Re: After 8 years my 71 340 Duster is off for paint & body!
[Re: NV69B7RR]
#1068165
11/07/12 11:17 PM
11/07/12 11:17 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
LOVE it! looking real good. whos restoring your carb?
"I know a guy"
So when are you planning on having it finished?
I'm hoping for summer, my free time ain't what it used to be.
[Re: ScottSmith_Harms]
#1068167
11/08/12 11:12 AM
11/08/12 11:12 AM
Posts: 1,152 Colorado
CuriousYella70
Colorado
Underside shot, after this shot they did a (very small) bit of touch up in a few spots adding paint to make it match the original over spray
What was the point of spraying the bottom black? Why did the factory do that? If it was undercoating, I could understand why but why black paint?
[Re: CuriousYella70]
#1068168
11/08/12 12:16 PM
11/08/12 12:16 PM
Posts: 409 PEI Canada
chromedome426
PEI Canada
The factory didn't actually PAINT the bottom of the car black. The bottom of the car was dipped into a tank of a protective coating that was black or dark gray. That is why our cars have all those drain holes in the floor pans and frame rails.
[Re: UCUDANT]
#1068171
11/08/12 09:02 PM
11/08/12 09:02 PM
Posts: 16,169 Mesa, Arizona
dart4forte
Mesa, Arizona
For those following this post, Washington state just leaglized the casual use of canibus so expect this build to take a little longer than previously expected
I don't think so
[Re: Shoozy]
#1068178
11/19/12 02:10 PM
11/19/12 02:10 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Great! Now start throwing parts at it! Did you get your k frame/front suspension stuff figured out?
No not yet, still thinking about options.
Meanwhile I'm just going to build a stock setup to get the car on the ground. I'll be using all Moog parts and rubber bushings, etc. throughout, but with 73-later spindles and BB disc brakes with BB 14" Rallye wheels. I am also building a second 8.75 rear end that I bought, I'll be using a new Dr.Diff Center section and BBP axles for the 14" BBP wheels and reproduction Goodyear Polyglass tires, and will be using stock rebuild leaf springs.
So, basically I'll have:
One setup that's all NOS parts and the stock SBP KH disc brakes, assembled, detailed and bagged, and a set of SBP Rallye wheels to go with it.
The stock original looking setup with Moog parts and a few small mods like brakes and wheel BP, going under the car for now as described above.
Then a 3rd setup with all of the upgraded handling componants which I'll install later on once I decide on the combo.
#1068179
11/19/12 02:23 PM
11/19/12 02:23 PM
CuriousYella70
Colorado
lol so explain the reason for 3 different setups? I'm assuming one is to make sure the car is fun to drive and drive smoothly. I'm assuming the stock one will be in case you ever sell it and then you'll install that setup?
