Page 2 of 3 1 2 3
Re: Could I please see your home made shop tools? [Re: MR_P_BODY] #1063358
08/27/11 05:32 PM
08/27/11 05:32 PM
NC
440Jim Offline
440Jim  Offline
NC
Attached is a picture of a few tools.
Front clutch compressor
727 bushing drivers, with screw on handle for hammer.
The rear servo comprssor isn't a must have, you can compress it with a strong hand, cyl head spring compressor etc. But this is small and makes it easy.
Also on the far right is a pin tool for turning the disc brake piston on a Ford with rear disc brakes (parking brake built in).
In the foreground is a large "wrench" to hold the pinion yoke securely if the nut won't come loose.
Re: Could I please see your home made shop tools? [Re: 440Jim] #1063359
08/27/11 05:35 PM
08/27/11 05:35 PM
NC
440Jim Offline
440Jim  Offline
NC
And here is one to hold the transmission using an engine stand. It allows the transmission to be vertical or horizontal. Dual bolt patterns for BB and SB Mopar. The big block pattern is painted white for easy ID since that is what I normally work on.
Re: Could I please see your home made shop tools? [Re: 440Jim] #1063360
08/27/11 05:53 PM
08/27/11 05:53 PM
NC
440Jim Offline
440Jim  Offline
NC
A couple notes on the 727 rear servo compressor.
I put an angle on it with the milling machine to get the angle aligned with the servo. The pan gasket surface isn't perpendicular to the servo motion. And the round plunger has a relief cut on it.
Re: Could I please see your home made shop tools? [Re: 440Jim] #1063361
08/27/11 05:58 PM
08/27/11 05:58 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
the most used tool i ever made is a 1/2 inch drive 5/8ths spark plug socket cut in half. a must have tool. i even painted it bright green so i can always find it in the tool box
Re: Could I please see your home made shop tools? [Re: sixpackgut] #1063362
08/27/11 07:26 PM
08/27/11 07:26 PM
NC
440Jim Offline
440Jim  Offline
NC
OK, I give up. What are some uses?
Is it cut in length or to open the side?
Re: Could I please see your home made shop tools? [Re: sixpackgut] #1063363
08/27/11 11:05 PM
08/27/11 11:05 PM
NJ
440challenger Offline
NJ
I made a 3/8 one with a 3/4 wrench head. great for angle plug eddys with tight headers
Re: Could I please see your home made shop tools? [Re: 440Jim] #1063364
08/28/11 03:50 AM
08/28/11 03:50 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
sorry, just a spark plug socket with 3/4 wrench end that fits tight headers. slips over the whole plug
Re: Could I please see your home made shop tools? [Re: sixpackgut] #1063365
08/28/11 05:55 AM
08/28/11 05:55 AM
Finland
mafo Offline
mafo  Offline
Finland
I have a lot of homemade tools, here is a few to start with
on head spring compressor
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Could I please see your home made shop tools? [Re: mafo] #1063366
08/28/11 05:58 AM
08/28/11 05:58 AM
Finland
mafo Offline
mafo  Offline
Finland
lifter bushing install tool
Re: Could I please see your home made shop tools? [Re: mafo] #1063367
08/28/11 06:09 AM
08/28/11 06:09 AM
Finland
mafo Offline
mafo  Offline
Finland
Flowbench
Re: Could I please see your home made shop tools? [Re: mafo] #1063368
08/28/11 06:11 AM
08/28/11 06:11 AM
Finland
mafo Offline
mafo  Offline
Finland
spring tester
Re: Could I please see your home made shop tools? [Re: mafo] #1063369
08/28/11 06:15 AM
08/28/11 06:15 AM
Finland
mafo Offline
mafo  Offline
Finland
don t know what this is called, it s to keep pistons in lathe chuck
Re: Could I please see your home made shop tools? [Re: mafo] #1063370
08/28/11 06:17 AM
08/28/11 06:17 AM
Finland
mafo Offline
mafo  Offline
Finland
vacuum tester
Re: Could I please see your home made shop tools? [Re: mafo] #1063371
08/28/11 08:47 AM
08/28/11 08:47 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
vacuum tester
thats some nice stuff,looks like you have some nice tools to make the tools.
Re: Could I please see your home made shop tools? [Re: bonefish] #1063372
08/28/11 09:20 AM
08/28/11 09:20 AM
Finland
mafo Offline
mafo  Offline
Finland
I have collected a lot of stuff over the years and now I m at the point that my shop is getting to small..
English Wheel I made some years back
Re: Could I please see your home made shop tools? [Re: mafo] #1063373
08/28/11 09:21 AM
08/28/11 09:21 AM
Finland
mafo Offline
mafo  Offline
Finland
Bead roller,
I really enjoy making and building stuff and we have long and dark winters here...
Re: Could I please see your home made shop tools? [Re: mafo] #1063374
08/28/11 11:02 AM
08/28/11 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats some nice looking tools... love the english wheel...
I have always wanted one of them... maybe some day...
but like you my shop is already toooooo small
Re: Could I please see your home made shop tools? [Re: MR_P_BODY] #1063375
08/28/11 11:23 AM
08/28/11 11:23 AM
Finland
mafo Offline
mafo  Offline
Finland
They are selling chinese wheels now ,look a little flimsy but I guess they are allright for hobby use,
you have to put in a lot of time before you get the hang of it, I have had mine for years and I m still just a beginner
Re: Could I please see your home made shop tools? [Re: mafo] #1063376
08/28/11 11:32 AM
08/28/11 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I've used them on a couple of different parts
and your right... the chinese stuff looks like it
would bend/bow if you used it... I wont even think
of one of those
Re: Could I please see your home made shop tools? [Re: mafo] #1063377
08/28/11 04:49 PM
08/28/11 04:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think mafo has us all beat...nice work.
Page 2 of 3 1 2 3
