Page 7 of 19 1 2 5 6 7 8 9 18 19
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068045
09/23/12 08:30 PM
09/23/12 08:30 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: NV69B7RR] #1068046
09/25/12 11:18 PM
09/25/12 11:18 PM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
Can't wait to see it painted!!!
Wilson
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: MUSLCA] #1068047
09/26/12 09:30 PM
09/26/12 09:30 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
One last step before putting the doors back on, checking final gaps and alignment, then a final block and mask....
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068048
09/26/12 09:31 PM
09/26/12 09:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068049
09/27/12 09:46 AM
09/27/12 09:46 AM
Colorado
CuriousYella70 Offline
Colorado
Are you going black instead of the original GY3? Or am I under the wrong assumption that only the upper/lower panels of the door got painted gloss black and the rest was body color?
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: CuriousYella70] #1068050
09/27/12 09:50 AM
09/27/12 09:50 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
He will tape off the black portion before painting the yellow
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: CuriousYella70] #1068051
09/27/12 09:51 AM
09/27/12 09:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, it will be GY3, the upper and lower doors were black, afterwards those areas will get masked off and the yellow will cover the rest.
*Adam beat me too it
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068052
09/27/12 10:21 AM
09/27/12 10:21 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Is there a certain shade or tone to the black? My roadrunner is going base coat clear coat and I have to buy the black, so should I just get some black base for these areas?
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: moparpollack] #1068053
09/27/12 10:28 AM
09/27/12 10:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I am having my car painted in single stage (similar to what the factory used) so the black on my doors is just plain old TX9 black single stage.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068054
09/27/12 10:34 AM
09/27/12 10:34 AM
Colorado
Colorado
I thought so but wanted to make sure - thought you might be going black on black instead of the GY3
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068055
09/27/12 10:40 AM
09/27/12 10:40 AM
85086
Lil Herman
Lil Herman
85086
High or low gloss? My only question is I have only seen car when they were already 20 years old and had wear on them.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: moparpollack] #1068056
09/27/12 10:45 AM
09/27/12 10:45 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Mine was done in base clear so it was gloss. I sprayed the black base, masked it off sprayed the color and cleared it all at once.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: AdamR] #1068057
09/27/12 10:53 AM
09/27/12 10:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Factory was gloss, but keep in mind, single stage enamel does not offer the "shine" that a base clear does, but only one is "correct", choose whichever suites your tastes. Also, for 340 Dusters with the V24 hood blackout, the upper door frames (coded 5X8) were painted in a unique low gloss charcoal finish to compliment the matte finish blackout on the tops of the outsides of the doors. See attached pic for example of codes
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068058
09/27/12 01:53 PM
09/27/12 01:53 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
What's the car look like that that tag was attached to???
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: RSNOMO] #1068059
09/27/12 02:07 PM
09/27/12 02:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Rough but saveable. I looked it over in person, it was in Utah, bare rusty #'s engine block in the trunk, non #s trans, rusty quarters, hit in the front caused a bent frame rail forward of the shock tower, most front sheet metal replaced from accident, most rare/expensive 71 only 340 parts were missing or heavily damaged. As good as it looked in pics it was a total basket case. If it had the #s trans I would be the new owner but I passed, Neat car but he was asking too much for it's condition and incomplete numbers matching status. He eventually lowered his price and a guy from Texas bought it.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068060
09/27/12 02:08 PM
09/27/12 02:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
What you see here is the replacement 318
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068061
09/27/12 02:09 PM
09/27/12 02:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
rear
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068062
09/27/12 02:09 PM
09/27/12 02:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
dash
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068063
09/27/12 02:10 PM
09/27/12 02:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
etc.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068064
09/27/12 08:27 PM
09/27/12 08:27 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Lotsa work to make that one nice...
