there would be a lot more guys doing it..
And it will take more than 850 HP to do it.. Quite a bit more..
Chris..
[Re: bwdst6]
#1070009
09/08/11 08:10 AM
09/08/11 08:10 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
More people don’t do it because they don’t have the money!
8.50's in a door car and economical don't belong in the same sentence (especially Mopar powered)
Rickster
[Re: Chris'sBarracuda]
#1070011
09/08/11 12:17 PM
09/08/11 12:17 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
Chris..
That would be Perfect, cause then I do not need ballast for super street, the 8.50 was a guideline for ET, but I would be plenty satisfied with anything between 8.50-9.00 and somewhere in the 5.65-5.75 1/8th mile. I think the aluminum block may be needed to not make weight go to high.
#1070013
09/08/11 12:39 PM
09/08/11 12:39 PM
Posts: 10,091 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The aluminum block makes sense because you will have a similar weight distribution, may even need to add ballast to the front as opposed to trying to make a nose heavy car work. Your last post said you are OK with an ET in the 8.998 to 8.50 range. That opens the door some! The heads you could use would be a well ported set of 440-1s,3x intake, 540 cubes 4.500 bore 4.25 stroke,terminator on methanol, Jesel rockers with 1.70 ratio, cam 283/288/110 in at 108 .775 to .800 intake lift, 15/1 compression with very small dome(i cut my heads to 62cc) 2 1/8 x 32 x 4 headers. Use a vacuum pump and .043 rings low ten oil, a good pan and this motor will take you to 8.80s on the bad days. I run 8.89 at 150 mph with a DA of 2200 ft at 3020 lbs with the same combo except 528 cubes using a 4.15 stroke. Run a 4.10 gear or 4.30 at the most, you won't need anything higher. A 4.10 will allow you to run a 14 x32 light weight Goodyear supergas tire, which should make the car faster. I am running a 40 lb 15.1 x 33.6 tire and it slows the car some.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: 440Jim]
#1070014
09/08/11 01:05 PM
09/08/11 01:05 PM
Posts: 2,578 sweden
1Fast340
sweden
Give that aluminum BB consideration. Like I said about chassis balance. And remember the aftermarket cast iron blocks are heavier than the factory cast iron, so it can add a lot of weight, hence aluminum block.
I don't have exact numbers, but a new cast block is around 300 pounds $2900-$3900 (MP-Koleno) and the aluminum ones 140 pounds $5000.
your post got me thinking here.. lots of people think aluminumblocks are just way to expensive but looking at it like that makes me think it may be the cheapest way to loose 160lbs you can find
[Re: LUMI]
#1070015
09/08/11 02:49 PM
09/08/11 02:49 PM
Posts: 627 IN
BIG BEAR
IN
do it like my engine has been done
Venolia 4.5 pistons, Callies 4.77 Crank, 6.8" H beam Rods, Koleno KP440 Block, out of the box Koffel B1 Original Heads, B1 intake, 1050 Holley Dominator, Crane Mec Roller 320/328deg 114 disp angle int .79 ex .76 with 1.7 ratio, CR10.69
dynoed at Koffels Place and with Shell 93 Octane Pump fuel
Hopefully she treats you well
#1070017
09/08/11 07:16 PM
09/08/11 07:16 PM
Posts: 1,050 San Jose Ca.
boatracer572
San Jose Ca.
540 CID (4.5 bore 4.25 stroke) unported predator heads, single 1050,solid flat tappet cam( non roller) will get u 850+ hp. And there is tons of room to grow.
[Re: AndyF]
#1070019
09/08/11 07:56 PM
09/08/11 07:56 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
aluminum blocks weigh what 150 less but supposedly make less power on the plus side easily repairable and new sleeves a cinch to get done. larger return when selling.
home of the Sox and Martin Hemi Duster
#1070020
09/08/11 07:59 PM
09/08/11 07:59 PM
Chris'sBarracuda
Arizona
Chris..
You'll most likely use the Indy block, as BG is a WD for them.. Not my first choice.. But better that World IMO.. KB is tops..
If you go B1's, (strongly recommend), Koffel has his sale starting in Nov. MC's included.
The bigger, the better on the motor, as you can keep the rpms down.. Doesn't cost any extra, if you don't go crazy..
My 540" B1 has gone 8.70's @ 153, 3000# over 2800' DA.. It dynoed @ 972hp on one dyno and 948hp on another..
Still working on converter.. Have 4 so far.. PG's are great once you find that magic converter..
I think Al is on #6 converter..
It's all fun though.. Going 10.90 @ over 150mph..
Chris..
