Page 47 of 55 1 2 45 46 47 48 49 54 55
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1061953
11/19/14 09:17 AM
11/19/14 09:17 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Breaker Breaker 1-9 What's your handle....?????
Need to start a new thread....Dave CB Handle Suggestions....?????
I'll Start.....Waxer-1
Rickster
fixed
Re: I'm back with a new Mopar project! [Re: Quicktree] #1061954
11/19/14 11:26 AM
11/19/14 11:26 AM
Tampa
DusterDave Offline OP
Tampa
Rickster
fixed
Figured you'd come up with that one...
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061955
11/19/14 08:26 PM
11/19/14 08:26 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Whats yur Vector Victor??
Mopar to the bone!!!
Re: I'm back with a new Mopar project! [Re: 72Swinger] #1061956
11/20/14 12:40 AM
11/20/14 12:40 AM
Tampa
Tampa
Tonight, I finished wiring up the tach, speedo, fuel level, voltmeter, oil pressure, and water temp gauges. All gauges are plugged into Weatherpack connectors. I still have the turn signal and high beam lamps, and trans temp gauge left to get done.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061957
11/21/14 03:01 PM
11/21/14 03:01 PM
ohio
all spooled up Offline
ohio
nice job dave
Re: I'm back with a new Mopar project! [Re: all spooled up] #1061958
11/23/14 10:59 AM
11/23/14 10:59 AM
Tampa
Tampa
Wiring update. I wired in the trans temp gauge, trans cooler fan, and the high beam and turn signal indicator lamps.
Electrical work left to do:
- Run various ground wires to the frame
- Run battery cables
- Wire up the horn relay
- Install the steering column (temporarily, for circuit testing)
I'm on track to check the circuits next weekend. The dash panel will not be installed during testing. I'll use my battery charger in place of the battery, set at a 10 amp output.
Once everything electrical is shown to be working properly, then I will install the stereo system.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061959
11/28/14 10:31 PM
11/28/14 10:31 PM
Tampa
Tampa
Today, I installed the DieHard Platinum group 65 battery and the Antenna-X radio antenna. Group 65 is about the biggest single battery you can stuff in the stock location, and with 950 CCA, this is one strong battery. You know its getting close when the battery gets installed!
The battery cables will be installed tomorrow, but not hooked up just yet. I will be using a battery charger for circuit testing. Safer that way.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061960
11/29/14 06:54 PM
11/29/14 06:54 PM
Tampa
Tampa
Rotopax 2 gallon fuel containers arrived today. Rotopax is selling blems of the 2 gallon size at 45% off, so I took a chance and ordered a pair. I don't see anything wrong with them. I've never owned them before, so I don't know what perfect Rotopax containers look like. I still need to purchase the locking mechanisms, and then get to work fabricating mounts on my tire swingout.
They will live behind my spare tire.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061961
11/30/14 03:05 PM
11/30/14 03:05 PM
Tampa
Tampa
Wiring update. I didn't get much done yesterday, due to a pounding sinus headache, but I did get all of the ground wires screwed to the frame and/or body. All I have left to do is install the positive battery cables, and install the steering column. I will get the column installed today, but I'm waiting on 1 gauge cable solder lugs to get here sometime later this week.
I'll be testing circuits next weekend, FOR SURE!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061962
11/30/14 09:13 PM
11/30/14 09:13 PM
Tampa
Tampa
I added these four switches. The two fan switches will be manual overrides, in case a relay or a thermoswitch dies. I don't have a 50" LED light bar yet, but one will be added over the next several months. No plans for a Zombie Targeting System, though. The systems currently on the market aren't reliable, anyway. That switch is just a place holder for another switch I'll actually need down the road.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061963
12/01/14 03:14 AM
12/01/14 03:14 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
Looks good. Where did you get the custom lettered switches?
