Re: Searching for an imposible part for a 64 dodge d100 [Re: chrisf] #1066917
09/03/11 12:19 PM
09/03/11 12:19 PM
Finally a HUSKER again
Moparnut426 Offline OP
go to the sweptline websites, you will get more usefull info than you will get here
Been there, done that, got nada....
Kasey
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066918
09/03/11 12:30 PM
09/03/11 12:30 PM
Heres the truck on the registry, I forgot Chris registered it.
In one of the pictures you can see the bezel needed.
http://benjamin_simons.tripod.com/css/65D100CSSHPP_CAlexander.html
Kasey
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066919
09/03/11 01:21 PM
09/03/11 01:21 PM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
Have you tried the sweptline club? Lots of knowledgeable people here, and a few used parts specialists.
http://www.sweptline.org/
Mark
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066920
09/03/11 03:40 PM
09/03/11 03:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kasey
Seems like you have hit all the stops , why not just send it out to have the one you have redone ?
Re: Searching for an imposible part for a 64 dodge d100 [Re: JohnRR] #1066921
09/03/11 06:27 PM
09/03/11 06:27 PM
That question was in my origional post, I dont know where to take it to have it restored. Its a pot metal.
Kasey
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066922
09/03/11 07:38 PM
09/03/11 07:38 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Check with MCB or GCAR and see what they say. Google them.
Re: Searching for an imposible part for a 64 dodge d100 [Re: RoadRunnerJD] #1066923
09/04/11 07:12 PM
09/04/11 07:12 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
How about this one ?
Re: Searching for an imposible part for a 64 dodge d100 [Re: stateline] #1066924
09/04/11 08:39 PM
09/04/11 08:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
FINALLY ...
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066925
09/05/11 12:22 AM
09/05/11 12:22 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The one linked to above, listed on eBay was a shifter I pulled from a Class A motorhome, and it does use a different bezel than both A-series vans and pickups, and Sweptline era trucks.
Re: Searching for an imposible part for a 64 dodge d100 [Re: stateline] #1066926
09/05/11 01:12 AM
09/05/11 01:12 AM
That one looks close. Do you have the measurements of the distance from the edge of the stop tit, and the edge of the inside bezel.
Kasey
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066927
09/05/11 12:11 PM
09/05/11 12:11 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Is the transmission in the truck a cable shift like the pushbutton cars? If so, then you need a '64-65 shifter. I don't think the later lever shift ones are the same.
I think there was a '64 dodge truck in the junkyard on Saturday but I didn't pay attention to the shifter or if it was an automatic.
Re: Searching for an imposible part for a 64 dodge d100 [Re: NicksGarage] #1066928
09/05/11 04:23 PM
09/05/11 04:23 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Now that I think about it, was the dash shifter available? I always see push buttons in early trucks, never seen a 68 style dash shift.
Re: Searching for an imposible part for a 64 dodge d100 [Re: wally426ci] #1066929
09/05/11 04:58 PM
09/05/11 04:58 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
It looks like '64 was a pushbutton shifter on the left side of the dash. This would mean that you probably have a one-year piece there.
Re: Searching for an imposible part for a 64 dodge d100 [Re: NicksGarage] #1066930
09/05/11 06:42 PM
09/05/11 06:42 PM
Accually this truck is a 64.5, and the center mounted shifter like we have was used through out the 63, 64, 65, 66, 67, and 68 trucks. I just dont know the split from the wide shift arm like we have and the narrow shift arm which seems to be more common. The mechanism has 2 cables, one for the shifting, and pne for park alone I believe. I know it was a night mare to dial inn with the shifter. Has a threaded collet, and a round dial and you adjust it like a bike clutch/brake cable in a way. It just hangs out of the tranny case and points to the rear.
Kasey
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066931
09/05/11 10:04 PM
09/05/11 10:04 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Kasey
A 2-cable shifter would have last been used in 1965. The gate is probably different from the later single cable ones. The transmissions starting in 1966 are lever operated and park is engaged with the same lever that does the other gear positions.
The 1964 CSS brochure shows a push button shifter. See this page - http://www.cssregistry.com/css/broch.html
I also looked at all the 1964 trucks on that site and they all have pushbutton shifters. Some cars had console shifters for the first time in 1964 and probably the 1964 A100 but it doesn't look like pickups did.
Re: Searching for an imposible part for a 64 dodge d100 [Re: NicksGarage] #1066932
09/06/11 12:39 PM
09/06/11 12:39 PM
Kasey
Like I said this truck is VERY 1 off, and rare. I know for a face that Ned, the man who ordered the truck ordered it very wierd. This truck also had a painted tranny. Bith the engine and tranny were painted chrysler engine bluegreen color. we had a guy in the registre look up the truck, and was pretty interested in the truck as it was optioned out so wierd. When we told him the tranny was painted green also, he was really interested. I have some pictures I can post.
Kasey
Re: Searching for an imposible part for a 64 dodge d100 [Re: Moparnut426] #1066933
09/06/11 10:04 PM
09/06/11 10:04 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Some pictures of the bezel and shift lever would be good.
Is there a part number cast into the backside of the bezel you're looking for?
Re: Searching for an imposible part for a 64 dodge d100 [Re: In_The_Pink] #1066934
09/06/11 10:46 PM
09/06/11 10:46 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
This is taxing my memory A LOT, but I remember visiting family out of state sometime between 1965 to 1968, can't remember for sure. I saw this beautiful mid 60's Dodge truck pull out of a gas station and boil the hides like a John Force burnout. Turns out it was a 426 HP truck special. I saw one for sale on the net, don't remember which site. Maybe perhaps that is what you have and that's why it's different? Don't know, just a guess on my part. Good luck finding what you need. Seems like I may have read about them too in a Dodge pickup truck book.
Re: Searching for an imposible part for a 64 dodge d100 [Re: aquamist60] #1066935
09/06/11 11:28 PM
09/06/11 11:28 PM
This is a 426 HPP truck, and there is a picture in the thread, there is a link with the before resto pictures in it.
Kasey
