Re: FBO Ignition system toubleshooting
[Re: Ronnman]
#1068590
09/06/11 06:26 PM
09/06/11 06:26 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
You have 12 volts on both terminals because its is not being grounded by the ECU. The ECU may not be receiving a signal from the distributor module or the ECU has a problem, maybe grounding as mentioned, or is bad. If you disconnect the distributor 2 prong connector and tap the male connect on the harness side that goes to the ECU, that should trigger the ECU to fire the coil.
You are reading the "dead end" 12V on both terminals because there is no current flow. If no current flow through a resistor (coil) the voltage drop will be zero, thus the presence of 12V on each terminal. Ron
That is 100% correct. To add if the ballast was bad you would not have voltage to the coil as it goes thru the ballast in the run position. And you said it read .9 ohms. Do the test where you touch the male end of the dist harness to ground and see if it sparks. If it dont you need the ECU and it it does its not seeing the dist signal. Ron
[Re: 383man]
#1068591
09/06/11 06:34 PM
09/06/11 06:34 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
what he said and did you find out what ohm the ballast is supposed to be? did you make sure the ECU is grounded?
[Re: mikemee1331]
#1068592
09/06/11 07:40 PM
09/06/11 07:40 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Ok, I was trying to learn to trouble shoot with the ohm meter and look at stuff. Don at FBO I was talking again this afternoon and done some more trouble shooting and we ended up trying another box that I had on my dad's van that wasn't too old. It fired right up so it was the box. Once running the positive side of the coil had 6 volts on it. Why the RC read differently than my shotbed I don't know.......both work so.
Anyway he cut me a deal on one of his newer units & sent it out the door today. Thanks Don.
Thanks everybody for your feedback.
Moparlee
[Re: mikemee1331]
#1068595
09/06/11 08:18 PM
09/06/11 08:18 PM
Robbins
Joplin, MO USA
Well, it (ballast) worked with a different brain box. So.........I'm not sure what it should ohm out to. Today is was reading 1.2 where the other day it was .9 This is my Fluke meter.
The newer system doesn't require a ballast and he says to tie them together, I would probably do a nice jumper so I can go to regular system on the fly if need to.
Just so you know he says that you can run the older box with the older and the newer style for 30 minutes or so to get home if need be.
Moparlee
[Re: Robbins]
#1068598
09/07/11 07:44 AM
09/07/11 07:44 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
""i think you should call him and make sure the coil he sold you is a true 12v or is internally ballasted (is that a word?)""
The new FBO coil #HR688 is a true 12v coil. (Reference, the coil can be mounted in any direction, per Don.) It looks just like the old FBO coil (size and shape) except for the writing on the coil is different. The old coil/ECU could handle 12v for a short time period (Don designed it this way for his drag car) and the new coil/ECU was designed for 12v all the time. I know for a fact that the new coil and the old coil are not the same unit. I started emailing Don in the Spring of 2010 to see if he was going to come out with a 12v coil and he had already been testing one for a while. Last fall (2010) when I wanted to swap to a 12v coil, I emailed him again about his 12v coil and it was still not ready. Then this past Spring I emailed him again and it was being tested but still not ready. This past Summer he started selling them and I now have one and I have been running it now for about 6 weeks. Don's ignition parts may be a little more expensive, but Don sells a very nice Mopar ignition system.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: mikemee1331]
#1068601
09/25/11 08:32 AM
09/25/11 08:32 AM
Robbins
Joplin, MO USA
I haven't called him yet, but the new box is on and working here are a couple of pictures of the newer box.
Moparlee
[Re: NachoRT74]
#1068607
09/25/11 11:07 PM
09/25/11 11:07 PM
Robbins
Joplin, MO USA
.....that's just messed up. Who ever posted that on that site......thanks for the heads up.
Moparlee
[Re: Robbins]
#1068608
09/26/11 12:04 AM
09/26/11 12:04 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
maybe IS TRUE the GM HEI module inside is nothing like a stock unit and really a Performance piece, but still on that way!!! I still can get a Performance GM kind HEI unit ( Moroso or Accel like I have foudn on the ebay ) and built into a stock original box like I posted there
