Re: 451 or 470 for street/strip car [Re: ahy] #1065665
08/31/11 01:07 AM
08/31/11 01:07 AM
They are both good... it comes down to matching heads and picking your power curve. The 451 will want to wind higher than the 470 other things equal.
I haven't seen those results in my motors or freinds motors like mine, the 3.91 stroke with the lighter rods, pistons and wrist pins seem to rev quicker and make peak torque and HP at a higher RPM with similar cams and heads
Re: 451 or 470 for street/strip car [Re: Cab_Burge] #1065666
08/31/11 01:56 AM
08/31/11 01:56 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I agree, my 470 thinks it's a small block the way it revs...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 451 or 470 for street/strip car [Re: DaKuda] #1065667
08/31/11 02:27 AM
08/31/11 02:27 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
451 has a very light rotating assembly. 470 is even lighter using offset ground journals and bb Chevy rods.
BINGO........
Re: 451 or 470 for street/strip car [Re: Thumperdart] #1065668
08/31/11 05:18 PM
08/31/11 05:18 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
The 470 will give you a little more compression with a flat top piston. The piston would be lighter per a given length of rod, but I think the 6.535 rod is optimal for a 470 which is also cheaper than a chrysler rod. The 3.9 stroke also takes a little out of the radius of the crankshaft which arguably helps the strength. My machinist quoted me 150 more dollars to offset grind. Being the chevy rod is cheaper the price comes out close.
Re: 451 or 470 for street/strip car [Re: viperblue72] #1065669
08/31/11 05:43 PM
08/31/11 05:43 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
3.9 stroke would use a 6.700 rod with the available shelf stock 1.320 pistons if going long rod.
Re: 451 or 470 for street/strip car [Re: JohnRR] #1065670
08/31/11 06:59 PM
08/31/11 06:59 PM
V
viperblue72 Offline
viperblue72  Offline
V
JohnRR,
Good call! That piston canbe used for either 451 with 6.76 or 470 with 6.70.
Re: 451 or 470 for street/strip car [Re: viperblue72] #1065671
08/31/11 07:11 PM
08/31/11 07:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 470 combo uses the 6.385 rod fwiw.
