Re: Need help trying to prime the oil system. Update [Re: JohnRR] #1069841
09/06/11 02:41 PM
09/06/11 02:41 PM
KC KS or Punta Gorda FL FL
VOABIRD Offline OP
VOABIRD  Offline OP
I'm getting oil to move through the engine but I hear gurgling and hissing under the intake manifold while priming and it never really builds up much pressure. the gauge does not register any pressure either. I have a new Mopar filter on and threw the Fram I had on it away when the problem occurred away.
Re: Need help trying to prime the oil system. Update [Re: VOABIRD] #1069842
09/06/11 03:22 PM
09/06/11 03:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like you need to pull the intake and valley pan to see where the noises are coming from.
Re: Need help trying to prime the oil system. Update [Re: stumpy] #1069843
09/06/11 03:30 PM
09/06/11 03:30 PM
X 2, time 2 dig further
Re: Need help trying to prime the oil system. Update [Re: RapidRobert] #1069844
09/06/11 03:33 PM
09/06/11 03:33 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
X3
UPDATE Need help trying to prime the oil system. 9-9-11 [Re: JohnRR] #1069845
09/09/11 05:26 PM
09/09/11 05:26 PM
VOABIRD Offline OP
VOABIRD  Offline OP
Good news. I could not build any oil pressure when I tried priming the engine with a drill through the distribuitor. I kept hearing gurgling and hissing under the intake manifolf. After 2 days I thought about trying to drink through a straw with a hole in it and decided to pull the oil pan. The oil pick up tube was cracked where it threads into the block and broke off when I touched it.
A trip to the auto parts store for 2 pan gaskets and a $17.50 pick up tube and the bird is running. Thanks to everyone for their advise.
Re: UPDATE Need help trying to prime the oil system. 9-9-11 [Re: VOABIRD] #1069846
09/09/11 07:54 PM
09/09/11 07:54 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
the pump turns counter-clock wise,so you want to run the drill in reverse.
Re: UPDATE Need help trying to prime the oil system. 9-9-11 [Re: VOABIRD] #1069847
09/10/11 07:27 AM
09/10/11 07:27 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Hmm. Thought it might be that but as I mentioned, I have only seen that happen twice in over 35 years. Now it's three times. Just as a note, looking at a number of pickups over the years some seem to have rolled threads that end with a smooth transition and some seem to be cut where the end of the thread is sharp. Both failures I've personally seen had the sharply cut threads and the failure appeared to have started at the end of the thread.