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: I'm back with a new Mopar project! [Re: blown340] #1061964
12/01/14 01:37 PM
12/01/14 01:37 PM
Tampa
Tampa
I bought the switches from here: http://www.otrattw.net/
Most of the switches they sell are geared for the off-road crowd.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061965
12/04/14 12:37 AM
12/04/14 12:37 AM
Tampa
Tampa
I decided to ditch the cheap Grant steering wheel in favor of something that fits in with the red and black theme. Call me crazy, but I think this wheel fills the bill.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061966
12/05/14 02:08 PM
12/05/14 02:08 PM
Monroe,Connecticut
BigEdsGarage Offline
Monroe,Connecticut
Good stuff here Dave! Great quality parts and excellent craftsmanship on this rig
Re: I'm back with a new Mopar project! [Re: BigEdsGarage] #1061967
12/06/14 12:14 AM
12/06/14 12:14 AM
Tampa
Tampa
Thanks, Ed!!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061968
12/07/14 01:27 AM
12/07/14 01:27 AM
Tampa
Tampa
With the wiring finished up, I hooked up my battery charger (set at 10 amps) and did some initial electrical circuit testing tonight, and had some surprises. Here's what I found. First, the good news, then the bad news:
What works:
- Radio (powers on)
- Side marker lights
- License plate light
- Driver side courtesy light
- Gauge lights
- Brake lights
- Left turn signal, front and rear
- Tail lights
- Heater fan motor (however, a loud noise when running, sounds like squirrel cage inside is rubbing/hitting something)
- Voltmeter gauge reading voltage
- Left turn signal indicator lamp
- High beam indicator lamp
- Fuel pump (however, it runs even when the key is in the OFF position. Must be full time Hot. May need to add a relay.)
What doesn't work:
- CB did power on, but after a while, it shut off and I couldn't turn it on again
- Headlights
- Wipers
- Right turn signal (comes on, but doesn't blink.. )
- Right turn signal indicator lamp (comes on, but doesn't blink)
- Reverse lights
- Passenger side front turn signal
- Passenger side courtesy light stays on
I was a bit disappointed to encounter so many issues during the test. I'll do some troubleshooting tomorrow. I was thankful that at least nothing started smoking!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061969
12/07/14 01:46 AM
12/07/14 01:46 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
Pretty simple to figure out. I would make sure each item that is not working has a proper ground. Then make sure the designated wire is powered up. You came this far so this is a minor hurdle. Nice job Dave.
Re: I'm back with a new Mopar project! [Re: NITROUSN] #1061970
12/07/14 11:57 AM
12/07/14 11:57 AM
Tampa
Tampa
Thanks! See my next post!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061971
12/07/14 11:58 AM
12/07/14 11:58 AM
Tampa
Tampa
**WIRING UPDATE**
I spent about 40 minutes this morning, troubleshooting the electrical issues I encountered last night. I got a lot of issues fixed, with the turning of one bolt! The firewall bulkhead connector bolt (the bolt that draws the two halves of the bulkhead connector together) was loose! I tightened it up, and instantly had working headlights, reverse lights, and properly working right turn signals! Woo-hoo!!
I fixed the constantly "on" passenger side courtesy light, so now it turns off when its supposed to.
My CB that was "on" last night and then stopped working, has a 2 amp inline fuse on the power wire. I pulled the fuse, and it was blown. I don't know what would have caused it to blow, it's wired up to my switched 12v distribution block, along with everything else. One thing of note, and I don't know if it caused the fuse to blow, but I didn't have the mic or the antenna hooked up to the CB. I popped in another 2 amp fuse, and it turns on again.
I thought maybe the wiper motor wasn't getting a good ground, so I tried jumpering the metal housing to the ground distribution block. Still doesn't work at all. I'll need to review my wiring for it.
So based on what I checked last night, the only thing left on the "doesn't work list" are the non-working wipers. This one bugs me...
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061972
12/07/14 04:40 PM
12/07/14 04:40 PM
Tampa
Tampa
Let there be light!
Tail lights on, with the trans shifted into reverse. I was surprised at how bright those 2.5" LED reverse lights are.
