Lickity Split,the worlds slowest build,with "newer"pics
#1064737
08/28/11 10:23 PM
08/28/11 10:23 PM
Posts: 9,895 MI, usa
dvw
MI, usa
My wife has put up with a crummy kitchen for ever. How long? The appliances were harvest gold. So we've been remodeling our kitchen all the way down to the studs. With that nearly done it's back to the car. Its rubbed,body panels aligned,suspension installed. I'll let the pictures tell the story. Doug
Re: Lickity Split,the worlds slowest build,with pics
[Re: dvw]
#1064738
08/28/11 10:25 PM
08/28/11 10:25 PM
dvw
MI, usa
[Re: dvw]
#1064742
08/28/11 10:30 PM
08/28/11 10:30 PM
dvw
MI, usa
[Re: dvw]
#1064743
08/28/11 10:32 PM
08/28/11 10:32 PM
dvw
MI, usa
[Re: dvw]
#1064744
08/28/11 10:34 PM
08/28/11 10:34 PM
dvw
MI, usa
[Re: dvw]
#1064745
08/28/11 10:36 PM
08/28/11 10:36 PM
dvw
MI, usa
[Re: dvw]
#1064746
08/28/11 10:37 PM
08/28/11 10:37 PM
dvw
MI, usa
[Re: dvw]
#1064747
08/28/11 10:38 PM
08/28/11 10:38 PM
Posts: 1,169 MI
68shifter
MI
Wow, that thing is gorgeous Can we get more info on build, powerplant, class?
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: pro6pakRR]
#1064750
08/28/11 10:43 PM
08/28/11 10:43 PM
dvw
MI, usa
Looking good Doug.Are you and Scott going to Milan's mopar race? Chief
I would love to but We have a family commitment that Saturday. We will be at Norwalk. Scott's busy on his turbo small block 62 Savoy. Doug
[Re: 68shifter]
#1064752
08/28/11 10:51 PM
08/28/11 10:51 PM
dvw
MI, usa
I will be running N/SS,Max Wedge. The motor is a 572,15-1,.800" roller.-1 Indys by MCH,Indy cross ram,T&D rocker,jessel,BME rods. Push button 727, Wheels are vintage 200S Americans. Doug
[Re: dvw]
#1064753
08/28/11 11:00 PM
08/28/11 11:00 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I must say... That is a really clean setup you have there. The cage fits tight to the lines in the car. Looks like no surface has been left untouched. Not sure about the Bondobob bit though.
Would like to see details of your quick release steering wheel. If it is not top secret.
Leon
[Re: Leon441]
#1064756
08/28/11 11:14 PM
08/28/11 11:14 PM
dvw
MI, usa
Leon
This is the first cage I have ever built. I made templates and a buddy bent the main parts, I bent the smaller bends and fitted all the tubes. The wheel uses the original hub that is pot metal. The release hub is a unknown swap meet special. Steering wheel was drilled to the hubs bolt pattern. I fabbed a 1/8" aluminum disc that was welded to the hub. The factory pot metal hub was gutted and epoxied to the aluminum disc. It serves no function except to look factory. The button protrudes thru a hole where the old 3 on the tree stick was attached. Doug
