Mounting FP regulator? #1064462
08/28/11 01:48 PM
08/28/11 01:48 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
I've got a Mallory 4309 regulator and where I want to mount it is about 10"-12" away from the exhaust manifold. Is this going to be too close? I really wanted to mount it on the firewall but I would like to keep the high pressure side out of the engine comp. as much as possible just incase of a leak. I'm running a walbro pump so I've got a fair amount of pressure....
Re: Mounting FP regulator? [Re: SLOW67] #1064463
08/28/11 01:57 PM
08/28/11 01:57 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Not on the fire wall, against nhra rules. A foot from headers is fine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Mounting FP regulator? [Re: SLOW67] #1064464
08/28/11 02:28 PM
08/28/11 02:28 PM
Cab_Burge Online work
Cab_Burge  Online Work
I would, and do, mount the regulators in front of the carb instaed of behind it
Re: Mounting FP regulator? [Re: Cab_Burge] #1064465
08/28/11 02:39 PM
08/28/11 02:39 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the only way to fly
home of the
Sox and Martin Hemi Duster
Re: Mounting FP regulator? [Re: HEMIFRED] #1064466
08/28/11 04:49 PM
08/28/11 04:49 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
there is 2 in this pic. the one for the carbs is at the end of the fuel log. cool fuel to carbs mounting it behind the carbs
Re: Mounting FP regulator? [Re: sixpackgut] #1064467
08/28/11 11:40 PM
08/28/11 11:40 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Thanks guys
I decided to mount it off the front carb stud...looks better too
Re: Mounting FP regulator? [Re: SLOW67] #1064468
08/29/11 01:42 AM
08/29/11 01:42 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
got mine hangin here
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
