Re: Zink Phosphate..How do you do it ???
[Re: THESHAKERPROJECT]
#1068974
09/04/11 12:10 PM
09/04/11 12:10 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I built a tank & welded a bung for a 220v water heater element into it....
#1068976
09/04/11 12:52 PM
09/04/11 12:52 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
There are plenty of 110 heater elements.. The trick will be finding a glue that will bond to the barrel & steel effectively... Might be able to fab a couple steel plates to weld a bung in & sandwich the barrel then you'd just need to find a sealant & that shouldn't be to hard.... Oh yeah you need to make a guard to protect the heating element..
[Re: 1_WILD_RT]
#1068977
09/04/11 02:39 PM
09/04/11 02:39 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I use machinist tool black, heres a crummy pic of the horn bolt, works fine
[Re: ademon]
#1068979
09/04/11 06:43 PM
09/04/11 06:43 PM
Posts: 1,172 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
Yeah, the tool black is the same stuff Eastwood sells and is not a zink phosphate coating . It does look OK but real zink phosphate is more of a flat greyish/black coating. Im actually working on a lot of GM (Oldsmobile)parts these days.
#1068980
09/04/11 09:52 PM
09/04/11 09:52 PM
ademon
IL, Aurora
the bolt came out nice greyish/black compared to the horn bracket that is freashly painted satin black.
[Re: burdar]
#1068984
09/06/11 02:41 PM
09/06/11 02:41 PM
Posts: 1,072 Louisville, KY.
Scottmon
Louisville, KY.
Zinc phosphating is the same thing as Parkerizing on guns. Go to Brownell's and order up a Parkerizing kit.
