Re: Emergency battery shut off [Re: MR_P_BODY] #1065914
09/01/11 10:09 AM
09/01/11 10:09 AM
ont,canada
mopartuner Offline OP
ont,canada
So for now I can run the wire from the alt to the battery with a #8 and this will be ok.The wire will be about 13 ft long.A number 10 wire won;t work?
410 pump gas solis flat tappet cam 10.95 so far
Re: Emergency battery shut off [Re: smokinwoody] #1065915
07/29/13 01:55 PM
07/29/13 01:55 PM
ont,canada
ont,canada
this is how I've been doing mine...
My battery isn't charging,i hooked my cables the same as in the diagram but my solinoid has 2 small studs rather than just one.any idea what i did wrong?should i just try the other terminal?
Re: Emergency battery shut off [Re: RobX4406] #1065916
07/29/13 06:46 PM
07/29/13 06:46 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
A fuse could be wired at the bat. If there is a short, fuse blowes & no fire.
Re: Emergency battery shut off [Re: mopartuner] #1065917
07/29/13 07:02 PM
07/29/13 07:02 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
The 2 small studs are the coil in the relay to make it work, ground one of them. The drawing you have shows a relay that already has the relay coil grounded(1 small term)
"Just a Bracket car dressed up like a streetcar"
Re: Emergency battery shut off [Re: mopartuner] #1065918
07/29/13 07:52 PM
07/29/13 07:52 PM
WA
JD Dart Offline
JD Dart  Offline
WA
This is how I did mine just interupt grd for alt relay 4 pole shut off switch.
Re: Emergency battery shut off [Re: JD Dart] #1065919
07/29/13 08:15 PM
07/29/13 08:15 PM
ont,canada
ont,canada
I grounded the other nerminal and now the relay works fine,can't say the same for the alt. it's toast
