Page 2 of 3 1 2 3
Re: Track report ! [Re: 383man] #1062683
08/25/11 09:46 PM
08/25/11 09:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
. Can't wait to hear more. When are you going back out?
Re: Track report ! [Re: AndyF] #1062684
08/25/11 10:15 PM
08/25/11 10:15 PM
fullmetaljacket Offline
Andy, with all due respect, didn't you just say in your last HP forum that the new Holley 950 was too big for any thing smaller than a 512 or some thing like that? 383 is running a 493 Cubic incher.
As far as Dominators, they are fine with most biggie blocks, but very few have made the magic number with them on a true street driven car like 383 as well as mine. I mean his 493 is very small compared to what's out there nowadays. Correct me if I'm wrong. Maybe there's a guru out there that can take the new Holley and make it run with his combo and still act civil on the street.
Re: Track report ! [Re: fullmetaljacket] #1062685
08/25/11 10:25 PM
08/25/11 10:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Way to go, Ron, .41 quicker IIRC with only a SWAG jet-change. There's a 10 in your immediate future, using the 850. A while back there was a thread about a 4150-body 1050CFM Holley, don't recall whose but it sounded promising.
Re: Track report ! [Re: topside] #1062686
08/25/11 10:43 PM
08/25/11 10:43 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
That is awesome, but it scares me that you have driven it that far with it possibly being too lean.
Re: Track report ! [Re: 383man] #1062687
08/25/11 10:47 PM
08/25/11 10:47 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Yes I drove to the track tonight and put 2 passes on my 63. I had some problems and found out it was way lean.
First pass it just would not rev good and felt real flat......11.27 @ 113 !
Yuk but my brother was watching and he said it looked good as it pulled about 6 inches under the front wheels but I said it felt real bad. I had just stuck the 850 DP on that was on my old 440 and I knew it needed more carb but I used what I had. Well we pulled the 80 primary jets and put 86's in. Car started fine and idled fine. Next and final pass for the night.........11.04 @ 121.42. Ok we made a drastic jet change to find out we are going in the right direction. We were going to pull the secondary bowl but I decided to call it a night as my back was hurting alot and my left knee was giving me alot of pain and I was not up to any more work. So I called it a night telling myself that 11.04 @ 121 is not to bad for the second ever pass on my pump gas full exh 3700 lb street car that I drove the 90 mile round trip. I will pull the carb and work it over this week. I wish I had a Dominator or a nice 950 to try but I will use what I have. I honestly think it has easy 10.80's or better and I hope to find out soon. I know I could have jetted the secondary side and came home with a 10.9 something pass but I was just not up to it. I had fun and hope to get back to the track in a month or so. Ron
Hey ron great job. 11.04 is the same et i ran last saturday but for some reasion they were not giving 1/4 mile mph. so could you post what your 1/8 et and mph were also ypour 60ft. sounds like there is alot more in it.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Track report ! [Re: mopar65] #1062688
08/25/11 11:16 PM
08/25/11 11:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Congratz Where's the pic of you hagin the hoops??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Track report ! [Re: hemi-itis] #1062689
08/25/11 11:35 PM
08/25/11 11:35 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Great first outing Ron!
Re: Track report ! [Re: Chargerfan68] #1062690
08/26/11 10:14 AM
08/26/11 10:14 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Congratulations Ron!! Great job with the new motor and very nice times so far. 10's are in the bag. Was that Cecil that you ran at?
Best of luck with you new motor.
Yes that was Cecil. It actually started getting much more humid out that evening. Ron
Re: Track report ! [Re: wheelsup68dart] #1062691
08/26/11 10:18 AM
08/26/11 10:18 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I have only driven it on the street where it felt fine driving normal. I would hit it a little once in a while but not really putting it to the floor and leaving it there as it felt fine even with a quick nailing the throttle. It had 80's and 86's in it with a 3.5 P/V up front. It drove fine going home and has not overheated or has no ping so I dont think it hurt anything. Ron
Re: Track report ! [Re: 383man] #1062692
08/26/11 10:23 AM
08/26/11 10:23 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for all the kind replies. Here is the rest of the #'s:
60 - 1.57
330 - 4.157
1/8 - 7.012
mph - 97.88
1000 - 9.189
1/4 - 11.044
mph - 121.42
I will have to stick with the 850 DP for now but I will jet the secondary up some and may even mill the choke air horn off. Thanks again for the replies. Ron
Re: Track report ! [Re: 383man] #1062693
08/26/11 11:07 AM
08/26/11 11:07 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Nice first outing Ron For sure there's lots more in it
Fwiw, mine made best power with 34* total timing using the EZ heads so that might be something to consider
Ron
Re: Track report ! [Re: firefighter3931] #1062694
08/26/11 11:22 AM
08/26/11 11:22 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Nice job, buddy!
Pretty sure a Pro-systems tweaked 1000HP like on mine would suit your very similar combo, I'd imagine you could put that thing solidly in the 10.65 range or better once you're sorted. That Max Wedge dual plane really likes a lot of CFM and traction/torque is definately going to be a chassis tuning challenge to really plant all the ET potential you're going to bring.
WIZE
In Car:
Re: Track report ! [Re: 383man] #1062695
08/26/11 11:23 AM
08/26/11 11:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good job Ron. 10's are in reach easy. Makes me want to step it up a bit on my ride...lol
Coming soon!!!!
Re: Track report ! [Re: Mr.Yuck] #1062696
08/26/11 11:42 AM
08/26/11 11:42 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Great first time out! You know you have a street ride that will run in the 10's, so I say well done! You can buy a new intake and a dominator and maybe pick up a tenth or two after tweaking and spending a grand. If it were me, I would just keep the nice street carb 850 and dial it in at the track next time out.
2 kids and a dog
Re: Track report ! [Re: 383man] #1062697
08/26/11 12:02 PM
08/26/11 12:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From what I recall you posting of the combination, I'd have expected more MPH, even w/ a chassis that wasn't hooking. Where is your timing set and how lean is that 850?
Re: Track report ! [Re: BradH] #1062698
08/26/11 12:08 PM
08/26/11 12:08 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Brad it was pretty lean. I was hoping to do more like 125 which I hope it will once I jet some more and mess with the timing. It was definetly still lean as it was holding back and even popping in the top of the gears. Ron
Re: Track report ! [Re: 383man] #1062699
08/26/11 07:55 PM
08/26/11 07:55 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Hi Ron, you want to borrow my 950 proform that is on my 493? has been 10 teens on my pump gas muff. motor in the demon.Let me know.
Tom.
Re: Track report ! [Re: grncpe] #1062700
08/26/11 10:20 PM
08/26/11 10:20 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Tom.
Thanks Tom but my buddy just told me about an hr ago to try his 950 Proform. So when I go back to the track I will run the 850 and then the 950. He told me if I like the 950 to keep it on the car as he wants to put the 850 back on his car which is a street car that he never races. Ron
Re: Track report ! [Re: ZIPPY] #1062701
08/27/11 03:31 AM
08/27/11 03:31 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
[quote
6" wheelies are pretty good for a street car
Wow, isn't that re truth! Awesome run Ron.
Mike
1969 Dodge Dart Swinger
Re: Track report ! [Re: MikeyT] #1062702
08/27/11 04:02 AM
08/27/11 04:02 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
11.04 @ 121 ? AWESOME!! There's a bit MORE
in your combo Ron and to say 10.9's, would be on the conservative side! Take care of your back, feel better and "KEEP ON MAXIN' 'EM"!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Page 2 of 3 1 2 3
